Changing Brembo Pads
Old Apr 10, 2008 | 02:47 AM
JETPILOT's Avatar
JETPILOT
Default Changing Brembo Pads
How do I push the Brembo brake pistons in with the caliper on the car when installing new brake pads. The Nissan service manual specifies the use of a disc brake piston tool.
How do I do it.
Also do I bleed both screws on each caliper? In a particular order?
JET
Old Apr 10, 2008 | 03:09 AM
DavesZ#3's Avatar
DavesZ#3
Big C-clamp works great for compressing them.
Yes, bleed both. Bleed inner first, then outer.
Old Apr 10, 2008 | 03:16 AM
JETPILOT's Avatar
JETPILOT
How can I use the c clamp without removing the caliper?
JET
Old Apr 10, 2008 | 03:53 AM
RandomHer0's Avatar
RandomHer0
I've used big channel locks, just put a rag or something over the caliper not to scratch it and then squeeze....
Old Apr 10, 2008 | 04:34 AM
mhoward1's Avatar
mhoward1
I have found the inexpensive brake compression tools (like $5) very useful. Just undo one of the caliper clamp bolts, swing the caliper up, remove the pads from the braket. Then take one of the old pads, place it against the caliper and use the tool to depress the piston. You can change all the pads in about 30 minutes this way.
Be sure to bleed the lines afterwards. I prefer to change all the pads first, reset the MC, then bleed from the passenger rear up.
Old Apr 10, 2008 | 05:52 AM
dhwang80's Avatar
dhwang80
hmm, i read bleed outer to inner.
Old Apr 10, 2008 | 07:43 AM
Axelerate's Avatar
Axelerate
I just remove the brake fluid cap to release pressure, and then I either use old pads to compress them or my fingers. Never had any problems and can do it in 15 minutes with the car 4 pointed.
Old Apr 10, 2008 | 07:47 AM
Axelerate's Avatar
Axelerate
How do you reset the MC????
I bleed LR, RF, RR, LF and do the outers first.
Old Apr 10, 2008 | 07:49 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
I changed my brembo pads in 30 minutes flat. pull the cap off and take a pair of flat mouthed crecent wrech squize down the piston and put the cap back on the pressure should hold it down in the system.
I did that 4 times and Not a big deal at all. Our pads are super easy to change. Its designed to be a quick system so you can actually track the car.
Old Apr 10, 2008 | 09:33 AM
mhoward1's Avatar
mhoward1
Pump the pedal until the pistons movde into place and the pedal gets firm again.
Old Apr 10, 2008 | 12:33 PM
dklau33's Avatar
dklau33
If you have some cash burning a hole in your pocket get this.
http://www.zeckhausen.com/Tools/cali...n_spreader.htm
My buddy has one of these and it works great!
Old Apr 10, 2008 | 02:34 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
I used a C-clamp.
Old Apr 10, 2008 | 03:16 PM
laze1's Avatar
laze1
I use either of these tools (or equivalent tools) depending the car......pretty cheap and work fine
Old Apr 10, 2008 | 03:50 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
You guys pull the caliper off are you serious?
I can change pads in 5 min each brake with the caliper on?
Crazy...
Old Apr 10, 2008 | 04:06 PM
DavesZ#3's Avatar
DavesZ#3
Crazy...
How are you forcing the pistons back in?
Old Apr 10, 2008 | 04:10 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
With the quickness, its a two man operation. one man on the resovoir cap. use clamp to compress with cap open, and then close it to presurize, slide pad in.
Next side is tricky, its a shimmy in with same procedure.
Do that 8 times and you are done.
Old Apr 10, 2008 | 07:26 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
i use the piston spread from snap-on. not too expensive, but very effective.
if you are just changing pads, you don't need to bleed the brakes. i may have missed something, but i'm not sure why everyone is telling you to bleed it. but, when/if you do bleed your system, always start with the OUTSIDE bleeder first. the concept is bleed what is furthest from the master cylinder (kind of like an "outside-in" mentality).
here is the bleeding order: rt rear -> lft front -> lft rear -> rt front (this bleeding order is from the FSM).
i don't even see how you would use a c-clamp over the 4-piston brembo caliper...dave may know something i don't. you definitely don't need to remove the caliper to change pads.
Old Apr 11, 2008 | 04:03 AM
Kolia's Avatar
Kolia
Tools to push the pistons back in the caliper ? Who needs that ?
Just open on of the bleed valve (install your bleed tube) and "twist" the rotor against the pads. This will loosen the pads enough for removal.
Then it's just a matter of using an old pad or simply your thumbs to push the pistons back. With the bleed valve open, they won't offer much resistance.
Do not push the pistons back in without opening the bleed valves. A fluid reservoir overflow is the least of your problem. Think contaminated fluid being pushed back into the ABS module... Not good.
Old Apr 11, 2008 | 06:08 AM
OPTIMO's Avatar
OPTIMO
That's what I do as well - open the bleeder valve and use my thumbs.
Old Apr 11, 2008 | 06:41 AM
n1cK!'s Avatar
n1cK!
Infiltrator!
does the amount of brake fluid that goes "back into the system" really amount to enough being pushed back into the ABS module?
