Lexan rear window
Old Nov 25, 2009 | 08:23 AM
reserved's Avatar
reserved
Default Lexan rear window
Looks like I may have an opportunity to pick up a CF rear hatch.
My question is about using Lexan instead of glass though. I know people have done it - but has anyone ever done it in their track car?
The rear window in our cars is pretty large, so I'm concerned about what might potentially happen at 130 mph with driver/passenger windows open!!!!!
Any thoughts??????
Old Nov 25, 2009 | 09:27 AM
ADMAN's Avatar
ADMAN
Prolly need to run a strap down the center.
Old Nov 25, 2009 | 09:33 AM
reserved's Avatar
reserved
I was thinking maybe 2 straps.
Wondering how thick the Lexan needs to be also.
Old Nov 25, 2009 | 03:04 PM
betamotorsports's Avatar
betamotorsports
1/8" to 3/16" is fine and run two 1" by 3/16" aluminum strap on the outside. It also helps to put two 1.5" holes in the Lexan near the top to help vent any pressure.
Running with the windows open actually creates a low pressure area inside the cabin until you get sideways at speed. Then the cabin pressure instantly transitions to high and sometimes the rear windows or front windshield blows out.
Old Nov 25, 2009 | 05:19 PM
reserved's Avatar
reserved
^ great info - much appreciated
Old Dec 3, 2009 | 04:51 PM
robbinsj's Avatar
robbinsj
it will crack blow out if not straped and vented from my understanding.
Old Dec 4, 2009 | 06:20 AM
reserved's Avatar
reserved
John
Did you use curved (formed) Lexan or a flat sheet?
Thanks
Old Dec 4, 2009 | 07:32 AM
betamotorsports
Flat sheet is fine for the rear window of a 350Z.
Old Dec 10, 2009 | 12:02 AM
bbs350z's Avatar
bbs350z
can i get pics of the straps being used?
Old Dec 10, 2009 | 03:02 AM
mw9's Avatar
mw9
Nice information guys, just ready to ask the same question
Old Dec 10, 2009 | 08:18 AM
pntfrk69's Avatar
pntfrk69
any idea on what the weight savings would be on this? or how much it costs?
Old Dec 10, 2009 | 09:35 AM
reserved's Avatar
reserved
They sell them here for $200 http://www.lsauto.com/
May be possible to have one made for less????
Regarding weight savings, I'm not sure, but I expect it would be significant.
Old Jan 30, 2010 | 08:23 AM
Dustman's Avatar
Dustman
Thumbs up
Is this something you can do on an everyday driver? I like the idea of wieght savings. Dose anyone have pic's of their car with a lexan window in the rear hatch?
Old Jan 30, 2010 | 08:39 AM
betamotorsports
They scratch easily, even the supposed scratch resistant Lexan. It can also be difficult to get a leakproof install. IMHO, I would not install Lexan windows on a street car.
Old Feb 3, 2010 | 11:58 AM
sfarrah's Avatar
sfarrah
I got the kit from lsauto.com and it saved ~7 lbs. I ran it last weekend for the first NASA race here in TX without any straps and it was fine, but I might add the straps just for piece of mind. I did use some washers when I installed it though to add a little more clamping area. Stock hatch glass is only around 14lbs.
Old Feb 6, 2010 | 12:58 PM
reserved's Avatar
reserved
Finally got my Seibon hatch and lexan window installed. Definitely not suitable for a daily driver IMHO. Unfortunately, I did not weigh it, but it certainly feels light.
My first track day of the year is coming up later this month (Sharif's GT-R day at VIR), so hopefully it will hold up OK.
Attached Thumbnails Lexan rear window-smaller.jpg   Lexan rear window-small.jpg
Old Feb 6, 2010 | 03:49 PM
misterniceguy's Avatar
misterniceguy
Nice. Is that on a stock hatch? Oops, just read the post instead of looking at pics. lol
Last edited by misterniceguy; Feb 7, 2010 at 01:56 AM. Reason: Reread while not drinking.
Old May 30, 2010 | 04:49 PM
misterniceguy
Why shouldn't this be used on a daily driver?
Old May 30, 2010 | 06:44 PM
dkmura's Avatar
dkmura
General & DIY Moderator
It's been discussed here, but to repeat: Lexan scratches easily and DD will do a number on it in a short time. It's also difficult to get a good water seal on a sheet of Lexan, so any rain will easily leak into the car.
As someone who's had Lexan in a variety of Nissan racecars, I'd also add you'll need special cleaners to clean the surface and it holds condensation (fogs) easily. For a racecar it's fine, but no way would I want it on my street car.
Old May 31, 2010 | 04:28 AM
GT-Rob's Avatar
GT-Rob
Lexan windows are not legal here (same with not running rear defrost) on the street. Unless you are already sub 3000lbs theres probably a lot easier ways to drop weight with less headache (we are talking ~7lbs here).
