New NASA Class for 2012: Spec Z
Old Mar 3, 2014 | 10:41 AM
  #1541
laze1's Avatar
laze1
Scott...How do you really feel?
Originally Posted by scotts300
No, NASA CCR states:
DRY WEIGHTS (no driver, no fluids)
2501-3000 lbs
1.500” x 0.120” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM
1.750” x 0.095” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM
1.750” x 0.120” ERW
3001-4000 lbs
1.750” x .120” Seamless Alloy (4130), Seamless mild steel (CDS Mechanical) or DOM
No ERW allowed.
This is SEPARATE from the minimum post-race weights of the SpecZ (with driver) for each of the 3 engine types. The rules end up being written around the weight of the driver, which is silly in my opinion, and the weights are too high after the update last year - again my opinion. We are building a bunch of low horsepower pigs.
Cheers.
Old Mar 3, 2014 | 11:46 AM
  #1542
scotts300's Avatar
scotts300
Old Mar 3, 2014 | 02:48 PM
  #1543
russell@z1's Avatar
russell@z1
Vendor - Former Vendor
Allow an inexpensive (but effective) plenum spacer on the DEs and drop the weight (particularly on the HR). The mandatory KW spring rates are not enough for a ~3450 lb car. We'll be pushing for this for 2015.
Old Mar 11, 2014 | 06:41 AM
  #1544
Palmettogasman's Avatar
Palmettogasman
Wouldn't the maximum HP limit of the DE (258) have to be increased? I assume the plenum spacer adds a few HP.
Allowing more HP for the older cars or running a restrictor in the HR cars would allow the weights to be adjusted downward if that's the goal.
Old Mar 11, 2014 | 08:00 AM
  #1545
scotts300's Avatar
scotts300
Yup, that's Russell's point I believe. Add some easy and cheap HP to the DEs to bump up the HP by 8-10, THEN allow the HRs to be a bit lighter.
Old Mar 11, 2014 | 10:12 AM
  #1546
B Esquire's Avatar
B Esquire
I would also support and push for this. Easy bolt on power will not effect price of the build significantly, and leveling weights is a great idea! These cars needs to be faster in my opinion. If someone wants super cheap, they will go race spec E30 or spec Miata. They are going to choose spec Z to spend a little more money to go faster.
I have been pushing to allow more weight reduction from the beginning, cheapest and easiest way to get some more speed, not to mention making the car handle less boaty on the soft springs.
Old Mar 11, 2014 | 12:28 PM
  #1547
russell@z1's Avatar
russell@z1
Yes we say allow 10-15 more HP on the DE cars and drop the HR min weight down 75-100 lbs. Both changes are super easy and inexpensive. Again the required KW springs simply aren't up to the task of supporting a car that is nearly 3,500 lbs at the start of a race.
Old Mar 12, 2014 | 05:36 AM
  #1548
Blurvision's Avatar
Blurvision
How many of the racers are running ABS delete? Any feedback or tips?
Old Mar 12, 2014 | 12:57 PM
  #1549
russell@z1's Avatar
russell@z1
We have deleted ABS on our 07 Nismo and installed a proportioning valve. We will try to put together a write-up and parts list / install kit soon.
Old Mar 12, 2014 | 03:11 PM
  #1550
npr350z's Avatar
npr350z
So what's the verdict on the wavetrac diff? I heard the heat kills them, or is that rumors? Or is everyone just running the nismo diff
Old Mar 13, 2014 | 08:52 AM
  #1551
Blurvision's Avatar
Blurvision
Thank you for the feedback, are the metric T's something you will be selling?
How do the lap times compare?
Old Mar 13, 2014 | 11:57 AM
  #1552
laze1's Avatar
laze1
Correct...do not use the WaveTrac...it is a POS under race conditions....
NISMO Diff is the way to go!!!
Note: there is a Version 2 Wavetrac..that is supposed to be better. But I would avoid it as well.
Old Mar 13, 2014 | 12:09 PM
  #1553
npr350z's Avatar
npr350z
Mmmm good to get some feed back, thankyou.
Old Mar 13, 2014 | 12:36 PM
  #1554
laze1's Avatar
laze1
I had a diff cooler with fan pack on it running Motul , and it failed within 3 race weekends
it would go open, lock...not unlock, go open...stay open, lock...repeat
Old Mar 13, 2014 | 12:50 PM
  #1555
scotts300's Avatar
scotts300
I ran a NISMO for years - LOVED it. When I switched to (V1) Wavetrac, I abhorred it, as the set-up for that diff seemed so different than what I came to love on the NISMO. When it failed on me, Wavetrac rebuilt it at $0 cost to said "V2". I've been on the V2 for 2 years now, and must say I like it more than the NISMO I had. I think it's smoother overall faster than the NISMO - it's certainly quieter! I change the fluid often (same as the NISMO) - every two weekend events or so - and don't have any gripes now on the Wavetrac. If I had to do it all over again - oh wait I am! - I'd build again with a Wavetrac (I did).
Old Mar 13, 2014 | 01:12 PM
  #1556
laze1's Avatar
laze1
WOW
For the record I had a V1...and it was terrible
Old Aug 29, 2014 | 01:56 AM
  #1557
Taereek43's Avatar
Taereek43
I just want to wish our racers and time trialer's a safe and fun weekend at the East and West Championships. I should've been there at Road Atlanta, but couldn't make it. It's nice to see 8 cars this year at East this year. I'll be seeing you guys live on the net. Let's see who can get 1:3x.xx's.
Old Aug 29, 2014 | 02:47 AM
  #1558
mhoward1's Avatar
mhoward1
Like.
Old Oct 14, 2014 | 11:23 AM
  #1559
KNS Brakes's Avatar
KNS Brakes
Gotta few sets of Hawk Race pads to unload otherwise they go back to Hawk
DTC70 - 2 sets
DTC60 -1 set
At cost+ shipping
Old Nov 19, 2014 | 02:55 PM
  #1560
scotts300's Avatar
scotts300
Quote:
Originally Posted by bkleeman View Post
I just got off the phone with Nissan have some clarifications for you guys:
Suspension kits must be purchased from Nissan. They will be stamped/marked in some fashion. Despite the KW part number that was on our shipping, they are not standard as they appear - the spring rates are 800/600 as the kits are assembled specifically for Spec Z. The shock valving was left up to KW to assure they are appropriate to the spring rates so those may not be standard either. Bottom line is - get the kit from Nissan directly.
Pricing I was told is $2599 for the Shocks/Springs. $185 for each swaybar.
That's $2969 total for the entire suspension kit.
Brian
Latest pricing (!?): $3602
Spec Z shocks/springs: $3189
Shocks
• Front Left Shock Part# E6110-SZ350
• Front Right Shock Part# E6111-SZ350
• Rear Shock Part# E6210-SZ350
Springs
• Front Spring Part# 54010-SZ350
• Rear Spring Part# 55020-SZ350
Coil-Over kit
• Front/Rear Part# 5600S-SZ350
ARBs $413
Anti-Roll Bars
• Front Progress Part# 54611-SZ350
• Rear Program Part# 56230-SZ350
Wavetrac Diff: $1400 ($300 higher than previously quoted)
Has anyone documented the "markings" on the SpecZ kit so one would know it was sourced through Nissan? I did not see any marks on my kits, but I also didn't really look.
