Lexan for carbon hatch
Picking up a carbon hatch without glass next week. Just want to know what people are being for a back window. Are you buying a sheet and trim to fit, do you form it for the slight curve in the glass? Then the most important part, strap, are you running a single or double strap and what material is typically used, aluminum or steel.
Master
i had a buddy that had plexiglass put on his, eventually it cracked around every screw hole, but his was flat not formed. i know they make them formed, but quick search (le tired) i just found one overseas
http://www.plastics4performance.com/...ar-screen.html
Senior Super Moderator
Don't buy Chinese!
6 inch cawk is my fave!
I have oem glass on mine... It's like 15lbs as opposed to whatever lexan is but I could tint normal glass. My hatch without glass was 22lbs.
Sorry I couldn't be more helpful. I was going to buy a sheet of lexan and trim to fit but after reading up on it I decided real glass was the way to go for me...
I also dont use struts for fear of breakage.. And my fitment sucked. After much adjustments its ok...
O and it leaked till I went crazy on the inside with some silicone.
http://www.autoall.com/350z-lexan-tr...ear-smoked.htm
Might take a peak at this one as well. I was concidering getting some polycarbonate sheet and just cutting my own, then getting a rear window applicae molding to install with it for a stock look. The side windows will be a little more difficult. Either way good luck.
You should let me know how this turn out.
I was contemplating going this route, carbon hatch with lexan and the whole 9 yards. But then i re consider since thats almost 100lbs out of the rear and it woul throw off the weight ratio that is already messed up on my car lol.
How about the strapping of the window part, any experience?
koren
South East Marketplace
06-06-2016 09:07 PM
ukraini9mofo
11-05-2015 06:28 AM
h2ographics
Vendor Group Buys
11-02-2015 04:37 PM
