Caster/Camber/ ABS & VSD setup advice
Old Oct 17, 2016 | 06:46 PM
jcj02's Avatar
jcj02
Default Caster/Camber/ ABS & VSD setup advice
Yes I have been reading and just trying to get a starting point. NCM track and autocross setup, majority autocross.
03 350z track
Rears 10.5" 275/35/18
Fronts 8" 235's
Spc upper arms
Billstein pro springs kit
Anti sway
Wondering how I should possibly set my caster camber when telling my guy at shop tomorrow.
Also was debating just having him disable the vsd and abs as it's having an issue anyhow. Thoughts above criticism please. As I'm just throwing this out there quickly.
I haven't been in car yet to track so I just needed a helpful starting point and info as I get adjusted to it and make changes to my feel.
Thanks!
Old Oct 17, 2016 | 06:49 PM
terrasmak's Avatar
Start with getting on track
Old Oct 17, 2016 | 06:55 PM
jcj02's Avatar
jcj02
But he has to do alignment so just didn't know if there were any opinions on what starting point.
Old Oct 18, 2016 | 07:39 AM
dkmura's Avatar
dkmura
General & DIY Moderator
This is a pretty complicated question, so I'll simply provide a starting point:
1) ABS is a must-have IMHO. At high speed tracks, you simply cannot pump the pedal fast enough to replicate what ABS does to prevent lockup.
2) VDC (not sure what you mean by vsd?) can be easily disabled, but is useful in the wet. If there's no other choice, take it out and rely upon your car control skills.
3) Caster and camber recommendations are highly dependent on what kind of tires you are using, the rules of the class you're in and which track you are at. I'll simply say that -3 degrees in the front is a good starting point, with the rears at about -1.8 degrees for better wear at a road racing track. Learn how to use a pyrometer to better gauge how your tires are performing at the track.
Edneil Sundar
Sep 11, 2016 12:52 PM
GOE350Z
Sep 7, 2016 04:46 AM
Daserz33
Aug 30, 2016 02:44 AM
TT03Z
Aug 20, 2016 01:21 AM
Seanvelez0618
Wheels Tires
Aug 14, 2016 03:25 PM
