Autox Alignment
Old Jan 16, 2012 | 01:35 PM
silents1ick's Avatar
silents1ick
Default Autox Alignment
hey guys, i have been autox'n stock Z for over a year now and decided to upgrade some stuff this year and just looking to find some info for Alignment set and suspension set up... i did use the search option and found lots of helpfull info but not exactly what i was looking for...
here are is what i have on the car...
Cusco zero2 coilovers
Cusco rear Traction arms.
Ichiba rear Control arms
Ichiba Front control arms
Hotchkis F&R rear sway bar.
Enkeis 18x9.5F and 18x10.5R +15 all around with BFG KDW's 265/35 frnts and 275/35 rears
I found some competition setups but thats are too much for me... since i daily drive my car.... i understand there is no such thing as competition/street setup... its either or... i m trying to look for a set up that a compromise between autox and daily use...
Any help would be appriciated. Thanx in advance...
Old Jan 16, 2012 | 01:37 PM
RMichael's Avatar
RMichael
photos would be nice
Old Jan 17, 2012 | 08:49 AM
silents1ick
i have allota pics thats i havnt gotten achance to upload it yet but i will do it soon...
Old Jan 17, 2012 | 05:39 PM
acke15's Avatar
acke15
What exactly are you asking for help on?
Old Jan 17, 2012 | 06:25 PM
steidz's Avatar
steidz
You can probably run -2 degrees of camber front and -1.5 to -2.0 rear without to much inside tire wear. Buy a tread depth gauge and measure your tires and keep an eye on the wear. I would try zero toe front and rear and see how your car tracks down your roads. If the car likes to follow every groove in the road, a little toe in will help.
Old Jan 17, 2012 | 11:11 PM
terrasmak's Avatar
I would start with lifting the car up a bit, looks a little bit low to be able to handle. Next, are you looking for a Daily drive and weekend play toy alignment or weekend play toy alignment. There is a big difference in settings between the two
Old Jan 19, 2012 | 03:58 AM
silents1ick
Lookin to get daily driver and ability to have fun on weekends... I don't mind lil tire wear..
Old Jan 24, 2012 | 10:38 AM
silents1ick
Going to get alignment done tomorrow... Any suggestions guys?
Old Jan 24, 2012 | 04:55 PM
Voboy's Avatar
Voboy
i would check those ichiba arms to see if the bushings have torn or not... replace them with some quality arms if possible. they are known to fail
Old Jan 25, 2012 | 12:42 AM
terrasmak's Avatar
-2.5 front camber with 0 or 1/16 toe out, then autocross i would run around -1.5 rear camber (better contact patch for corner exit) with 1/16 to 1/8 toe in.
Roadcourse i run a bit more rear camber to carry corner speed.
Paul.
Oct 16, 2015 07:34 PM
Depravity
Oct 1, 2015 04:49 PM
RiujinZero
Sep 25, 2015 01:19 PM
