Help me pick coilovers for NASA time trials
Old Jul 23, 2008 | 05:36 PM
Slow*Jim's Avatar
Slow*Jim
Default Help me pick coilovers for NASA time trials
Hey guys, I need some help choosing what coilovers I am going to go with. I am planning on competing in NASA TTC by the end of the summer and running in the National championships next season (currently in HPDE3). Budget is around $1700 for just the coilovers, and I plan on doing camber arms and toe correction front and rear. *Not going to be running slicks* unless I decide to make the move up to TTB, which is doubtful. The car is daily driven now but will probably only see roads once or twice a week in the future, so I would like to maintain some semblance of driveability. Not looking for super high spring rates with questionable dampening - I want a high quality coilover with easy adjustability that will allow me to be competitive in my class. And I would rather not do a true coilover conversion in the rear.
So here is what I'm thinking: HKS RS, Hipermax III, or KW v2
Thoughts?
Old Jul 23, 2008 | 07:55 PM
dmoffitt's Avatar
dmoffitt
Aren't there some TC single-adjustable Konis on closeout right now for like 1k? I'm super happy with my DA / Phase4 setup (planning on doing TTB and mainly PTB end of this / beginning of next year)
Old Jul 24, 2008 | 04:54 AM
Slow*Jim's Avatar
Slow*Jim
Link?
Old Jul 24, 2008 | 05:54 AM
dmoffitt's Avatar
dmoffitt
Originally Posted by Slow*Jim
Link?
saw it in Grassroots Motorsports or another mag, sale / advert. Try (614) 771-7744 ?
Old Jul 24, 2008 | 06:01 AM
AznSky's Avatar
AznSky
are you going to the NASA event at Mid-Ohio in August? A couple buddies of mine are going. Just wonderin
Old Jul 24, 2008 | 06:14 AM
Slow*Jim's Avatar
Slow*Jim
I'm at every NASA event at mid ohio.
Old Jul 24, 2008 | 06:20 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
Stance GR+ coilovers run about $1300. I think they are probably the best bang for the buck coilovers I have tried on the 350Z.
Old Jul 24, 2008 | 08:41 AM
Axelerate's Avatar
Axelerate
The RS's are a great street coil-over but, are not suited for competition. Maybe if you got stiffer springs.
I think a decent set of R compound's would make you faster than a set of coil-overs.
Old Jul 24, 2008 | 08:45 AM
Slow*Jim's Avatar
Slow*Jim
I may end up running R-compounds, but they would be useless without coilovers. Our cars have too much body roll and not enough negative camber to utilize R-comps.
I wouldn't have a problem going a little higher on the spring rates, but I still need the car to be usable on the street. Our roads in Ohio aren't very friendly to lowered cars.
Old Jul 24, 2008 | 09:25 AM
3m wol8's Avatar
3m wol8
just get the stiffer spring rates but don't drop it as much
Old Jul 24, 2008 | 12:09 PM
betamotorsports's Avatar
betamotorsports
You're joking right?
Old Jul 24, 2008 | 12:25 PM
stuntman's Avatar
stuntman
So you can't run KW V3s?
If not, then i'd choose V2s or Hypermax III.
useless without coilovers? I disagree. First off, the Z has a crazy amount of camber gain in the rear, lower the car atall and you have too much rear camber. In all the Z's ive driven, wearing the outer edge of the tire is hard to do especially in a lowered car due to the camber gain. If you fix that with camber arms, the tire tends to wear more evenly and even if you have almost zero camber, your car will handle better if you're working the outer edge of the tire more than just the inner.
Even without coilovers and a lot of body roll, R-comps will still be a few seconds faster. I'd take R-comps over coilovers any day as tires makes all the difference (so no you don't need coilovers before you get R-comps).
Then get KW V3 and larger swaybars. The ride quality of the V3s are phenominal as the damping is very well matched to the spring rates compared to most everything else on the market.
0.02
Old Jul 24, 2008 | 04:20 PM
Slow*Jim's Avatar
Slow*Jim
I just want to make sure I am utilizing the entire contact patch before I start sinking too much cash into r-comps.
Are the v3's really that much better than the v2's?
Old Jul 24, 2008 | 04:53 PM
stuntman's Avatar
stuntman
Yes the V3s are, they are also double adjustable vs. single adjustable.
Again, tires make the biggest difference. You could put $10,000 race dampers on your car, but if you have the same crappy street tires, you won't get that much of an improvement. Tires are one of the biggest aspects of your cars performance (and are its limitation). R-comps on stock suspension would probably be faster than 4-way adjustable race dampers with street tires.
Old Jul 25, 2008 | 07:01 AM
Fluid1's Avatar
Fluid1
I couldn't disagree with this any more!!
I say Koni yellows that are matched to Swift springs. the drop will give you more negative camber and you'll have damping adjustment.
Old Jul 25, 2008 | 09:11 AM
mojojojo's Avatar
mojojojo
Default konis
I have a set of TC Kline Koni single adj. I'll sell for $500.00
They worked fine in T2.
Old Jul 25, 2008 | 01:39 PM
Slow*Jim's Avatar
Slow*Jim
I'm liking this idea... and shopping around the vendor classifieds gets me both for $935 shipped
Old Jul 25, 2008 | 03:32 PM
stuntman's Avatar
stuntman
Are you referring to off-the-shelf swift lowering springs?
...Because swift makes tons of different spring rates.
Old Jul 27, 2008 | 09:28 AM
Fluid1's Avatar
Fluid1
Of course they do.
And yes, I'm referring to the Swift springs that have rates of:
336 front
364 rear
Having a spring of ANY rate matched to a shock that is valved for that exact spring is always going to be better than a set of name brand coilovers that, when shock dyno'd, may not even be a matched set. Put it to the test if you don't believe me.
To the OP, I'd get these springs, and maybe even the $500 TC kline single adjustables from the gentleman on this thread selling them, and send them off to have them valve matched to the Swift springs.
The Swifts' are going to be the lightest spring available for the Z as well, make sure you send either the springs or a complete list of their specs to TC.
Old Jul 28, 2008 | 09:02 AM
Slow*Jim's Avatar
Slow*Jim
Just FYI guys, I sent an email to Truechoice inquiring about revalving the Yellows and gave the rates on the Swift springs. They said it would not be necessary to revalve for the off-the shelf rates.
The standard Koni yellow valving will work fine with these spring rates.
