Better wheel studs?
Old Jan 18, 2010 | 04:35 AM
corz's Avatar
corz
Default Better wheel studs?
Hey guys, with all my Autox tire changes I've been braking alot of the stock wheel studs. Any ones you think might work better for me?
Old Jan 18, 2010 | 04:36 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
check out the arp studs...i have them on my car and i do a lot of track days and i've had no issues with them
Old Jan 18, 2010 | 04:58 AM
racerbob4's Avatar
racerbob4
ARP studs are great and you can also get equal strength studs from Summit Racing in Ohio. I think they are the same as the Evo. Get fairly long ones so you can put on spacers if you want to move the tire out to the edge of the fenders.
The stock studs will eventually break. We torque ours to 80#'s.
Old Jan 18, 2010 | 05:34 AM
corz's Avatar
corz
Thanks guys, I'll check thos out
Old Jan 18, 2010 | 06:19 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
http://z1auto.com/prodmore.asp?model...ls&prodid=4356
Old Jan 18, 2010 | 09:27 AM
ADMAN's Avatar
ADMAN
Nismo has them too...
Old Jan 18, 2010 | 11:32 AM
phreaktor's Avatar
phreaktor
Design Engineer
I broke 3 on one rim during a standard wheel swap. Breaking a stud is probably one of the most nerveracking experiences if you have never changed one before, lol..
Old Jan 18, 2010 | 02:18 PM
laze1's Avatar
laze1
I got my ARP studs from SPL. This is the only way to go for Hi Performance Cars on a track with R-compound tires
splparts.com
Tel 1-866-SPL-PART
Quantity Item Code Description Price Each Amount
4 100-143L ARP wheel stud 14.3mm knurl long set of 5 49.50 198.00
1 20033SD Gorilla SD lug nut set 12mm x 1.5 open end 29.00 29.00
Shipping Shipping 10.83 10.83
$237.83
Old Jan 18, 2010 | 02:24 PM
03threefiftyz's Avatar
03threefiftyz
Originally Posted by laze1
I got my ARP studs from SPL or Import Parts Pro..I can't remember.
But this is the only way to go for Hi Performance Cars on a track
Agreed, I just bought some for my car.
Old Jan 18, 2010 | 02:28 PM
mw9's Avatar
mw9
Originally Posted by Z1 Performance
Bump for a bunch of good guys, recommend picking them up here. Got my studs and lugs here
Old Jan 18, 2010 | 02:46 PM
03threefiftyz
+1.
Old Jan 18, 2010 | 03:35 PM
laze1's Avatar
laze1
Consider replacing your front wheel bearings when you install the studs...if you have many track days/miles on the car...
Old Jan 18, 2010 | 03:42 PM
ADMAN's Avatar
ADMAN
Rear hubs too...
Old Jan 18, 2010 | 04:20 PM
laze1's Avatar
laze1
BTW: I have 2x new rear bearings available, as well as used front wheel bearing and a bunch of OEM wheel studs..some new/some used...
PM with offers as my 350Z is long gone..these are left over from my spares kit.
Old Jan 18, 2010 | 04:33 PM
DavesZ#3's Avatar
DavesZ#3
Wow, after 5+ years of autocrossing and track days with regular changes between street wheels and my autocross and track wheels, I have never broken a stud or stripped one or had a problem with lug nuts.
How are you removing them and better yet, putting them on? Impact wrench?
You should be tightening them with a torque wrench, never with an impact wrench. Also, at least once a year you need to put some anti-seize compound on the studs.
Better studs may be a cure but it sure seems you've got to be doing something else wrong to be regularly breaking studs.
Old Jan 18, 2010 | 04:46 PM
dhays's Avatar
dhays
I've never had a problem either with the Z, or with my old RX7. However, hearing these other guys makes me nervous. How tight do you torque your lug nuts Dave when you swap?
Old Jan 18, 2010 | 04:54 PM
laze1's Avatar
laze1
I have never broken one...but I don't take chances on the race track...
Old Jan 18, 2010 | 05:00 PM
DavesZ#3's Avatar
DavesZ#3
75 ft-lbs
Old Jan 18, 2010 | 05:07 PM
DavesZ#3's Avatar
DavesZ#3
I certainly agree that if you have a real race prepped car then it's worth the extra insurance of having ARP or similar studs. With a street car where you're constantly changing wheels, you are automatically presented with the opportunity to inspect the studs, plus if there is a problem, that's when you're likely to break one and find it.
If corz is only autocrossing, he's not subjecting the studs to the kind of stresses that tracking and racing does. Broken studs should be rare IMO.
Old Jan 18, 2010 | 08:34 PM
christoc's Avatar
christoc
I broke a ton of them on my old 350z, almost one a weekend. I ended up going with the NISMO studs on the front, never did put them on the rear. At that time though I changed from using a 4-way bar to just a socket, that severely cut down on the number of studs I broke. In fact I don't think I broke any of the rears after stopping using the 4-way bar.
