This is why....
Old Oct 28, 2009 | 04:14 AM
laze1's Avatar
laze1
i think it is this recent roll bar failure
http://jalopnik.com/5390934/mustang-...over-tire-wall
Old Oct 28, 2009 | 04:50 AM
Tac-M's Avatar
Tac-M
^ omg !
Old Oct 28, 2009 | 08:05 AM
betamotorsports's Avatar
betamotorsports
One important thing to keep in mind is that the Mustang roll over was a one-in-a-million shot. It just flipped straight over onto its roof from the front of the car. 3,000 lbs. times the velocity of the flip was a load that is rarely ever encountered by the roof of a car in a road racing accident. In 99% of the roll overs the car rolls onto the roof and doesn't just land flat and square.
I'm not defending the roll bar installation (I know nothing about it) just letting you guys know that this was an unusual incident.
Old Oct 28, 2009 | 08:38 AM
laze1's Avatar
laze1
Do you guys remember the 350Z T2 car that crashed earlier this year? flipped like 10 times and the driver was not injured...I bet he had a "pro-built" cage.
Old Oct 28, 2009 | 08:42 AM
betamotorsports
This is the company that built the Mustang pictured in the wreck.
http://www.tulsacarfx.com/
Old Oct 28, 2009 | 10:07 AM
racerbob4's Avatar
racerbob4
I think that cage was done by www.rollcageguy.com who has done three of our cages so far. Hes located in Canton, Ohio and does superb work. We tested one of them and it worked perfectly. Part of the Mustang problem is found at many tracks and that is protective tires that are not banded together and eventually form a ramp.
Old Oct 28, 2009 | 10:16 AM
mhoward1's Avatar
mhoward1
Just a small correction..or really clarification. One of the Mustang guys has said that the bar was installed per directions, but it was a street use only one and not a true track bar. There was also some debate on the size of the tubing and which backing plates should have been used.
Old Oct 28, 2009 | 06:59 PM
ADMAN's Avatar
ADMAN
By the looks of it, it either flattened out the same as the roof or got punched through the bottom of the floor. Either way, it is still
Agreed on the tires not being banded together...
Old Oct 29, 2009 | 08:33 AM
DriveI65's Avatar
DriveI65
How did they survive if they were harnessed in?
Old Oct 29, 2009 | 08:38 AM
betamotorsports
They leaned forward or to one side. Pretty simple. And now you know the "myth" about having your head crushed if the roof caves in and you're harnessed in the car is false. Funny how reality is far different then what's posted on the Internet.
Old Oct 30, 2009 | 03:27 AM
laze1's Avatar
laze1
How can you "lean" if belted in correctly? (correctly is a key in this question)
In my car with 6-point, HANS, seat with full halo head support, I basically can't move...can barely turn my head or lean forward to hook-up my belts on entry, much less lean left or right any appreciable amount.
Old Oct 30, 2009 | 05:28 AM
mhoward1's Avatar
mhoward1
in this case I have heard the seat backs collapsed saving the occupants injury.
Old Oct 30, 2009 | 06:06 PM
T_K's Avatar
T_K
Probably wasn't voluntarily. Roof caves, seat collapses, body moves in to fill whatever open space is left. Don't know how much "wiggle room" is available in a 2 seater like the Z though.
Old Oct 31, 2009 | 09:34 AM
Tac-M's Avatar
Tac-M
hey guys , i am getting a little paranoid by looking at this ... do you think this is adequate for the front posts ? it looks like it is welded to the "frame" but the plate looks a little small...
Old Nov 2, 2009 | 08:15 AM
Z3305's Avatar
Z3305
Default Brain Failure
It seems to me that when you get to the point where you have racer paint, most/all of the trim pieces are out of your car, there's a fire extinguisher clamped somewhere and you think you want a rollbar you need to just get a professionally installed rollcage. That poor idiot in the 'Stang should never have been allowed on track.
Old Nov 2, 2009 | 10:56 AM
Stillen Z's Avatar
Stillen Z
That's what I was thinking.
The collapsing seat backs would certainly explain how the occupants survived...they'd end up lying on their backs looking up at the not very far away roof. I was wondering about that because it looks like they were wearing 4,5 or 6 point harnesses, any of which would have kept them upright under the collapsing roof.
If you're in a race seat where the back won't collapse, or even an OE seat in a car like the Z where the rear bulkhead will prevent the seat back from collapsing very far, a cage seems like a really good idea if you're wearing a 4,5 or 6 point harness. And especially if you're wearing a HANS.
supahotfiya
Dec 6, 2014 01:05 PM
wasuber
North West
31
May 22, 2008 04:40 PM
SweetDreamZ
May 25, 2007 11:28 AM
speedraver2
Mar 7, 2006 03:36 PM
