GPS timer/Data acquisition...jump in and give out a shout for your unit
#41
You can pretty much buy anything that runs windows Mobile. This includes the HP Ipaq, Dell Axium, or any cheap WM hand held. Some have GPS, some don't. If they don't just buy a $50 GPS Bluetooth Puck.
#42
on
Ok. I am planning on borrowing an old phone from someone to test the program if I like it and then will buy a used one on Ebay. Regarding the GPS Puck, I am looking at Qstarz BT-Q818X. It sells for about ~$60 on Ebay.
Howard, I see that you have guages with rpm readings. Were you able to record that info since you have the hardware version of RaceChrono?
I am assuming the smartphone version does not support any of this and only supports lap timings and possibly Brake/Throttle indicators based on GPS positions?
#43
on
I also found a very good review where the reviewer explained about segments and how to generate a map of the track. He was talking about an AutoX lap but I am assuming it will be the same for a HPDE track as well.
What about the other Full Systems like Traqmate and Racepack? How do they generate the track layouts?
#44
No, RC can record just about any OBII data. You just need an OBII reader like OBIIKey. It's bluetooth and feeds right into RC. It includes brake and throttle position, RPM, Sensor readouts and just about anything else your OBII reads.
#45
on
What about THIS?
ELM327 Scanner OBDII Car Diagnostic OBD2
I only found one on Ebay. Did not find any stores that I can order and get shipped faster. I am planning on getting stuff ready to use it at the track this coming weekend.
EDIT
Found another one called ScanTool, but it's expensive --> HERE
EDIT
#50
on
I was also researching on Traqmate in parallel and it's amazing how expensive the system is. I was under the impression that the Traqmate Complete would give me all the inputs and not just the track times. But it looks like I was wrong. Everything needs an add-on and I am starting to doubt the cost-to-benefit ratio of this system for weekend warriors or intermediate track drivers. It might be a different story for people who are really serious and do stuff like Time Attacks, Races etc.
What I found (a lot of folks might already know)
- Traqmate Basic ($699) --> Gives basic lap times
- Traqmate Complete ($999) --> Adds an additional display module that shows laptimes in car
- Traqmate Data --> You need this component ($129) in addition to Basic or Complete to get inputs like RPM, Brake, Throttle etc.
- Traqmate Traqstudio --> a $200 software package to generate video overlays on to your videos
However, there are some really good things about Traqmate for people who can reap the benefits. For instance its GPS supposedly works at 10, 20, 30 Hz.
I am somebody who typically drives in third or second fastest groups depending on the track and something like this would be a total waste of money. It might be better to buy more seat time and get better
#51
traqmate has a few things going for it
1) Software - I still think it's the best software analyst package out there.
2) User base - There are a lot of users you can swap data with and compare to.
I am hoping that TM will unlock their format so it can be compared to other systems like DLI, Racebox, and others have done but I don't think that will be any time soon.
#52
on
Howard I searched online and did not find anything called OBIIKey. Was it a typo?
I found something called OBDKey. Is that what you were referring to? Also, this unit is very expensive ~$140 and it ships from UK. I wonder what is the difference between that and the cheaper unit (~$60) I found on Ebay.
OBDKey vs ELM327
I have been searching online and local places but did not find any place where I can order something and get it shipped overnight or a 2-day delivery. Does anyone know of any websites in USA to get the Bluetooth OBDII scanner?
OBDKey vs ELM327
#53
Sorry, yes it's OBDKey
You can also get the ELM327 for $40 bucks
http://www.easy-motorcycle.com/bluet...less-p-81.html
Others that have been tested are
Car-Pal BT
Alpha-Bid's Bluetooth OBD-II reader
but they have been slower and skipped readings compared to the ELM and OBDKey
As far as getting before the weekend...sorry I don't know.
Car-Pal BT
#55
on
Autobahn Country Club - TRACK MAP for RaceChrono
Does anyone have a track map for Autobahn Country Club in Joliet, IL, USA?
http://www.autobahncountryclub.net/
I need both SOUTH and FULL courses
#56
Just a question, did you build your own setup or order it complete? I now carry the complete setup.
http://www.mh-motorsports.com/products.htm
#57
on
hey, I answered your question on the other forum. I can also help out more if needed, just ping me.
- Dell Axim X51V on Ebay
- QStar GPS
- OBDII Key from Easy Motorcycle store link that you provided a few posts up
#58
We got the 10 hz 818XBT up and running and now even have customized software for the equipment build.
#60
yeah, we had to change the software to get the 10 hz reliable. Good news is we also went ahead and also changed the data logging to handle upcoming 20 hz, and 100 hz units coming soon.
