Sundown72 Track Car Build Thread
Ha! The OG himself!
How’s the refresh going? The car still up in KW?
I want to take car back home and up to Mosport at some point (I haven’t driven the big track since ‘08, so lots has changed) and maybe jump into a CSCS round.
If I’m headed back up there I’ll drop you a line, I’d love to see your car up close and steal all the Sasha/Mike/Eric secrets.
Just upgrade my PS cooler for track use. I have a question since you've replaced yours as well - did you keep the hard-lines that run from the cooler to the reservoir and the power steering pump? There is a small segment of hardline that runs through the front radiator support bracket and I've removed it and replaced with reinforced rubber lines. Wondering if its ok for track use. It was just easier to run a single line from the cooler to the reservoir and pump.
Thanks!
Thanks!
