Lapping at Calabogie Motorsports Park
Old Jul 25, 2009 | 11:20 AM
RandomHer0's Avatar
RandomHer0
Default Lapping at Calabogie Motorsports Park
Hey guys, thought I'd share my video with you all.
I was a novice on this track, first time there. Absolutely amazing track...
Length:
5.05 km (3.05 miles)
Number of Turns:
20
West Track:
2.2km (1.38 miles)
East Track:
2.81km (1.74 miles)
Track Width:
40 feet
Elevation Change:
65 feet
Camber in turns:
0% to 6%
Straightaway:
2000 ft.
Direction:
Clockwise
Surface:
Polymer Modified Asphalt (Koch Stylink PG 70-34)
Safety systems:
Extensive run-offs, and combination of tire barriers/walls, guardrail, and concrete
East Paddock (main):
3.75 acres
West Paddock:
1.2 acres
Total site acreage:
1200
Track acreage:
275
<object width="640" height="480"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=5757479&amp;server=vimeo.com&amp;show_ title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp ;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=5757479&amp;server=vimeo.com&amp;show_ title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp ;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="640" height="480"></embed></object><p><a href="http://vimeo.com/5757479">MCO Calabogie Lapping Day July 23rd 2009</a> from <a href="http://vimeo.com/user2080412">RandomHer0</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
Old Jul 25, 2009 | 12:02 PM
WXSigns's Avatar
WXSigns
Vendor - Former Vendor
In the rain as well! Nice! I know too many peeps that won't even track in the rain.
Your following the guys line...don't do that.
Old Jul 25, 2009 | 12:11 PM
RandomHer0's Avatar
RandomHer0
Which car? I still find it difficult to acknowledge the car in front but not follow their lines...newb mistake. Need more seat time!
Then rain was a great learning tool, teaches you to rely on your lines and smoothness rather than just sticky tires and brakes...
Old Jul 25, 2009 | 01:59 PM
Its raining but you make no mention of tires.
Video can be deceiving, but I see not obvious overseer incidents. Oh come on give the car some gas.
Old Jul 25, 2009 | 04:02 PM
WXSigns's Avatar
WXSigns
I was referring to the white car BMW? in the beginning of the video.
That white car is a squirrel. Don't want to follow to close in the rain with that guy. He will collect you if he spins.
Did the silver hatchback signal early enough he was getting off track...geez.
Love watching Porsche novice drivers especially in the rain...lol
You did a good job seeing the dry line form.
Old Jul 25, 2009 | 04:20 PM
RandomHer0's Avatar
RandomHer0
Thanks guys, value the input, I was running NT05's, love those tires. I had NT01's but wasn't about to use them in the rain for my first time there...
You didn't see alot of oversteer because I left VDC on, I normally don't have it on because I find it intrusive more than anything but at times the rain was really heavy, those 15 minutes you're seeing is from about an hour of taping. 2 different run groups.
Thanks again for looking and for any advice...
Old Jul 25, 2009 | 04:46 PM
WXSigns's Avatar
WXSigns
Your Tire choice was good.
NT01s are good in the rain but when the let go they give you zero warning. I know from experience.
Old Jul 25, 2009 | 07:06 PM
kuoyang's Avatar
kuoyang
Is it just me, that the track has a nuburgring feel to it.
Old Jul 26, 2009 | 04:13 AM
nissannx's Avatar
nissannx
Way to go to hang in there in the rain. You made a good tire choice and were at a great track. My suggestion would be to give yourself much more space between yourself and the traffic. You never know what they're going to do! MCO runs a really good event!
Here are my novice to the track comments from last year in my low power track car. I won't be getting there this year. But for anyone from the states, this track is worth the trip.
This has the awesome straights that the power guys need and love plus some very technical and challenging sections that push your car's handling. I had some car overheating issues on the second day and there were some organizing challenges the first day - but aside from that and it being six hours away from where I live, this was awesome.
Turn 1 - flat out corner with my car in 4th gear
Turn 2 - 2nd gear
Turn 3 - blind, 3rd gear flat out
Turn 4 - flat out
Turn 5 - hard braking, touch left side at Sir John A. then touch right at 5, swing wide into 6
Turn 6 - back on the gas; still deciding between 2nd or 3rd
Turn 7 - third flat out
Turn 8 - Temptation - great corner than invites you to go fast BUT does it ever tighten up. I was doing a two apex here - hard braking coming in as I was usually at the redline in 3rd. First apex probably just under the P in tempation, then straight to the right side of track (about where the half track enters) then brake and into second and really hard left.
Come in fast and wrong then you'll need to clean your shorts!
Turn 9 - WOT through a and b
Turn 10 - fast corner
Turn 11 - stay really wide here, third though it
Turn 12 - a - hard brake and grab 2nd; b - into 3rd and WOT
Turn 13 - WOT and move to right for next corner
Turn 14 - more brakes and grab 2nd
Turn 15 - WOT and third
Turn 16 - WOT
Turn 17 - some brakes and still deciding about 3rd or 2nd
Turn 18 - if you've come into 17 right then this and 19 are a sweet corner, decreasing radius. Grab second and it's smooth. Come in wrong and it's choppy.
Turn 19 - get into 3rd before 20
Turn 20 - WOT for the straight
Old Jul 26, 2009 | 04:27 PM
RandomHer0's Avatar
RandomHer0
Great notes, temptation is best taken the way you describe too!
Old Jul 26, 2009 | 05:11 PM
Parker01's Avatar
Parker01
Excellent driving in the wet and your car is a monster! You did a great job of not breach the limit... it is so easy to be greedy and ask for too much grip in the rain and have it bite you in the ***. I ran time attack at Mosport today with 1 wet session and I ended up sliding off the track, yikes!
That track looks amazing to drive and just plain beautiful, it would be extremely fast in the dry I would imagine!
Old Jul 27, 2009 | 05:09 AM
RandomHer0's Avatar
RandomHer0
You should come up and check it out! Ya I'd like to run it in the dry with my NT01's. I just gotta be comfortable first, as much as the track is huge, and wide, it's still very technical...
Old Jul 28, 2009 | 06:08 AM
anth72's Avatar
anth72
I really wanna drive on this track. I might head up there from Toronto in August with a group from Michigan. Now that's a long drive!
Old Jul 28, 2009 | 07:09 AM
RandomHer0's Avatar
RandomHer0
Yeah you're talking about 3balls?
http://www.3ballsracing.com/index.ph...ask=view&id=25
Good opportunity for those that want to check out this world class track, I'm still un-sure if I'm going to be at this event.
ablaine
Nov 29, 2016 10:13 AM
SharX59
Sep 30, 2015 10:54 AM
