Street /Auto Cross Setup
Old Mar 10, 2012 | 11:47 AM
sgreb's Avatar
sgreb
Default Street /Auto Cross Setup
Hi Guys,
I am pretty new to this forum but I search it all the time to find common questions. Im sure this is on here but I have been able to find more detailed specifics.
I need to get a new set of rubber and, was seeking some recommendations on what tires would be best suited for Street The majority of driving will be on the street but I really like having the grip of great tires. I don't mind spending some money to get something reasonable.
My questions.
1-what would be the best tire for me? (currently looking at bridgestone RE11, considering the ADVAN, and star spec.) Are they are with more grip?
2-I was thinking that I may be able to increase my tire width to gain more traction can you put 245F and 265R with no problems?
The Car
06 350Z Rev up
6Spd
Old Mar 10, 2012 | 12:10 PM
sgreb's Avatar
sgreb
I wanted to add one this. I have discovered the Michelin Super Sports. Really just looking for the best and I don't mind spending a few coins.
Old Mar 10, 2012 | 06:31 PM
SE5spd's Avatar
SE5spd
Are you on stock wheels?
Look at RS3s
Old Mar 10, 2012 | 08:24 PM
terrasmak's Avatar
Wheel details are needed, a lot of us run larger than 265's .............. up front.
Old Mar 11, 2012 | 09:58 AM
dubi2087's Avatar
dubi2087
I run 265/35/18 super sports all around for daily driving and autocross. Love this setup. The super sports last longer and have more grip than the ad08.
Old Mar 11, 2012 | 07:34 PM
PDX_Racer's Avatar
PDX_Racer
I don't know if the stock '06 wheels have the same "engineering" to them that the '03-'05 Track model wheels do, but if you don't have an '06 track model (18F/19R) then you can go with the OEM Track model wheels.
While they're marked the same size (18x8F/18x8.5R), the Track model wheels are actually 5/8" wider at the bead lip than they are at the measuring point at the base of the bead.
Old Mar 11, 2012 | 11:52 PM
SE5spd's Avatar
SE5spd
I dont
one day ill run 315s up front
Old Mar 12, 2012 | 05:43 AM
sgreb's Avatar
sgreb
Hi Guys, thank you for your replies.
I am running the stock 18"s that came with the car.
its a 06 touring.
Thank you for your help guys.
Old Mar 12, 2012 | 06:45 AM
terrasmak's Avatar
I would order a set of 245/40 and 265/40 Hankook RS3's. That will be perfect for your needs and wheel sizes.
Old Mar 12, 2012 | 07:25 AM
sgreb's Avatar
sgreb
so i can run those tire sizes without upsetting my traction control or causing rubbing?
Also I am unfamiliar with Hankook tires in the performance game. I thought they were really budget focused. I would consider them if they are great performance tires, but i don't mind spending a little more
Old Mar 12, 2012 | 08:34 PM
terrasmak's Avatar
They are probably the fastest street tire on the market right now, and have multiple track records set with them in Time Attack. VDC will be very happy with my suggestion.
Old Mar 12, 2012 | 08:47 PM
cow's Avatar
cow
The RS3s are the current badass tire of choice. They're also cheaper than many of their competitors. I ran an event this past weekend after mounting the tires the previous Wednesday &, once they were slightly heat cycled, absolutely loved every second of driving on them.
I've previously raced on RE11s & loved those too, but they're not worth the extra money vs the RS3s as the grip was equal.
Old Mar 12, 2012 | 09:28 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
R-S3's all the way. As said, 245/40 and 265/40 (if they make that size) not sure.
Old Mar 14, 2012 | 05:34 AM
sgreb's Avatar
sgreb
ok thank you for your replies. The RS3 are available in those sizes however I am having a very hard time finding them in Canada.
Does anyone have any good tire shop recommendations in Upstate NY, our the GTA in Ontario? I have no problem ordering off Tire Rack, but would rather go to a local shop if they can keep prices somewhat close.
Old May 28, 2012 | 07:38 PM
MrZ1987's Avatar
MrZ1987
I am in the market for new tires for autox too. Will 245/40 and 265/40 have a lot of sidewall flex and have any problems that I would not have if I just run the stock sizes for a 03 track?
Old Jun 30, 2012 | 02:15 PM
n8dog11914's Avatar
n8dog11914
That will work. I had the stock V1 Touring rims so I actually went with a neutral setup running 245/45 rear with 245/40 fronts.
Old Jul 1, 2012 | 12:11 PM
eracer's Avatar
eracer
Anyone try running 285/35 on the track V1 rear wheels? If so what did you run in the front? Driving impressions?
Old Jul 1, 2012 | 12:31 PM
terrasmak's Avatar
285/30 front and rear is a popular autocross setup on stock wheels, for the road course I wouldn't go wider than 255 for a roadcourse
sales@czp
Sep 23, 2019 03:30 PM
_bit
Oct 2, 2015 07:49 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
