String Alignment
Old Feb 27, 2008 | 07:56 AM
SteveA's Avatar
SteveA
Default String Alignment
I finally found a use for the front and rear tow hook fittings
If you are bored and have a couple of hours (and a euro spec rear bumper with a centre tow hook hole) you can make a pretty decent string alignment setup for cheap. I always liked smart strings, but they are over $600 by the time I pay international shipping to get to me. This set up cost me less than $100 thanks to some spare board lying around, a few bolts and some cheap aluminum levels from a chinese outlet.
The tow hook holes are perfect for mounting as they are centered on the car. The whole thing is very stable and easy to adjust.
Old Feb 27, 2008 | 08:48 AM
daveh's Avatar
daveh
Well done!
Old Feb 27, 2008 | 08:13 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
+1! do you adjust your alignment while you're on your rack?
Old Feb 27, 2008 | 08:25 PM
350ZTheStandard's Avatar
350ZTheStandard
Okay, i am lost what are you supposed to be doing here? Because the write up is kinda not complete or i am a complete MOROn.
Old Feb 28, 2008 | 01:36 AM
SteveA's Avatar
SteveA
String alignment is a low technology but quite accurate way of doing wheel alignment, setting toe, checking frames for squareness etc. Unless you are familiar with it this probably doesn't make much sense
People have traditionally used parrallel string lines not attached to the car but the problem with those is that the minute you move the strings or the car, you have to remeasure. Finding a way to attach the strings to the car means you can roll the car around to settle suspension after making changes and not affect the relationship of the parrallel lines to your centreline or hubs.
Smart Strings is a popular commercial solution.
http://www.pegasusautoracing.com/pro...asp?RecId=3004
This is just a home made idea to achieve the same thing
Old Feb 28, 2008 | 01:40 AM
SteveA's Avatar
SteveA
Yes, I like being able to make changes under the car without jacking and most of all being able to stand up and save my old back!
Old Feb 28, 2008 | 08:04 AM
daveh's Avatar
daveh
Do US spec cars have a center rear tow hook like that? I only know of the thing on the driver's side under the bumper.
Old Feb 28, 2008 | 10:50 AM
SteveA's Avatar
SteveA
You mean not everyone has one of these?? Maybe its a gender thing
Old Feb 28, 2008 | 12:58 PM
dnguyent's Avatar
dnguyent
Attachment 179362
Attachment 179364
Nope, we don't have that thing that's below the right side headlight either.
Old Feb 28, 2008 | 07:15 PM
SteveA's Avatar
SteveA
Huh. Interesting.
Those things pop open when you select the weapons button on the dash board
Old Feb 28, 2008 | 07:24 PM
crg914's Avatar
crg914
Nice job. I remember learning how to do string alignments 'back in the day'. lol. Thumbs up
Depravity
Oct 1, 2015 04:49 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
