URGENT: Spring rates for Nordschleife: 1300-1350kg car weight
I think you will have oversteer issues with your 14/9 setup but there are other things you can do to correct that but I would start with different springs
Ways to Correct Oversteer
Lower front tire pressure
Raise rear tire pressure
Stiffen front shocks
Soften rear shocks
Raise front end
Lower rear end
Install narrower front tires
Install wider rear tires
Stiffen front sway bar
Soften rear sway bar
Reduce front negative camber
Reduce positive caster
Stiffen front springs
Soften rear springs
Ways to Correct Understeer
Raise front tire pressure
Lower rear tire pressure
Soften front shocks and stiffen bump
Stiffen rear shocks
Lower front end
Raise rear end
Install wider front tires
Install narrower rear tires
Soften front sway bar
Stiffen rear sway bar
Increase front negative camber
Increase positive caster
Soften front springs
Stiffen rear springs
Soften rear shocks
Raise front end
Lower rear end
Soften rear springs
Stiffen rear shocks
Lower front end
Raise rear end
Z-Noob
Feb 19, 2004 04:12 PM
