My STU build
Old May 4, 2015 | 04:45 PM
  #61
Flier129's Avatar
Flier129
No comment on money I had in the BSP car ...
Yeah, I could only imagine 6-7 is about what I was expecting for ~95% STU build, good to hear that from you guys.
The actual car and build of a 03-05 Z isn't much different than my damn miata. It's the on-going wear items that puts it ahead though. Tires, especially tires. The speed difference on track is the biggest allure for me.
Old May 4, 2015 | 05:11 PM
  #62
03threefiftyz's Avatar
03threefiftyz
Not even scratching the surface...I had custom double koni's, motons and penske's on the BSP car at one time or another ...
Old May 4, 2015 | 09:39 PM
  #63
joshua350z6841's Avatar
joshua350z6841
great build. love the info an the chase video.
Old May 5, 2015 | 03:29 AM
  #64
Glenn350zHR's Avatar
Glenn350zHR
I wish I had just 6-7 into my build. The MCS double adjustables alone were half that.
Old May 7, 2015 | 06:25 PM
  #65
SirMichael's Avatar
SirMichael
I noticed you said you run no sway bar in the rear. I have heard of the miata guys that do this.
Any particular reason?
How do you like not having the sway bar? I have considered the same considered the amount of oversteer I currently have. I'm hoping the r-comps Im waiting on showing up will help that.
Old May 7, 2015 | 06:41 PM
  #66
Z1NONLY's Avatar
Z1NONLY
The car hooks up better out of corners without a rear sway bar. (At least it does with the spring rates I'm running.)
Old May 7, 2015 | 07:12 PM
  #67
SirMichael's Avatar
SirMichael
I'm curious how the difference in rates compares between true coilovers and spring perch version.
I run a true coilover at 784f and 672r or atleast thats what I'm getting converting 14k 12k rates. Maybe Ill give it a shot for the event at the of the month. I am curious if it will help keep the inside wheel in contact with the road surface.
Old May 8, 2015 | 03:41 AM
  #68
03threefiftyz
Holy crap...a 12k with true coil? Prepare to drive looking out of the side windows instead of the windshield. Off-hand...that is the equivalent to running a 1400-1500lb spring in the OEM location.
Old May 8, 2015 | 05:42 AM
  #69
SirMichael's Avatar
SirMichael
Yes the rear end is very loose.
Honestly, the more I look into the spring rates I'm not entirely sure. I need to send them back to Zeal and have them rebuilt at the end of the season. I bought them from USANA Z and he told me they were 2k higher spring rates than original. I have since found that they came in 12k/10k (hard) or 10k/8k(soft) depending on where they were ordered from. Vivid racing has the 12k/10k version only. I have sent him a message to try and clarify this.
Never the less yes it is very prone to drifting as it is currently set up. My sways are currently set full stiff up front and full soft out back. (hotchkis)
Not trying to hyjack your thread, apologies. Maybe I should start another one to discuss setup.
Old May 20, 2015 | 11:28 AM
  #70
Z1NONLY's Avatar
Z1NONLY
I broke a motor mount at ZdayZ and it appears that I can use mounts made of any material.
J. Any engine or transmission mount is allowed provided it attaches only
to the original mounting points, does not relocate the engine/transmission
(other than incidental to changes in compliance material),
and weighs no less than the OE mount. All components between the
engine/transmission and the mounting structure are considered to be
part of the mount assembly.
Am I reading this correctly? Metal motor mounts are OK?
Old May 20, 2015 | 02:57 PM
  #71
NA&CH's Avatar
NA&CH
Great chatting with you OPP this past week. Its great rattling your brain.
I have the Z1 Motorsports 350Z/G35 Urethane Motor Mounts. Just checked and they are out of stock Sorry. I can check to see if my shop has my oems you can have?
Chris
Old May 20, 2015 | 04:59 PM
  #72
SirMichael's Avatar
SirMichael
It sounds like the weight thing might get you. I recall seeing that the solid motor mounts where lighter.
Old May 21, 2015 | 04:49 AM
  #73
DmanG281's Avatar
DmanG281
A little piece of well placed lead tape may be in order here.........lol
Old May 21, 2015 | 05:12 AM
  #74
Z1NONLY's Avatar
Z1NONLY
Chris
Do you know how many miles were on them before they were removed?
Old Jun 7, 2015 | 07:43 PM
  #75
jbh1's Avatar
jbh1
Default Re71 or Rival S
So I just finished running the pro solo in Texas, super fun format! The car is new to me, got in in November and put ohlins dfv, 10.5" rfp1, front sway and 285 rs3 v2 and camber arms and alignment, that's it so far. The rs3 are approaching 50% but still in their prime. Most of the STU class was running the new RE71r. I was the only 350z, finished 7 of 11. I talked to Brian Peters who was there running a mustang and he said I am probably giving up a second on the 47 second course by not running the new tires which is huge. Several others there said the same thing. Has anyone tried the RE71R or new Rival S on our cars and have a preference? I will get a set in the next few months.
Old Jun 9, 2015 | 05:40 PM
  #76
SirMichael's Avatar
SirMichael
Everyone around here seems to like the RE71Rs, haven't really heard anything about the Rivals
Old Jun 10, 2015 | 04:49 AM
  #77
hajwoj's Avatar
I quickly looked and noticed that neither tire came in 285. Do you go to the 275 size and give up tire width?
Old Jun 10, 2015 | 06:13 AM
  #78
steidz's Avatar
steidz
The RE71 and Rival are noticeably better than the rs3, Well worth giving up the 10mm, and the re71 at least is a fat 275.
Old Jun 11, 2015 | 10:04 AM
  #79
hajwoj's Avatar
Hmm, thinner sidewall & smaller diameter = running out of revs. Have to ride the limiter longer or upshift into 3rd .....and then downshift while sawing at the wheel.
Old Jun 11, 2015 | 11:10 PM
  #80
terrasmak's Avatar
Always look up full specs on tires, kinda odd the 275/35-18 RS3 is wider than the 285/35-18 , but you do have a slightly shorter tire with the 275.
