Z car AutoX and Roadcourse Modification Guide
Old Aug 22, 2010 | 09:56 AM
  #41
Dcdylan's Avatar
Dcdylan
I am currently running star specs 265 front and rear, so basically a very very sticky street tire. I occasionally switch over to 275 v710's all around if I feel like dispensing the cash. Thanks for the input! I'll try it out on my next alignment.
Old Aug 22, 2010 | 11:54 AM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the best way to find out what your car, with your suspension setup and your driving technique, is a pyrometer. It's among the most important tools you can take to the track (and sometime to record the results on). Try different settings, measure, rinse, repeat, and you will hone in on the settings that your car is most comfortable with (at least on that day)
Old Aug 23, 2010 | 01:03 AM
  #43
Dcdylan's Avatar
Dcdylan
Thanks for the tip. I'll be looking into pyrometers now for next season, I still have lots to learn. Thanks!
Question, will it be better to record pyrometer results on a large flat surface, somewhat like a skidpad, or at the track? The track is going to have a variety of straights and corners so the results will be an average of these combinations correct?
Old Aug 23, 2010 | 05:07 AM
  #44
Z1 Performance
Former Sponsor
a skidpad won't tell you much unless all you're doing is driving on a skidpad
you want to measure inside/center/outside during the conditions you are trying to set the car up for
Old Aug 23, 2010 | 06:32 AM
  #45
roger22's Avatar
roger22
You want more neg camber up front versus back on most rwd cars. you can easily run -2.5 to -3.0 up front and no more than -2.0 in the back.
Old Aug 23, 2010 | 07:36 AM
  #46
betamotorsports's Avatar
betamotorsports
Default Front roll Stiffness
Another Mark Ortiz chassis newsletter;
WHEN LOTS OF FRONT ROLL STIFFNESS HELPS, AND WHEN IT DOESN'T
The following question was forwarded to me by a correspondent who said they got it from a Formula Student/Formula SAE forum, where somebody was suggesting it should be put to me.
In the UK most of the successful hillclimb and sprint cars have a monoshock front suspension which is very stiff in roll. Examples include the Gould and Force cars, and more recently Graeme Wight Jr's Raptor design. The rear suspension is often considerably softer in both bounce and in roll. As a consequence the cars often corner on three wheels, with the inside front lifting. Why is this a successful method when all of the suspension/chassis technical books suggest that weight transfer results in a loss in overall grip due to the non-linearity of the tyre?"
We have debated this topic in the amateur paddock and have come to the conclusion is that these technical sources are generally correct for tyres which are already up to temperature. However in a hillclimb or sprint the tyres are initially cold, so the grip gained by tyre temperature increase may outweigh the loss in grip through loading up the outside tyre.
Furthermore the hillclimb tracks are often very heavily cambered so cornering on 3 wheels may improve car stability and tyre contact patch. My analogy would be the stability of a table on any uneven floor; stability can be achieved by 3 good points of contact.
I have added A/R bars to my OMS in order to stiffen the car in roll, particularly at the front. My OMS 1100 has conventional independent suspension all round with Koni double adjust dampers. Attached is a photo at an Aintree sprint showing the inside front just lifting. The car feels better with the A/R bars and takes sweeping corners better than before. I am convinced that I can lean on the car much more now in corners.
First of all, it is vital to recognize that having a lot of front roll resistance, relative to the rear, does not increase overall load transfer.
It increases front load transfer, and decreases rear load transfer, and the total remains essentially unchanged.
Increasing overall roll resistance does not increase load transfer either. It just reduces roll, and, accordingly, camber change. It is true that stiffer settings tend to heat tires faster, and more, because the tires experience more dramatic load changes as they go over bumps.
Whether more heat helps the tire depends on the compound. In general, tires intended for long runs are designed to heat up and get tacky. Tires intended for short events such as sprints, hillclimbs, or autocross often use compounds that are tacky at room temperature. The Hoosier tires used by Formula SAE teams I have worked with use the same A25 compound for the slicks and for the moulded rain treads: the dry tires use a rain compound, and consequently work well when moderately cold. They do get hot as they run, but they don't benefit much from it.
