How to properly wire in a master cut-off switch?
Old Sep 19, 2010 | 06:53 AM
nkohler's Avatar
nkohler
Default How to properly wire in a master cut-off switch?
I have been searching and finding a lot of threads on other cars, but no specifically the Z. For the track guys out there, how have you done yours?
Old Sep 19, 2010 | 02:44 PM
laze1's Avatar
laze1
I will take some pics next weekend....mine looks pretty simpler..it is spliced inline with the battery positive cable....mounted on the dash on the passenger side...
Old Sep 19, 2010 | 06:18 PM
nkohler's Avatar
nkohler
Thanks Laze,
Lots of people talking about if you just cut the battery it does damage to your alternator. Plus I didnt know if the Z33 had more electrical crap that I didnt know about.
If anyone else has done this I would appreciate the input!
Old Sep 20, 2010 | 03:05 AM
laze1's Avatar
laze1
This car was built by the PO 2-3 years ago, but I am not aware of any Alternator problems at all.
Mine is wired this way:
Battery Positive terminal wire is routed thru a hole in the bulkhead created for this purpose into the passenger compartment>
that wire is connected to a standard cut-off switch, then routed back to the engine compartment thru a hole created for this purpose>
then the +wire runs it normal/factory path...Appears to be pretty straight forward
Note: My car is still using the factory Key switch
I plan to remove the key over the winter, and this may cause some significant rewiring...as I am sure there are several interlocks/theft prevention devices to work around.
Originally Posted by nkohler
Thanks Laze,
Old Sep 20, 2010 | 03:53 AM
JasonZ-YA's Avatar
JasonZ-YA
maybe i can help with your pic laze?
Taken from this thread: - noticed it on post 5.
https://my350z.com/forum/8653962-post2.html
-J
Old Sep 20, 2010 | 03:56 AM
JasonZ-YA's Avatar
JasonZ-YA
Where are you guys buying the master cut off switches???
any perks to the ones you have?
-J
Old Sep 20, 2010 | 06:48 AM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Any race parts supplier sells them. I have the longacre one, bought it from discoveryparts.com
Old Sep 20, 2010 | 07:25 AM
GT-Rob's Avatar
GT-Rob
do you not need to cut off the alternator as well? I've read some guys getting the 2-post switch and wiring the battery to one post, and alternator to the other, so it cuts them both off.
Perhaps specific race series rules define it better.
Old Sep 20, 2010 | 04:50 PM
laze1's Avatar
laze1
-J
Old Sep 21, 2010 | 06:31 AM
nkohler's Avatar
nkohler
So yours basically is in line with the positive power from the battery? Seems simple enough. Looks like there is some conflicting opinions as far as if this is safe to the alternator, however these are all different cars. I was hoping to get some Z33 specific info.
Has yours been tested by any safety inspectors?
Old Sep 21, 2010 | 01:28 PM
Nackers's Avatar
Nackers
http://www.pegasusautoracing.com/pro...asp?RecID=1464
Thats what I have. They have a diagram how to do the wiring. It's not great or anything, but you should get the idea.
BTW, haven't installed it yet. Thats going on Friday.
Old Sep 21, 2010 | 06:16 PM
laze1's Avatar
laze1
Inspected by NASA-SE, current NASA log book...raced regularly...
However, NASA is NOT SCCA, so who knows what a through inspection will show?
BTW: just purchased the car, but not aware of any electrical problems...
Old Sep 21, 2010 | 07:35 PM
nkohler's Avatar
nkohler
I will probably snag up the one at Pegasus. The kicker is if I can find the proper power wires for the alt and ignition system. I wish I knew someone local more familiar with the Z's electrical system to get some guidance. I have the FSM so I hope that helps.
Old Oct 18, 2010 | 04:37 PM
nkohler's Avatar
nkohler
Hoping to tackle this job soon. Could anyone lend some help in showing me which alternator wire I should be tapping into?
I got this switch from Pegasus, here are the directions. Yeah pretty straight forward I know, but I am just unsure what alternator wire I need.
Here are the instructions:
http://www.pegasusautoracing.com/pdf...structions.pdf
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
Depravity
Oct 1, 2015 04:49 PM
Beater350z
Sep 9, 2015 03:36 PM
