FN01R-C 17x10 -12 fitment
Old Jun 28, 2008 | 07:33 AM
  #41
ke0ki2k's Avatar
ke0ki2k
Originally Posted by nlzmo400r
just a couple of action shots, no rubbing whatsoever and im at a pretty low ride height (about as low as JET i think)
stock caster? or are ya runnin the +1 degree SPC caster plates?
and how do you do in BSP down in N.O.? been thinking about running it up here (what mods other than suspension bits ya got?)
Old Jun 28, 2008 | 03:59 PM
  #42
nlzmo400r's Avatar
nlzmo400r
running factory caster, no aftermarket caster plates. Im doing very well in BSP here, actually Im usually in hot contention for FTD within my region
Old Jun 28, 2008 | 04:22 PM
  #43
ke0ki2k's Avatar
ke0ki2k
what kinda boltons are ya runnin? stock VLSD or clutch/gear type aftermarket?
Old Jun 28, 2008 | 04:32 PM
  #44
nlzmo400r's Avatar
nlzmo400r
my car is as stock as the day it left the showroom floor powerwise. I have an OEM vlsd, cusco zero2's, cusco upper A-arms, and my RPF1s with Kuhmo slicks. Thats it.
Old Jul 9, 2008 | 10:51 AM
  #45
scotts300's Avatar
scotts300
first350 from washington runs BSP and hes running 295/30-18 Hoosiers up front with a +23 offset 2" drop with -2 degrees camber. he says it lightly rubs the fender wells and only has a couple mm of clearance on the inside.
Do you know what width wheel?
Originally Posted by laze1
I run 17x10 ET25 with 275-4-17 RA1s all-around on track
Note I run a 3MM spacer in the front only to give a little more clearance between the wheel and the suspension upright. Only have enough to barely slide my little finger between the wheel and Upright....close..........the
So that essentially puts you at 17x10 +22 front, which is the new set I found for sale in the FN01R-Cs with a matching 17x10 +22 rear (which I think should be fine - I was more concerned about the front). Do you think you could fit more tire, like a 295/35, in either location?
Old Jul 9, 2008 | 06:11 PM
  #46
laze1's Avatar
laze1
Yes, I think a 295 will fit front and rear....I have plenty of room with the 275/40
Old Jul 9, 2008 | 06:24 PM
  #47
nlzmo400r's Avatar
nlzmo400r
295/35 will be a pretty tall tire, I would opt for the 295/30 and you'll have no issues.
Old Jul 9, 2008 | 06:59 PM
  #48
z33sm2's Avatar
z33sm2
I ran 295/30/18 up front and 315/30/18 in the rear last year. I had to flatten the fender lips but the car was sitten pretty low.
Old Jul 10, 2008 | 06:34 AM
  #49
scotts300's Avatar
scotts300
Thanks. Any pics of your fender lips? I don't think I've ever seen the fronts adjusted.
Old Jul 10, 2008 | 03:06 PM
  #50
z33sm2's Avatar
z33sm2
I didnt take any up close pics of the inside of the fenders. I'm running wider wheels and tires this year so I had to pull the fenders out quite a bit.
If you do roll the fender lip make sure to trim the tab that holds the fender liner or you will get an ugly bump on the fender. The flattened lip will hold the liner up just fine and it will look alot better from the outside.
Old Aug 8, 2008 | 02:05 PM
  #51
mario23's Avatar
mario23
Performance wise, how wide is too much?
I was thinking about 275/40/17 all around but haven't pulled the trigger yet as I am still debating with myself whether I want to do that or stagger the setup for the track. I believe the FN01RC 17X10+25 will fit ok with those tires. Do you guys think that 275 up front is ok or too much grip possibly slowing the ride down?
Thanks...
Old Aug 10, 2008 | 05:18 PM
  #52
scotts300's Avatar
scotts300
Thanks...
The square 275 set-up is great. Many members run this way, as well as myself for a long time now.
Old Aug 10, 2008 | 05:21 PM
  #53
mario23's Avatar
mario23
Thanks for the response. I really like the idea...may have to make a move
Old Aug 12, 2008 | 02:12 PM
  #54
scotts300's Avatar
scotts300
I just took delivery of four 17x10 FN01R-Cs and sold my 275/40/17 RT615 set-up (one set of used tires one set of new). Just need to solidify how much tire I can fit and still be able to rotate to maximize life. I'm thinking/hoping 295/30 will do the trick.
Old Aug 16, 2008 | 09:53 AM
  #55
mw9's Avatar
mw9
Thanks...
This is also the setup I was looking to run, let me know how it goes.
Old Aug 30, 2008 | 08:35 AM
  #56
scotts300's Avatar
scotts300
I have been running a CCW set-up of 17x9.5 with 275/40/17s all-around for some time now w/o issue. Wheel offsets, as you've read in this thread, is key. I asking about the +12 set because I'm changing set-ups for next year, so have been selling old wheels and tires in preparation for it.
I've taken delivery of THREE out of the FOUR FN01R-C 17x10 wheels (thanks for losing one, FedEx!), but they just cut a check to replace the lost one. Now I'm trying to figure out the best way to utilize this new set of wheels and a new set of Enkei RP01s in 17x9.5 +35. Two sets of wheels need to serve autox for the Z33 and track for both the Z32 and Z33, so I have some math to finish crunching. Right now I'm thinking I'll order a pair of 295/35/17s - which I'm confident will fit the rear - and test fit them on the front (FN01R-Cs). If they fit, then order two more for the rear; if they don't, then size-down to 275 fronts. The 295/35/17s are slightly taller than the 295/30/18 set-up discussed earlier, and almost 1.5" smaller than OE height for the front, so it'll be close. I was hoping for an even larger rear tire for autox, but with no 305s available, I don't have high-confidence that the 315/35/17 will fit in the rear. Any takers?
Old Aug 30, 2008 | 12:08 PM
  #57
laze1's Avatar
laze1
This is what I run..I use a 3 MM spacer in front,,,,5 MM would be better, but I currently have stock wheels studs...
Thanks...
I run
Old Aug 30, 2008 | 12:23 PM
  #58
laze1's Avatar
laze1
Thanks...
I run
Old Oct 15, 2008 | 09:11 AM
  #59
scotts300's Avatar
scotts300
I'm talking about 17" wheels, so only the 295/40/17 or 295/35/17 tires would apply. The 295/35/17 is about as tall as a 295/30/18 anyway. . . I'm bummed that the V710 isn't offered as a 295/35/17, only 295/40/17, so will probably run the 295/35/17 A6 for autox and R6 for HPDEs.
Update:
I bought a dedicated Z33 track car versus turning our ZR into a DD/track car.
It already has TEIN coilovers with EDFC, sway bars, some go-fast goodies, etc. The previous owner said it could be lowered more, but wasn't sure of the exact drop in the current state. I plan to add SPC rear adj arms so we can dial the camber in a bit.
Old Oct 15, 2008 | 10:27 AM
  #60
ExtaZ33's Avatar
ExtaZ33
I was going to bump this thread today...glad to see it's still going.
I just fit 17x9 +15 on all four corners...still running 255F 275R 615's...everything fits nice and no rubbing.
Can I fit the 275 up front also? Looking to finally run a square setup. I just changed out the +35 fronts to the +15's.
