350Z Gutted/Weight Loss Pics NASA TTC Prep
Old Jun 25, 2014 | 04:56 AM
l30thelion's Avatar
l30thelion
Originally Posted by MonkeyMagic72
You should consider Tomei Ti exhaust and y pipe. They are super light, which help you shave about 40lb over stock.
My car is at 3,200 lbs with me in it and 1/4 tank of gas. I feel it is already fast. I can't imagine how fast the car would go weight in at 2,940 lbs.
I actually considered the Tomei Ti specifically for the weight savings, just don't have the budget for it right now. If you look at some of their other products, including the headers and test pipes, you could save more! Seems the OEM Cats are very heavy (based on the awesome job others have done showing weights of various parts, thx!).
Stock cats weigh 26.4lbs:
https://my350z.com/forum/8518753-post39.html
Tomei claim their test pipes weight 8lbs
Saving 18lbs, not bad at all, and not too pricey.
Supposedly the full Tomei setup would save around 61lbs, I wonder if you could run their exhaust w/o the muffler for even more weight savings?
Old Jun 25, 2014 | 05:10 AM
l30thelion's Avatar
l30thelion
Originally Posted by 2TH PWR
Wow, my car is fairly stripped and yours is far lighter than mine.
You can gut the supports out of the hood to save another 7 or 8 lbs.
I thinik you saved a lot of weight gutting the doors, which I'm about to do.
Nice, will look into the hood supports, need to get weight out of the front, thanks for the heads up, appreciate any advice to better the car, specially the weight distribution/ballast, need to optimize that.
The doors are a good bang for buck weight wise, definitely.
The car was weighed a few times at the NASA event at Sebring, after the warmup/practice session w/ 17x8 lightweight wheels w/ 1/8 tank of fuel, it weighed 2981, I weigh 165, so the car weighed 2726, which was way lower that I expected, I panicked a bit, was under by 50lbs.
For the first timed session I switched to 5zigen 17x10s (which are 10lbs heavier than the 17x8s for a total of 40lbs) and filled the tank some and was later DQ'd for being underweight by 8lbs!!
Finally I filled the tank up completely and fortunately weighed 2952lbs (over by 12lbs) after the 3rd session. At least its simple, I just have to make sure the tank is full before going out every session and know I'll be over by 11-12lbs after.
Old Jun 25, 2014 | 05:15 AM
l30thelion's Avatar
l30thelion
How much weight can you save, if you were gutting out each door? I am consider gutting out the all the internal of the doors, such as power window, glass, and unnessarry hardware, but keep the plastic door panel for clean look. I think saving weight on the doors are very critical, because removing front and high weight at the door helps bring back the weight balance of the car closer to OEM 53:47 weight ratio or better. I track my car, but I am not ready or brave enough to remove all the front dash and plastic door panel. I can live with removing headliner and carpet.
The glass alone is 10-11lbs, I'm not sure how much exactly but I would say between 20-25lbs for sure, maybe even more. The plastic door panel doesn't weigh much but not sure if you'll be able to put it back on w/ the rest of the stuff gutted.
Old Jun 25, 2014 | 10:24 AM
bealljk's Avatar
bealljk
excuse me if I'm breaking any of the sauctioning body rules as I don't know them - but can you move your battery to the trunk? have you considered a lighter weight battery? I know Braile makes a killer battery, maybe look into EarthX. It's a colorado company $350 will buy you a 3.5lbs battery that has 600 pulse cranking amps (I disregard cold cranking amps because if it's 'cold' than I'm not in the car, I'm in my truck).
http://earthxmotorsports.com/shop/etx36c/
You may have mentioned above removing your AC compressor/condenser, which will improve weight(obviously) and cooling allowing better flow through your radiator. What about your coolant tank and windshieild fluid tanks? can you put those in your trunk? The OEM strut bar is rather heavy (and high) can that be swapped out with a cusco? This may be on the extreme side but can you core-out your OEM aluminum crash bars? I think I cut 8lbs by stratically coring holes in each bump. Did you remove the dampening weight and/or rear wiper assembly in the hatch lid - it's not much but every pounds counts and starts to add up!
