where to buy 6pin or 8 pin headlight connector?
Hey guys,
Has anyone found someplace that sells the either the 8 pin or 6 pin headlight connectors for our cars?
I'm converting from 03-05 halogen (6pin) to 06-08 depot HID's (8pin). Ideally I'd like to find a 6 pin to put on the new depos so I'm able to switch back to my old lights if needed for some reason. But converting the car side to 8pin would also be acceptable.
Worst case scenario, I cut the connector off my stock lights and splice them onto the DEPOs.
Thanks!
Thanks!
the worst case doesnt sound to bad if the pins are in the right location and if you have heat shrink and soldier gun to make it look good and last long. im sure any electronics store should have simliar connectors that you can make work although i believe that there is a diy on this site that just says to cut the plastic
BlanQshot
Nov 1, 2015 07:32 AM
