1st time at the track!!!!
Old Apr 24, 2009 | 03:01 PM
IslandZavage's Avatar
IslandZavage
Originally Posted by coachk
Paco...great driving for a first time out....how about some info on your car i.e tires,suspension, etc.
SPC F/R Camber kit F= -1.8 / R= -2.0
BC BR-type Coilovers set to full Stiff (felt great)
Hotchkis F/R Sways F=Full Stiff R=Medium Stiff
Nitto NT-05 tires (32PSI) these are some good *** tires!!!!
Ruff Racing 19inch F/R (Heavy/Cheap) 1st time out gimme a break..lol
Brakes were OEM FTMFL
PADS = EBC REDS never again. Occasional track pad my ***!!! mine were brand freakin NEW
Rotors = EBC OEM replacement Blanks (mixed feelings)
Changes to come: (Please comment)
Brakes will be replaced by Brembo F/R (already bought waiting to be installed).
Pads will be Carbotech XP10's
Might set rear sway to full stiff
Rotors will be slotted
Gonna order a better gripping Shift **** (i like my Nismo Titanium, but not enough grip for me)
Might just run the wastegate PSI so i can concentrate more on my technique, The speed is there but the seat time isn't.
Old Apr 24, 2009 | 03:07 PM
IslandZavage
thnkx for all the kind words fellas... Im hooked.. Dont worry Coach.. i still drag the car too..lol.. I know my roots...lol
Old Apr 24, 2009 | 04:43 PM
Ataru074's Avatar
Ataru074
I'd change the front camber and go at least -2.5, than remove the full stiff...
I know, the body roll is ugly but with "street" tires you're loosing grip in that way and the car is less forgiving.. (and you have "some" juice).
that both in the shocks and in the sway bars.
rotors better be blank... centric premium are cheap and works really good.
pads... you got brembo! why don't use ferodo ds2.11 or 3000...
Old Apr 24, 2009 | 07:16 PM
JETPILOT's Avatar
JETPILOT
Brakes: I'd look into the Stoptech ST-40 front calipers w/14" rotors and the ST-22 caliper rear. The OEM brembo's have limits. The ST-40's you can get for $1995 for the fronts and you would be hard pressed to find the limits of the Stoptechs.
Pads: I have had great success with the new Hawk DTC-70 pads. They are really unbelievable. The yare available for both the Stoptechs and the OEM Brembo's.
Rotors: If you get the StopTech brakes they come with their 2 piece Aerorotoors which are really good rotors. if you go wit hthe OEM brembo's yo u can still buy the 2 piece Aerorotors for them.
Tires: I feel the best semi slick out there now is the Toyo R888. another great product.
Camber: With a sticky semi slick I would go with -2.5 in the frotn and -2.0 in the rear to start. You might like to add more. I run -3.0F and -2.5R.
Don't forget a good set of dampers!
Old Apr 24, 2009 | 07:40 PM
IslandZavage
I looked into the Stoptechs, but i got a GREAT deal on the Brembos.. COULDNT pass them up.. Maybe later down the line i'll look into stoptech when im ready. But for now the Brembos are a god send compared to OEM's..lol..
I plan on going to a sticky tire like the 888 later on this year. Gonna get a set of Enkie RPF-1's in 17inch all the way around.
Old Apr 24, 2009 | 07:44 PM
JETPILOT's Avatar
JETPILOT
I would go with 18's. I'm not a fan of 17's. They feel sloppy to me with the taller sidewall. Just something to consider.
Old Apr 29, 2009 | 01:35 PM
IslandZavage
thnkx for the advice
Old Apr 29, 2009 | 01:37 PM
coachk's Avatar
coachk
Paco...is the car ready to go this weekend in Sebring?
Old Apr 30, 2009 | 01:05 PM
IslandZavage
Im doing Sebring on June 21s with NASA.. I only wish it was this weekend..lol I need to hurry up and put the brake kit on and quit just starring at it...lol
Old Apr 30, 2009 | 07:56 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It's addicting...isn't it. You will be fine with OEM Brembos and some good pads, lines, and fluid. Shed some weight from your car, if you can get away with it. Report back on those XP10's. you are going to love them.
Hey Jet, Hawk DT-70's? They only thing I use those for, is to resurface/refinish my rotors if I pick up a few hot spots.
Old May 1, 2009 | 10:13 AM
anth72's Avatar
anth72
May I ask why are you running such low tire pressures(32psi)? I set mine at 40 up front and about 36 out back (hot pressures). This will give a little more cornering grip up front to help with the car's natural understeer. But you do have a lot of suspension mods so maybe I'm missing something. I'm obviously not an expert, not even close, but I'm curious. Higher tires pressure should result in better cornering grip.
Old May 6, 2009 | 07:41 AM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
I have run about 26 track days and have to say the carbotechs are the best pad. I run XP12 in front, XP10 in rear. I also run -3.0 camber in front, -2.5 in rear. Car is on rails. I have heard the R888s are slower than the RA1, never used them. I am going to be using NT01s now because I have a hookup on them. Once I learn the new motor, I am making the jump to hoosiers!
Old May 6, 2009 | 08:35 AM
laze1's Avatar
laze1
Agreed! I luv the Carbotech Pads...I run the XP12 (Front) and XP10 (Rear) for Time Trials, and XP10 (F & R) for HPDE
Old May 6, 2009 | 09:31 AM
AznSky's Avatar
AznSky
I plan on running XP10's in the Front and XP8's in the rear at Mid-Ohio this year on stock non-brembo brakes and RE-11's.
We'll see how well they'll handle for me! I know carbotech recommend's skimming the rotors, but do you guys think it's a must? I read somewhere that moving to a more aggressive pad will just take all the old material off by itself.
So maybe I'll just throw the new pads on and see if there's any vibrations
Old May 6, 2009 | 10:33 AM
Sharif@Forged
Forged Performance
Me three. It's a pretty magical pad. In a blind test drive, i would swear I was running a BBK. The bite, control, and fade resistance is impressive. Best pad I have used yet.
Old May 6, 2009 | 12:04 PM
JETPILOT's Avatar
JETPILOT
Have you used the DT-70's? What did you find wrong with them? I find them superior to anything I have ever used. I however never used the Carbotechs so I can't make a comparison.
Old May 6, 2009 | 12:44 PM
laze1's Avatar
laze1
CARBOTECH STROBGLY RECOMMENDS RESURFACING THE ROTORS...or use new ones..I would take their advice ( I do and have NO problems - with brakes )
Old May 6, 2009 | 02:40 PM
  #38
Morris's Avatar
Morris
Well, hook the rest of us on the NT01's. I think they are great, but I am going thru them like candy!
Old May 6, 2009 | 06:10 PM
  #39
Sharif@Forged
Forged Performance
Yes I have. They are a good compound, but abrasive as hell on rotors. There are better compounds, that offer just as much friction, but far gentler on rotors.
I made this comment, somewhat tongue and cheek. If you run the DT70's on the street for an hour, your car will double as a mobile brake lathe.
Old May 6, 2009 | 06:13 PM
  #40
Sharif@Forged
Forged Performance
I didn't resurface mine...two different sets of rotors, and 3 sets of Carbotechs along the way. With the XP12's I had a few smears here and there...nothing major at all. With the XP16's, looked like a very good bedin and mating process.
This is with the GT-R.
What has your experience been with them?
