Battery Kill Switch
Old Jan 15, 2012 | 01:57 PM
laze1's Avatar
laze1
I have removed everything up front..no Misc covers exist anymore.
Yes, the battery is in the Trunk, in a Sealed and vented to the Outside plastic battery Box from Summit Racing. It is bolted thru the truck floor...
Removing all the crappage in the engine makes maintenance and engine swaps easier!
Note: I now run a OEM Airbox...needed the Points...(this pics show a CAI) still have it is somebody wants it cheap.
Note 2: This pic show the car's wiring when the Battery was in the front...relocating the Battery to the rear DID NOT Require changing the Alternator Kill switch wiring...just the Hot side battery wiring.
Originally Posted by Fixxxercask
Thanks Laze!
Do you run without the plastic trim pieces that cover up by the windshield wipers/master cylinder and battery cover? It doesn't appear they are on in the pic. Your battery is in the trunk though too isn't it?
Old Jan 15, 2012 | 02:19 PM
laze1's Avatar
laze1
A few more Pics..might be helpful
Ask me any question...pm as needed...glad to help
Old Jan 15, 2012 | 02:21 PM
laze1's Avatar
laze1
now back to "Beer & Football"
Old Jan 15, 2012 | 02:29 PM
laze1's Avatar
laze1
Yepper, the fire system runs off a chemical reaction...not external power.
Hard to see in this pix, but there is a small cylinder that holds a catalyst that when mixed with the stuff in the big cylinder, shiate flys outta the outlets
C
Pull the "Oh Shiate" handle and that starts the reaction...
Originally Posted by mhoward1
The kill switch should cut all power. The fire systems run off the pressure of the tank.
Old Jan 15, 2012 | 02:33 PM
Fixxxercask's Avatar
Fixxxercask
Thanks again Laze!
...and yes, back to beer and football.
Old Jan 15, 2012 | 02:34 PM
Fixxxercask
Oh, another quick question. Is that a sock over your power steering reservoir? I think know why. Mine spews crap every where over time. Is that why?
Old Jan 15, 2012 | 03:11 PM
laze1's Avatar
laze1
Yes, that is a official NISMO Racing Sock...LeMans approved
It prevents boiled/steaming powers steering fluid from spewing all over the engine compartment.
I now run Redline PS Fluid and don't have that problem any more...so no official NISMO Racing Sock any longer
I am too Laze1 to vent the PS to a catch bottle..
Old Jan 15, 2012 | 03:22 PM
laze1's Avatar
laze1
This wiring model would likely start a Fire!!!!
The Battery and Alternator would both be putting 12volt at a pretty high amperage on the same wires/circuits...all the time...not a good idea...
umm...don't do that!
I am no Engineer...but not a good idea
Couldn't you just use a 2 pole switch? I would think you can take whatever and all wire/cables going to the positive terminal of the battery and crimp them all together, which they pretty much are already and run that to one pole of the switch and the other pole to ground obviously.
Would that not work?
The only exception I think would be if you had some type of fire suppression or any other safety feature running on power then you could wire that to bypass the kill switch.
Old Jan 15, 2012 | 03:41 PM
Fixxxercask
LOL Thanks! I will look into the 4 pole switch.
Old Jan 15, 2012 | 04:39 PM
2TH PWR's Avatar
2TH PWR
laze1, your car is awesome.
Old Jan 15, 2012 | 04:52 PM
laze1's Avatar
laze1
Thnx! more Pix if you check them out
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://static.pbsrc.com/flash/rss_slideshow.swf" flashvars="rssFeed=http%3A%2F%2Ffeed161.photobucket.com%2Fal bums%2Ft204%2Flaze1one%2FLFR2%2Ffeed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="http://photobucket.com/redirect/album?showShareLB=1" target="_blank"><img src="http://pic.pbsrc.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s161.photobucket.com/albums/t204/laze1one/LFR2/" target="_blank"><img src="http://pic.pbsrc.com/share/icons/embed/btn_viewall.gif" style="border:none;" /></a></div>
Old Jan 15, 2012 | 04:55 PM
laze1's Avatar
laze1
how about this one:
http://nasa-se.com/
Old Jan 16, 2012 | 02:09 AM
mw9's Avatar
mw9
thanks for sharing the pictures
Old Jan 16, 2012 | 06:30 PM
kart14's Avatar
kart14
Thanks guys, much appreciated. The attached wiring diagram may help as well.
Attached Thumbnails Battery Kill Switch-picture-2.png   Battery Kill Switch-picture-3.jpg
Old Mar 14, 2012 | 04:43 PM
kart14's Avatar
kart14
So I finally got around to installing the 6 pole kill switch. Was a pretty easy install so I figured I better post up a few pics for others considering this.
-Moved the battery to the back of the car.
-Ran a cable from the battery to the drivers side dash/window(kill switch) and then to the OEM battery location.
-Spliced into the ignition wire (black/red), at the connector (E119) on the left side of the steering column, and ran it to terminial Z on the kill switch and back.
-Installed a patch cable from the alternator side of the battery cable to the W terminal on the kill switch.
-Installed the resistor on the other side of the w terminal and then patched it to ground.
Here's the installation instructions, 350z wiring diagram, and a few pics.
Attached Thumbnails Battery Kill Switch-picture-5.png   Battery Kill Switch-m1110003.jpg   Battery Kill Switch-m1110004.jpg   Battery Kill Switch-4430_wiring_instructions.jpg
Old Mar 14, 2012 | 04:45 PM
kart14's Avatar
kart14
The rest of the pics
Attached Thumbnails Battery Kill Switch-m1110006.jpg   Battery Kill Switch-m1110007.jpg   Battery Kill Switch-m1110009.jpg   Battery Kill Switch-m1110013.jpg   Battery Kill Switch-m1110014.jpg
Old Mar 14, 2012 | 07:19 PM
Fixxxercask
Thanks! This is very helpful and I will for sure be using this layout.
Old Mar 15, 2012 | 04:01 AM
  #38
2TH PWR's Avatar
2TH PWR
Awesome work.
I'm a ways off needing this but when the time comes I will be checking it out for sure.
Old Oct 13, 2019 | 10:57 AM
  #39
etkms's Avatar
etkms
Hi guys, I know this thread is MANY MANY years old! so I am sorry for bringing it up. But I am about to install a kill switch on my car and been looking for instructions and I don't know why all the wiring diagrams are so confusing to me! I have a Longacre 4pole switch as seen here http://www.longacreracing.com/produc...l---4-Terminal
I want to obviously kill the battery and alternator. The wiring I am seeing so confusing! with jumpers, ignition and what not. Why can't I cut the battery + side, extend the wire to one side of the kill switch, then use another side from the switch back to the battery? And for the alternator, why can't I do the same? The way I am thinking about it in my head is like me installing the kill switch inline with both the battery and alternator, all I am doing is extending the wires to have the kill switch in between the 2? is this not right? will this be a problem if I do it as such?
Thanks
Old Oct 13, 2019 | 11:21 AM
  #40
laze1's Avatar
laze1
Thanks
Are you using a 2 pole or 4 pole disconnect switch? You gotta have a 4 pole!...