It probably makes good sense to use heat-insensitive compounds for short events, if for no other reason than to give the driver a car that doesn't change dramatically in the course of a run.
Whether they are heat-sensitive or not, tires generally do follow accepted theory as regards load sensitivity of the coefficient of friction, cold or hot: the coefficient of friction does decrease as normal force increases; a pair of tires make less force the more unequally they are loaded.
Consequently, a setup with more front roll resistance, relative to rear, will be tighter (have more understeer). This tends to be a good thing in sweepers, and a bad thing in tight turns. Not only do most drivers prefer a looser (more oversteering) car in tighter turns, but cars tend to get tighter as turn radius decreases, especially at really small radii, as seen in FS/FSAE events.
This is partly due to "off-tracking": the rear tires track inside of the front ones in a tight turn, even when running at a significant slip angle, and track outside of the fronts in a large-radius turn when running at a slip angle. Even at steady speed, as on a skidpad, the driver must apply substantial power in limit cornering, just to overcome tire drag. Assuming rear drive, when the rear tires are tracking inside of the fronts, the drag force from the front tires creates a pro-understeer (outward to the turn) yaw moment, and so does the propulsion thrust from the rear tires. When the rear tires track outside the fronts, the effect reverses, and the yaw moments from drag and thrust add oversteer.
Again assuming rear drive, a car also tends to get looser in conditions requiring heavier throttle application: corner exit; hill climbing; high speed turns. This results from the "traction circle" effect: the tires can't make as much lateral force when they are being asked to make longitudinal force.
Uphill, this effect is partially countered by rearward load transfer resulting from gravity, but generally a powerful car will be looser uphill than on level ground. This explains why, in the old days, people put dual rear tires on hillclimb cars.
Finally, if the car has any form of limited-slip differential, or a spool, there is a "locked axle push" effect when cornering, and this becomes more pronounced in smaller-radius turns.
This explains why autocross cars, and especially FS/FSAE cars, don't want a front-stiff setup, while hillclimb cars do, and cars for full-size road courses generally fall somewhere in between, depending on aero properties. FSAE events are run in parking lots. There is little climbing or descending involved. There are no sweepers. The courses are designed to keep speeds very low, in the interest of safety.
The last FSAE car I drove has roughly 57% static rear weight, give or take about 1% depending on driver weight. It has equal size tires front and rear. Ordinarily, one would expect a car like that to have some oversteer even if it were set up to lift a front wheel. But on the turn radii used in FSAE, that doesn't happen. The car has to be set up so rear-stiff that inside rear wheelspin is a problem. When you are cornering near the lateral force limit, you can't throttle-steer; the inside rear spins, and the outside rear stays stuck. That's with a Gleason-style limited-slip. The inside rear can't transmit enough torque to lock the Gleason. Earlier cars, with less rear percentage, would lift the inside rear off the ground on the skidpad.
Any attempt to get more inside rear loading resulted in excessive understeer.
The cars also use considerable static negative camber at the front, and considerable caster, so that the front wheels corner at more favorable camber than the rears, or at least the outside front does.
Typical skidpad sizes for testing full-size cars are 200 or 300 feet diameter. FSAE skidpads are 50 feet in diameter at the inside. A good car can pull around 1.3g lateral acceleration. The car is at its steady-state lateral force limit, at a speed of about 25mph.
These cars should be loose in a sweeper. I can't tell you from experience whether they are. We have never run an FSAE car anyplace where there was a sweeper.
Finally, we should note that this whole discussion applies to rear-drive cars, and that when we speak of greater or lesser front-stiff roll resistance distribution, we are speaking in relative terms. A given design will need a more rear-stiff setup when used for autocross than when used for hillclimbing or full-size road course work, but that does not necessarily mean that all autocross cars are more rear-stiff than all hillclimb cars, irrespective of all other factors.
Old Aug 23, 2010 | 08:00 AM
  #47
Zazz93's Avatar
Zazz93
+1 on Roger's settings, with zero toe. Should be a good starting point.
