Welp...The Z got its roll cage finished
Old Nov 3, 2014 | 09:47 AM
Chugg's Avatar
Chugg
Default Welp...The Z got its roll cage finished
Well here we go, my Z finally got its 6 pt roll cage installed for the 2015 season. I am going to be running SPEC-Z for NASA mid-a once I get my comp license. The cage turned out really good, i'm pretty stoked. Its got new Sparco seats and 6 point harnesses. Had a few hiccups, but who doesn't?
Well any way, here are the pictures. Let me know if you guys have any questions!
I just got it back late last night, When I get more pictures I will update further. If you want to see anything specific let me know!
These are the Eye hooks used to mount the harnesses. I love these clip on Sparco 6pt's...amazing.
Here are the two for the sub straps
Rear Mounting plate
Old Nov 5, 2014 | 12:41 PM
RAYoRAY's Avatar
RAYoRAY
Looks good!!
Old Nov 5, 2014 | 12:57 PM
pyshin's Avatar
pyshin
What diameter/wall tubing did you use?
Old Nov 5, 2014 | 08:54 PM
terrasmak's Avatar
I would cut the single bar that goes across the rear down tubes. Then run the single diagonal or turn it into an X back there.
Old Nov 6, 2014 | 06:36 AM
Chugg's Avatar
Chugg
Why is that? Do you think it would be stronger with the X?
Old Nov 6, 2014 | 06:59 AM
terrasmak's Avatar
An X would triangulate the area , much stiffer.
Old Nov 8, 2014 | 10:33 AM
guitman32's Avatar
guitman32
Nice work. What was your rationale behind where the rear downtubes meet the chassis?
Just curious because that area is where I have seen the most variance in cage construction.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
