lets see your autoX/Track wheel and tire setups
Old 11-08-2014, 10:37 AM
  #221
guitman32
guitman32's Avatar
Originally Posted by crZydave
New setup is 17X9 Enkei RPF1 with 255/40/17 Maxxis RC1 tires. Saving a bundle on tires.
Originally Posted by SE5spd
RC1 are rad.
How rad are they? Can you give a comparison? Based on their advertising they sound like they are gunning for the NT01 crowd, while making them look like a full slick. Very curious...
Old 11-10-2014, 06:11 PM
  #222
SE5spd
SE5spd's Avatar
RC1 engineer is the NT01 engineer. Scotts300 posted a review between RS3/RC1 in norcal track section. Go check it out.
Old 11-10-2014, 07:36 PM
  #223
guitman32
guitman32's Avatar
Cool thx ill go check it out
Old 11-11-2014, 10:01 AM
  #224
scotts300
scotts300's Avatar
https://my350z.com/forum/wheels-and-...re-review.html
Old 11-12-2014, 04:14 PM
  #225
guitman32
guitman32's Avatar
Appreciate the link and the reviews, thanks for sharing your experiences.
Old 08-09-2016, 11:59 AM
  #226
LoneStarG
LoneStarG's Avatar
I recently sold my G35 sedan and purchased a 2006 350z. I want to begin AutoX with several of my friends that currently run and I want a seperate wheel/tire AutoX setup that my DD wheels. A friend of mine is offering me 17X8 Enkei RPF1's with 255/40/17 RS3 tires.
Not knowing the 350Z yet or having much AutoX time, is a 17x8 with a 255 too small perform well for our cars?
Old 08-09-2016, 12:21 PM
  #227
travlee
Master
travlee's Avatar
Received 9,059 Likes on 6,523 Posts
several of my buddies used to run 17's to autox and drift on... you will have no issue, and tires will be cheaper
Old 08-09-2016, 04:20 PM
  #228
LoneStarG
LoneStarG's Avatar
Thanks travlee. I am not so much concerned with the wheels being 17's. As you said, I like the price of the tires! I am more concerned with the wheels only being 8" wide and running 255's. I have read through this thread and most people are running wheel/tire combo's much larger than that. Will the car over power an 8"/255?
Old 08-09-2016, 04:25 PM
  #229
travlee
Master
travlee's Avatar
micvelo will be a good resource, maybe he will chime in
Old 08-10-2016, 04:36 AM
  #230
eye-5
eye-5's Avatar
Once you become competitive, your class will dictate wheel size. If you run SCCA C Street, you need the width & offset wheel your car came with from the factory + or - 1" in diameter. Most Z's came with 18x8 front and 18x8.5 rear.
If you already have some mods and you fall into STU, I'd go as wide as you can. 10.5" is what most of the competitive guys are running.
Old 08-10-2016, 06:49 AM
  #231
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,261 Likes on 2,319 Posts
Thanks, Trav, but no, I don't qualify to chime in here. Do not use my car for either discipline so not going to talk theory over reality.
^^^ This. What theory I will talk is about reading the rules. Doesn't matter what the hot setup is if it bumps you a class (or two).
For reference:
Street (Stock): Page 72, 2016 Solo II Rules
Pertinent paraphrase (substantiating eye-5's remark):
"13.4 WHEELS
Any type wheel may be used provided it complies with the following:
A. It is the same width as standard and as installed it does not have an offset
more than ±7.00 mm (±0.275”) from a standard wheel for the car. The
resultant change in track dimensions is allowed.
B. Wheel (rim) diameter may be increased or decreased 1” from the standard part."
STU (Street Touring): Page 82, 2016 Solo II Rules
Old 08-10-2016, 08:21 AM
  #232
03threefiftyz
03threefiftyz's Avatar
I would imagine at least a few of the STU guys are on 11's. The newer gen street tires are a little wider than there predecessor's and work a little better on the larger wheel.