Old Jun 25, 2014 | 10:41 AM
l30thelion's Avatar
l30thelion
Current battery is Odyssey PC680-P, I believe it weighs 16#, but at 3.5# the other battery you mention sounds good. But at that point relocating may not be worth it?
Windshield fluid tank is gone completely, nice idea about the coolant tank relocation. I still have windshield wipers and motors since I still drive to events.
OEM Strut bar would probably count as a mod so would take points, will have to look into that though!
OEM crash bars removed already =)
Hatch is gutted pretty good, need to add lexan to cut more.
Great ideas, thx!
Old Jun 25, 2014 | 11:44 AM
RAYoRAY's Avatar
RAYoRAY
I'm a huge fan the NASA TT Classification system, especially the dyno re-class method, and feel it is the best way to be competitive.
I've chosen to run the car in TTC now w/ a dyno re-class of 2940lbs/235hp:
+10 R6 255/45/17
+ 2 Springs
+ 3 Shocks (Truechoice Phase IV DA Koni)
+ 1 Upgrade Diff
+ 2 StopTech Calipers
Total: +18 TTC
I'm thinking of going to stock calipers and running A6s, that would probably be better use of points as A6s would give me 1 second in lap times vs the R6s ......stoptechs are probably not worth a second.
Here's my info for when I ran TTD and some other info regarding running the Z based on dyno re-class (forgive me if I ramble on a bit, hopefully someone will this information useful):
Dyno Reclass TTD* @ 3195lbs/235hp
+ 7 for the (*)
+10 R6 225/45/17
- 4 225mm Tire
+ 2 Springs
+ 3 Shocks (DA Koni)
+ 1 Upgrade Diff
Total: +19 TTD
Adjusted Wt/Hp Calc:
3195lbs/235hp = 13.59 + .8 (for tire < 255mm) - .05 for weight = 14.34....pretty close to 14.25 min.
Copied from another thread that I posted way back when: https://my350z.com/forum/9559719-post5.html
Yes, the Wt/Hp reclass is the most flexible to way to class a car and in most cases the most competitive.
The nice thing about the NASA Classification system is the various options you can play with. I believe the Z can be very competitive in TTD/TTC and probably TTB (a member on here, Fixxxercask, is gunning for TTB at Nationals). Also want to clarify that any car can be dyno re-classed (mine is stock)...no engine mods or swaps or anything is required....simply get a dyno done (be very careful to follow the exact procedure and fill out proper form) and send an email out to the National director.
Here are some actual reclass configurations for the Z based on Wt/Hp:
3440 lbs / 240whp / TTD / 245mm
3370 lbs / 235whp / TTD / 245mm
3195 lbs / 235whp / TTD* / 245mm
3260 lbs / 240whp / TTD* / 245mm
3360 lbs / 260whp / TTD** / 245mm
2940 lbs / 235whp / TTC / 255mm
3005 lbs / 240whp / TTC / 255mm
2890 lbs / 240whp / TTC / 255mm (must end up in TTB though)
3190 lbs / 306whp / TTB / 265mm
Not sure if this sort of info is sticky worthy but since NASA TT and PT use the same classification system it could be helpful to others as they look to compete in TT/PT to have reference info like this and what others have found to be good setups for TT/PT competition. Maybe in the road course modification guide thread?
As someone who plans to making the jump from HPDE4 to TT, this was a big help. Looks like I could be much more competitive with that dyno reclass.. Gives more room for points in TTC class.
If I do a reclass and end up in TTD, do I have to limit my mods and be required to stay in TTD? or can I add 20+ points to go back in TTC?
Expect PMs in the future!
Old Jun 25, 2014 | 11:55 AM
l30thelion's Avatar
l30thelion
If you are re-classed down to TTD, you can go up as many classes as you want based on the points system, means you could use up to 39 points and still be in TTC.