Old Aug 23, 2010 | 01:33 PM
  #48
scotts300's Avatar
scotts300
Don't Hoosiers and similar comps want as much camber as possible? i.e. more than -2.0 in the rear?
Old Aug 23, 2010 | 05:41 PM
  #49
roger22's Avatar
roger22
Nope, run less than -2.0 in the rear with Hoosiers also...
Old Aug 23, 2010 | 06:57 PM
  #50
Z1 Performance
Former Sponsor
Not necessarily - it's driven by lots of factors not
the least of which is spring/wheel rate and out back the
Diff setup plays a huge role
More is not always better
Old Aug 23, 2010 | 09:37 PM
  #51
Dcdylan's Avatar
Dcdylan
Thanks for the flurry of responses guys. Picked up a pyrometer today for 150 bucks, not sure if that's a good deal or not, but seems like a damn good investment. Going to try 2.0 camber in the rear and 3.0 up front as a base point. Then fine tune it with my new gadget along with tire pressure as well .
Old Aug 24, 2010 | 05:44 AM
  #52
roger22's Avatar
roger22
Too much neg camber in rear diminishes grip past a certain point.
Old Sep 23, 2010 | 05:02 PM
  #53
pro_350z's Avatar
pro_350z
Good Idea
Old Oct 6, 2010 | 03:21 AM
  #54
fairlady rasir's Avatar
fairlady rasir
I LIKE this.
Old Oct 26, 2010 | 05:25 AM
  #55
mhoward1's Avatar
mhoward1
items added
Old Oct 26, 2010 | 08:56 AM
  #56
Zazz93's Avatar
Zazz93
Just got back from a trackday at Big Willow and aggressive camber settings didn't work (2.6 in the rear). The temps ran 40+ degree difference from outside to inside (130'ish - 152 - 172 <similar right and left>) On the brakes the rear was everywhere and it was nearly impossible to trail-brake effectively. The tires were worn and a rock hard street compound but it was clear to me the car didn't like that aggressive of a setting at this track. I think I lost a second or so a lap in actual speed a couple of seconds or so in confidence.
Old Oct 26, 2010 | 09:27 AM
  #57
scotts300's Avatar
scotts300
What about the front settings and toe?
Old Oct 26, 2010 | 09:48 AM
  #58
betamotorsports
At the Big Track you should run an asymetric alignment with the rears being the most important. I've never run more then -2.5 on the back of any car at WSIR and the wider the tire the less camber you'll need. You'll also want to eliminate as much scrub as possible so toe in front should be close to zero (slightly out) and rear toe about 1/16" in.
A very general set of 350Z alignment numbers for the big track (assuming 285/30-18s all around):
OVERALL
Ride height - Left side - 1/4" lower in front compared to rear. Right side - 1/2" lower in front compared to the rear
Track - 1" wider in front then rear.
FRONT
Toe - 1/32 to 1/16" out.
Caster - +9 even on both sides.
Camber - 2.5 negative LF / 1.5 negative RF
REAR
Toe - 1/16" in.
Camber - 1.5" negative LR / 1" negative RR
Old Oct 26, 2010 | 10:17 AM
  #59
scotts300's Avatar
scotts300
OVERALL
FRONT
REAR
Toe - 1/16" in.
You are hard core. I get my car aligned up to twice a year unless I change something, certainly not for each change in track venue. I just added a touch of toe out in the front (previously 0), but bumped up the camber both front and rear and maxed the caster to just under 9 on both sides. I kept slight toe in for the rear. The two main tracks I run, Thunderhill and Laguna Seca, are CCW, but we get down to BW twice a year which is CW.
We'll see on Monday if the changes are beneficial for the Hoosiers.
Old Oct 26, 2010 | 10:26 AM
  #60
betamotorsports
Originally Posted by scotts300
You are hard core.
Not anymore. Years ago when I raced Spec Racer Fords we had a morning qualifying alignment setup and an afternoon race alignment setup for the big track and the differences were in 32nds of an inch.
