spring rate
Old Feb 28, 2011 | 08:50 PM
JDMStanced's Avatar
JDMStanced
Default spring rate
sorry for making so many threads
i wonder..how much increase in spring rate for tightening up certain amount of preload?
i have stance gr+ true type
thanks
Old Mar 1, 2011 | 02:44 AM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Not sure what you are asking but be aware that if you increase your spring rates too much, you will overspring the dampers and they will not be able to do their job effectively. A big change in spring rates will require a revalve of the dampers.
Old Mar 1, 2011 | 07:52 AM
betamotorsports's Avatar
betamotorsports
Pre-load has no effect on spring rate. It only effects travel.
Old Mar 1, 2011 | 08:14 AM
terrasmak's Avatar
Tightening up preload does not change spring rate
EnjukuRacing
Sep 30, 2015 06:55 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