BUT, ensure that you are within the "Adjusted Weight/Power Ratio" for the class you are in (TTC 12.00:1 min).
Old Jun 25, 2014 | 12:14 PM
RAYoRAY's Avatar
RAYoRAY
How come the above can be classified in TTD even though the power/weight ratio is under 14?
Old Jun 25, 2014 | 01:16 PM
l30thelion's Avatar
l30thelion
Wt/Hp Ratio is a little more complex than that, see Appendix B of the TT Rules for Adjusted Wt/Hp Calculations: http://www.nasaproracing.com/rules/time_trial_rules.pdf
In my particular case, when I ran TTD, this is the Adjusted Wt/Hp Calc:
I may be crazy but I love the complexity of the TT rules, you can play w/ so many variables, this is what I ponder sometimes for fun:
Old Jun 25, 2014 | 02:16 PM
MonkeyMagic72's Avatar
MonkeyMagic72
Someone should build an app or software, where you can fill in all these variables, so you can play with the results to get an edge over other racers in choosing to stay in or step up in race classes.
Old Jun 25, 2014 | 05:44 PM
RAYoRAY's Avatar
RAYoRAY
Ahh. I get it now. Lots of little things that you can play with your setup. Nice organization!
Old Jun 26, 2014 | 07:26 PM
hndumafia's Avatar
hndumafia
Leo, was nice to meet you at Sebring this past weekend. I was the guy with the other 350z running in hpde. I can't believe you still drive to the track.. I need to step up my game!
Old Jun 27, 2014 | 06:51 AM
l30thelion's Avatar
l30thelion
Yooooo!
I only drive to the track out of necessity, hoping to make the car a trailer queen soon
I take all my tools and 4 big *** tires in the car (almost).......I actually drive to the events w/ a tire in the rear which doesn't allow the hatch to close completely, looks really idiotic. I also never wash the car, I mean its been years since it was washed, seriously. But my philosophy is the only thing that matters is what the clock says!
Old Jun 27, 2014 | 07:31 PM
SE5spd's Avatar
SE5spd
2725 with or without driver and full tank? this is crazy. If my car weighed sub 3k itd be SO much quicker.
Old Jun 27, 2014 | 08:45 PM
l30thelion's Avatar
l30thelion
Without driver, w/ very little gas, and lightweight wheels. But yes, it is much faster than before! Every track is different but every 80-100lbs is probably ~1sec per lap, saves rotors/pads, fuel, engine, easier on suspension, list goes on.
Would be great if SpecZ allowed for a car like mine at least weight wise, then I could cage it and run TT and SpecZ.
Old Jun 28, 2014 | 11:23 AM
2TH PWR's Avatar
2TH PWR
Ah ok. mine is a lot closer then. Mine is about 2875 with no fuel and no driver and with a 4 point roll bar. All OEM glass.
Old Jun 28, 2014 | 04:06 PM
350zjason350z's Avatar
350zjason350z
Know it all
what are you guys running for rims? size, width, brand
Old Jun 28, 2014 | 08:02 PM
  #38
l30thelion's Avatar
l30thelion
TTD: Kosei K1 TS 17x8 / 225 Hoosier R6s
TTC: 5zigen 5Zigen FNO1R-C 17x10 ET25 / Hoosiers 255R6s
Enkie RPF1 would be nice, but pricey.
Old Jul 16, 2014 | 06:16 PM
  #39
2TH PWR's Avatar
2TH PWR
My car is now 2815 with a full 6 point cage and all oem glass.
But that is on an empty tank and with no driver of course.
full race weight is 3115 lbs.
Old Jul 17, 2014 | 05:45 AM
  #40
l30thelion's Avatar
l30thelion
Nice! Did you update your build thread, so you went from 4-pt to full cage and dropped 60lbs?
How much weight did the front part of the cage add?
My car is at the shop getting a cage, sucks getting a bunch of weight put back in but safety first.
I'm hoping I can offset most of the cage weight by running less gas and some more gutting.
Now I need to get a steering wheel and adapter, any suggestions?
