KaBlamO
Old Jun 19, 2011 | 04:11 PM
laze1's Avatar
laze1
email sent
Originally Posted by bkleeman
It's in the Northeast, but yes I have a couple VQ35DEs ready to go, rebuilt and 0 miles. We had 3 in normal rotation in the DE race car but have now moved to the HR so they're just sitting in the shop.
PM or email me: bkleeman@gmail.com.
Old Jun 19, 2011 | 06:30 PM
mhoward1's Avatar
mhoward1
I was sorry to see that on Friday. Overall though I am glad you guys were OK.
Old Jun 20, 2011 | 07:17 AM
betamotorsports's Avatar
betamotorsports
Gentle hands on the shifter. Its not a drag race, take your time, and let the internal detents guide the sifter. The most common way to blow an engine on the race track is with the shifter.
Old Jun 20, 2011 | 07:23 AM
mhoward1's Avatar
mhoward1
For me it's always shift with an open hand and a gentle push. The shifter usually knows where to go, but will go other places if you TELL it to.
Old Jun 20, 2011 | 07:58 AM
terrasmak's Avatar
That sucks man, i've done 4th to 3rd on accident. Never 5th to second.
Old Jun 20, 2011 | 11:32 AM
betamotorsports
I've done 4th to 3rd in a Spec Racer Ford. Had to write a $3,800 check for a replacement engine (the car was rental) when I got back to the pits. The team got it installed overnight and I made the race.
Old Jun 20, 2011 | 05:30 PM
laze1's Avatar
laze1
So, how hard is it to install a RevUp engine in place of the DE...I heard they was a fairly simple way to do that...i.e. to disable the Intake cam gizmo??
Old Jun 20, 2011 | 05:31 PM
03threefiftyz's Avatar
03threefiftyz
Might as well do an HR....
Old Jun 20, 2011 | 05:33 PM
laze1's Avatar
laze1
how hard is that to do???
Old Jun 20, 2011 | 05:55 PM
03threefiftyz
Don't know, but I have been tossing around the idea of backdating/updating my BSP car with an HR. I was hoping you would do it first...then I could learn the foibles, etc of the swap .
Old Jun 20, 2011 | 06:17 PM
laze1's Avatar
laze1
Actually I should ask "how expensive is it?"
Old Jun 20, 2011 | 06:20 PM
03threefiftyz
I've seen the motors for sale in the 1500-2000 range, but you will need the trans, ecu, etc as well. You would also need the "bump" hood.
Old Jun 20, 2011 | 07:55 PM
Fixxxercask's Avatar
Fixxxercask
I've heard the RevUp's are much easier because most of the parts outside the engine are interchangeable. I believe you need a new ECU though and possible harness.
I've also heard the HR's are way more complex and difficult. RevUp or replacement DE would be the way to go.
Old Jun 20, 2011 | 10:40 PM
terrasmak's Avatar
Or you can use a Rev up motor and swap back to Non-Rev cams to run it as a normal DE. You would just run the timing cover and cam gears off your old motor.
Old Jun 20, 2011 | 11:01 PM
Zazz93's Avatar
Zazz93
Rev up block, DE heads... That way you get some better rod bolts and some help against that happening again (not a whole lot but some help). I'm pretty sure the block and head are fully compatible, but I dont think the DE cams fit in the Revup heads without other mods.
How do the rules account for "Frankenstein" engines?
Old Jun 20, 2011 | 11:20 PM
terrasmak's Avatar
The cams will bolt in, all that is needed is a plug to block off the extra cam sensor off the back of the head. I would have to search around, but i think GTM makes them.
Old Jun 21, 2011 | 07:12 AM
Zazz93's Avatar
Zazz93
Don't forget the front timing cover caps, exhaust timing magneto, and ECU/harness stuff. Rev-up short block and DE head just seems easier.
But I think a straight HR transplant would be nice (but costly), ECU, Harness, engine and exhaust peices. Being a race-car there are some considerations that get left behind and simplify things a bit. But I'd love to talk to someone who's done it.
Old Jun 21, 2011 | 07:32 AM
  #38
thekinn's Avatar
thekinn
I thought that NissanSport did the HR swap in a track car. Sorry I don't have details - but maybe this will shake someone's memory that does have the details.
Old Jun 21, 2011 | 10:08 AM
  #39
ADMAN's Avatar
ADMAN
Oh, that sux, dude. I remember when I popped the motor in the Momentum test vehicle in Carolina.
At least you were able to make it back to the pit. Glad your driver was okay. Could have been ugly...
P.S. Hey, Len...was that you at the Meadows Mall this weekend???
Old Jun 21, 2011 | 10:22 AM
  #40
terrasmak's Avatar
That was me, had to swap out some tools and buy a couple more. Then some shopping for maternity clothes with the wife.
