Front wheel bearing time
Old May 16, 2016 | 09:33 PM
terrasmak's Avatar
Default Front wheel bearing time
Had a hub failure up front, OEM bearing is still good, but it's time to replace them both. What options do I have, so far I see Beck-Arnley , Timken and of course OEM. There are cheaper ones available, does anyone know who makes the cheaper bearings ? I obviously don't want something that is going to break again , this one wiped out my front caliper , so add an extra $300 to the cost if this failure.
Old May 16, 2016 | 09:37 PM
rustyschopshop's Avatar
rustyschopshop
From what I have seen either Centric, Timken or Oem. Rockauto has great prices on timken. Centric I have seen on a couple of our vendor sites. Need not to explain Oem I hope....just kidding terra.... lmao
Old May 16, 2016 | 09:39 PM
rustyschopshop
Oh btw sorry to see how bad the damage was on this one. I have a suspect bearing that I think I am really going to be replacing soon after seeing this.
Old May 16, 2016 | 09:41 PM
HRMoneyPit's Avatar
HRMoneyPit
I'm just very curious how. I've never seen such a thing
Old May 16, 2016 | 11:34 PM
armt350z's Avatar
armt350z
Slicks seem to be the culprit if the track page is any indication.
Old May 17, 2016 | 05:27 AM
Blurvision's Avatar
Blurvision
SUKCS!!! That must have felt crazy, have to get towed off I would assume? Looks like bearings should be a yearly thing now.
Old May 17, 2016 | 06:39 AM
jledford's Avatar
jledford
Does anyone make Ceramic bearings for the 350Z and would they hold up better?
I know I've seen them for GTR's and other vehicles. Normally they're more heat tolerant and at the same time less rolling resistance. I used to use them when I road raced motorcycles.
Old May 17, 2016 | 08:51 AM
DmanG281's Avatar
DmanG281
from my research Timken seemed to be the choice. I keep 2 spares in the toolbox considering how cheap they are to come by for the whole assembly. echo the Rockauto.com suggestion also
Old Jul 7, 2016 | 11:39 AM
GodISmE's Avatar
GodISmE
Who manufactures the OEM ones? Is it possible to replace just the brearing?
Old Jul 8, 2016 | 03:15 AM
armt350z's Avatar
armt350z
The bearings are not readily available. They sell the entire hub. I just installed Moog hubs this past weekend and they appear on par or slightly better than OEM. Less rolling resistance.
Old Jul 8, 2016 | 06:35 AM
Blurvision's Avatar
Blurvision
I have not been able to figure out how to press out the spindle, in order to look into improving the part. Any tips? Looks like the end is pressed in a certain way to make in non-serviceable.
Old Jul 8, 2016 | 07:57 AM
Flier129's Avatar
Flier129
Mother of god..... adding this to the list of paranoia.
I've used Timken on my track miata with great success, though that doesn't carry as much weight since it's not a Z. Still, runs r-comps with lots of load!
Old Jul 8, 2016 | 09:11 AM
GodISmE's Avatar
GodISmE
Right, so this is it, is it? Only the whole assembly can be bought?
http://www.partsgeek.com/catalog/200..._assembly.html
Old Jul 8, 2016 | 02:04 PM
armt350z's Avatar
armt350z
Yes.
Old Jul 9, 2016 | 07:11 AM
GodISmE's Avatar
GodISmE
@armt, Timken are not available in Europe, are they? Where did you buy your Moog?
Old Jul 9, 2016 | 08:13 AM
R3belzBRN's Avatar
R3belzBRN
U can order timken hubs from rockauto.. Shiping is not that expensive to outside usa.. And btw u can Use 468994566799271 for 5% dicount code.
Old Jul 9, 2016 | 10:29 AM
eye-5's Avatar
eye-5
I'm putting in some Timkens today. Sucks that happened to the OP.
Old Jul 10, 2016 | 04:26 AM
armt350z's Avatar
armt350z
I got the moog's off amazon.de but I can no longer find the ones I bought.
Old Aug 7, 2016 | 11:34 PM
GodISmE's Avatar
GodISmE
Guys, is it normal that the abs sensor had to be moved after replacing oem front bearing with Timken's? The mechanic that did the job on my car said that they had to do this:
draft
Suspension
May 8, 2016 06:06 AM
Kellys7118
May 5, 2016 02:38 PM
cbb7855
Apr 26, 2016 08:40 AM
