The Big LSD FAQ thread (About various Limited Slip Differentials)
Old Jan 26, 2009 | 02:52 PM
  #221
Z1NONLY's Avatar
Z1NONLY
Originally Posted by Mr.Jadkowski
Z1, have you ever had any problems breaking a tire loose on a really tight corner? It seems like the quaife does a great job of keeping the tires hooked up UNLESS you still manage to break one loose, and then it just stops working until you get grip on both wheels again. Is that right?
I have stepped the the rear end out and still had it put power to the outside tire.
Here is an old vid in which I hit a cone on side "A" and decided to "play" (hange the rear-end out, over and over) on side "B". The quaife worked well the whole time. (BTW I didn't hit any cones other than the one I blew the run on.)
http://www.youtube.com/watch?v=8eHAIvfdplQ&fmt=18
If you get one of the rear tires in the air, on ice, or other near-zero-resistance situation, it will not work.
Old Feb 3, 2009 | 09:03 AM
  #222
JuJube's Avatar
JuJube
What split do you guys think best with the Cusco LSD for road racing?
60%? or 100%
Old Feb 4, 2009 | 05:42 PM
  #223
roger22's Avatar
roger22
I would go 80 or 100%...I personally have the Cusco RS 1.5 with 100%...
Also this works well with 3.90 and 4.08 gears if allowed...
Old Feb 4, 2009 | 06:57 PM
  #224
Chebosto's Avatar
Chebosto
i've had the Cusco RS 1.5 way, and current using the OS Giken Superlock 1.5 way. and ridden in cars with KAAZ and Nismo.
KAAZ = Nismo... very similar (if not identical casings) noiser, but gets the job done. adjustable lock via adjustment through the side. cheaper of the three listed here.
Slightly less noiser is the Cusco RS. The engagement on mine was quite smooth, and i drove it at 60% lock... if you're going racing, perhaps 80% or higher. lock is adjusted based on clutch plate arrangements.
The OS Giken is super smooth. no noise!! Fully adjustable on WHEN it locks and initial torque. locks to 100%. most expensive of the group...but like Kwame said. quality is there.
Old Feb 5, 2009 | 07:55 AM
  #225
JuJube's Avatar
JuJube
Thanks for the input. I appreciate it.
Old Feb 5, 2009 | 09:34 AM
  #226
betamotorsports's Avatar
betamotorsports
We've been having a discussion for a few months over on HybridZ.org regarding limited slips and yaw behavior. There's a lot of information about car setup, etc. specific to each type of differential. Its worth a read.
http://forums.hybridz.org/showthread.php?t=140642
Old Feb 6, 2009 | 01:39 PM
  #227
Chebosto's Avatar
Chebosto
thats a pretty good read John- thanks for the link.
how was it with the welded diff on the Z?
Old Feb 6, 2009 | 02:38 PM
  #228
whitebwoy's Avatar
whitebwoy
I have the Quaife. I don't know how clutch type Diffs are, so I can't offer much of a comparison opinion. Mine is super smooth though. But yes, once one wheel is having no resistance you're pretty much stuck. I have a driveway at work that I have to take sideways. And if I don't go with momentum I'm stuck. I've stopped once on it, and when I tried to move of all I heard was my tire spinning and saw smoke coming from the back. I was freaking out at first, but then I realised one tire was off the ground. (the smoke was from the tire barley touching the road and burning from it spinning so fast) I sat in the car and jumped up and down and that rocked the tire to 'touch' the ground, and I moved off. Lol!
Happened again in traffic going over a huge ditch in the road. That time I was stuck for almost 15 minutes trying to get the tire to touch the ground. Lol. I'm glad I can laugh now!
OTHERWISE... Lovely diff. Smooth and absolutely noise free. I've noticed how the car almost automatically straightens itself after doing a power slide. It's effortless.
Old Feb 6, 2009 | 02:42 PM
  #229
Z1NONLY's Avatar
Z1NONLY
....Or you could just use the e-brake to get a little resistance on both wheels and the Quafe should put more power to the tire on the ground. (because it has e-brake resistance + the ground resistance.)
