Hr ac delete options
Old Oct 3, 2015 | 07:33 AM
CKdevil's Avatar
CKdevil
Default Hr ac delete options
For those that have deleted compressor please chime in. Options I see is run shorter belt or fabricate bracket to run OEM routing (have not seen any kits out there).
Thoughts? Any feedback would be appreciated.
Old May 31, 2017 | 02:20 PM
GodISmE's Avatar
GodISmE
No one here has done it yet?
Old May 31, 2017 | 03:34 PM
bealljk's Avatar
bealljk
I' a DE - so I don't know how applicable this is? I blitzed mine a few years back in the name of weight savings. I believe I have a pretty good heat/cold weather tolerance but damn - sometimes it gets hot! so if you think you'll miss your AC than you will.
What is your intention for the AC delete?
Old May 31, 2017 | 10:10 PM
GodISmE's Avatar
GodISmE
Track car.
HR is different and needs a shorter belt. Just wondering what size would be best to have the tensioner still work properly... and if there is additional work required.
I got a reply in the vq35hr section though from dkmura, just waiting for more details about drilling and tapping the tensioner.
Old Jun 21, 2017 | 02:39 AM
CKdevil's Avatar
CKdevil
GodISme did you ever get details about ac delete from dkmura please pm me any hardware changes that were needed
Old Jun 21, 2017 | 06:05 AM
iideadeyeii's Avatar
iideadeyeii
Run a string around the new configuration
Bring tied string to autozone
They can match out a belt for you.
Bring belt home and test
Return for correct size if off
PROFIT?
Old Jun 21, 2017 | 06:12 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Here's the same info I sent previously: issue #12 of Nissan Sport Magazine detailed the HR swap. By drilling and tapping the central belt tensioner, I found that a Gates Micro-V belt (part #K050505) would work for deleting the a/c. You will need to check the belt tension manually before drilling the tension arm. This is NOT a factory authorized procedure and let the modifier beware.
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