Old Feb 6, 2009 | 05:40 PM
  #230
whitebwoy's Avatar
whitebwoy
Okay, NOW I feel reeelly stupid.
Old Feb 7, 2009 | 08:21 AM
  #231
betamotorsports
Fine. You set the chassis up different with a welded diff or a spool. You want the rear to rotate easily and you use left foot/trail braking to get it around and the drive out with the throttle. If you're sloppy it can get the rear tires pretty greasy by the end of the race.
Old Feb 8, 2009 | 07:57 PM
  #232
stuntman's Avatar
stuntman
CUSCO RS 1.5 way (80-100% lock) or OS Giken 1.5-way
Old Feb 8, 2009 | 08:02 PM
  #233
Phantom Menace's Avatar
Phantom Menace
I have the Quaife and love it! Best $1k(something) I've ever spent on my car! During regular driving I don't notice any difference. However, when I'm cornering (hard) I can feel the outside wheel bite down. It does it subtly though, it doesn't snap hard or anything. I just notice it because in similar corners/speeds with my old open diff, I would have to throttle off a bit. with the Quaife, I can accelerate much sooner and brake later.
I've never used the clutch types. A carbon one will not clank as much, or so I've read, and it may be better suited for competition.
Old Feb 8, 2009 | 08:54 PM
  #234
Chebosto's Avatar
Chebosto
listen to Stuntman..
he knows all.
Old Feb 15, 2009 | 03:35 PM
  #235
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Carbonetic has always been my favorite choice. I havent tired the OSG, so I can't comment on that one. The Carbonetic Carbon LSD is very smooth in normal street driven, and tight manuevers, and incredible on the track. It's set from the factory on 100% lock, but doesnt feel like it, due to it's very smooth engagement.
Old Feb 15, 2009 | 05:35 PM
  #236
mw9's Avatar
mw9
Been using the NISMO LSD for a for weeks now, wish the car would have came with something like this. I will have to admit its little loud. Just did my first oil change after brake in with Amsoil. I know everyone has said to run Motul, might have to try that, to see if will be a little quieter.
Old Feb 16, 2009 | 01:51 AM
  #237
Vader007's Avatar
Vader007
Talking Cusco RS
Originally Posted by Kwame@z1
You can't actually, they will just direct you to a US dealer
The Quaife is a nice unit - not the ideal choice for road racing due to the nature of helical diffs (both wheels must be on the ground for it to work), but it is a nice unit.
The nicest clutch type diff out there, bar none, is the OS Giken - it is buttery smooth, and the quality of construction is on another level. Check out this months Grassroots Motorsports for a nice write up of a few units compared to one another. It's also among the more expensive units (in the $1500 range). The Cusco RS is a popular choice as it's less expensive than Quaife, though a bit more sensitive to fluid selection (we use Motul in ours, works great and you can't tell it's there unless you are doing 3 point turns. It's significantly smoother than the NISMO/Kaaz type units as it uses springs in the center hub section. Adam uses the Cusco in his car now, and it's worked flawlessly. For the new rear he's building (trying different gears) he's going to use the Quiafe, just to try something different. Both are excellent units.
Is he selling the the used Cusco?
Old Mar 2, 2009 | 10:53 AM
  #238
TCO's Avatar
TCO
i read the articles and have some questions:
1. if you have the quaife and stand on snow, only one wheel will spool and the other will do nothing right?!
2. the quaife and the os giken lock from 0% to 100% is this right?!
thanks from austria
thomas
Old Mar 2, 2009 | 11:49 AM
  #239
betamotorsports
1. No.
2. No. The Quaife does not lock 100%.
Old Mar 24, 2009 | 11:06 AM
  #240
billstein87's Avatar
billstein87
Well, 2 years after the original post, here's a newbie that appreciates this write-up.
If Dave is still around the forum, did you leave everything set the same, or have you teaked it since then?
I couldn't find any oil discussions. I saw Redline mentioned here, and another mention of Motul on another thread. Mine has Mobile 1 in it now and I really bounce around the parking lot. What are people running in their track Zs with Nismo, Cusco, or Kaaz LSD?
Thanks,
Bill
