The Big LSD FAQ thread (About various Limited Slip Differentials)
Old Jan 16, 2012 | 09:06 AM
  #281
betamotorsports's Avatar
betamotorsports
You can configure at the time of purchase. OSG charges $125 to reconfigure the unit and they turn it around in one day. I can also reconfigure the units and just did one for a customer who drag races his LS7 240Z. Dropped the lockup timing from 336kg to 258kg and increased preload by 15%.
FYI... in most cases you do not need to reconfigure. They ship with a Spec-S setting that works well. In my NASA TTC 350Z I ran the Spec-S setting and the car worked very well.
Old Jan 16, 2012 | 09:31 AM
  #282
terrasmak's Avatar
Originally Posted by RandomHer0
Wow, so you purchase the unit and then have to send it in for re-config, or can you choose your config at the time of purchase?
That was a concern of mine too, but in all actuality there is little to no need for adjustment.
If you talk to the right people you can get the specs you need for adjustment. I havn't even touched mine since it was installed. IMO the only people who need to be able to adjust it are the ones with a high dollar race team competing at a national level.
Old Jan 16, 2012 | 09:36 AM
  #283
SE5spd's Avatar
SE5spd
I'd like to know this too. That would be a hassle if it's the case
Old Jan 16, 2012 | 10:25 AM
  #284
betamotorsports
99% of the people on this forum do not need the OSG Super Lock reconfigured from the Spec-S setting as shipped from OSG. The 1% that do have a very specific application where the additional tuning is need. I've reconfigured two diffs out of the dozens I've sold. One is for the drag racing example above (a 9 second car) and the other was for the 2011 FP National Championship winning E36 BMW.
Old Jan 16, 2012 | 10:42 AM
  #285
SE5spd's Avatar
SE5spd
^ 1.5 way 100% lock isn't to extreme?
Old Jan 16, 2012 | 11:09 AM
  #286
betamotorsports
"1 way, 1.5 way, and 2 way" are mostly marketing terms used to help manufacturers sell diffs. The terms very vaguely describe a diff's behavior under acceleration and deceleration but there are many other aspects to a diff's behavior then the pressure ring ramp angles that those terms pretend to describe.
Percentage of diff lock is the value when the diff reaches its full lock capability. All diffs allow adjustment of lockup percentage by swapping driven vs. drive plates and preload. Some diffs reach that number at low torque values and others reach it at high torque values.
The OSG Super Lock is different in that lock timing can be adjusted. OSG lock timing can be adjusted so that 100% lock is reached at some torque level and that torque level is what is changed to affect lock timing. The lower the torque level, the sooner the diff reaches 100% lock.
As shipped for an R200 diff (may not be correct for the 350Z R200) the 100% lock torque number is 336kg. That's diff torque not engine torque.
Old Jan 16, 2012 | 02:02 PM
  #287
Neimad's Avatar
Neimad
Just get the OS, it's been awesome on the street for me, track reviews are universally positive, you get t-shirt and license plate frame, fluid changes are best, Rob gets relieved when you show up with that instead of something else, you can look down on everyone else's diff, and no other diff company has made DOHC conversions for old L-series 4 bangers.
Old Jan 16, 2012 | 03:47 PM
  #288
SE5spd's Avatar
SE5spd
do the vendors tell you this when you order or is this only when you order directly from OSG?
Old Jan 16, 2012 | 03:53 PM
  #289
03threefiftyz's Avatar
03threefiftyz
I got the shirt and plate frame with my clutch....
Old Jan 16, 2012 | 03:56 PM
  #290
SE5spd's Avatar
SE5spd
which OSG clutch do you have?
Old Jan 16, 2012 | 03:58 PM
  #291
03threefiftyz
Super single with aluminum pressure plate.
Old Jan 16, 2012 | 04:42 PM
  #292
RandomHer0's Avatar
RandomHer0
I didnt get a shirt or frame! Not FAIR
Old Jan 16, 2012 | 04:53 PM
  #293
Neimad's Avatar
Neimad
So whoever installed it is rockin YOUR shirt? I put the license frame on b14 sentra to confuse people.
Old Jan 16, 2012 | 05:00 PM
  #294
SE5spd's Avatar
SE5spd
he got a CUSCO RS not a OS GIKEN lol.
Old Jan 16, 2012 | 06:09 PM
  #295
Neimad's Avatar
Neimad
Damn, missed that. But it's settled then? O.S. or go shirtless. (the stuff is in the box, make sure you open it first)
Old Jan 16, 2012 | 06:21 PM
  #296
SE5spd's Avatar
SE5spd
guess im getting a OS GIKEN lol.
Old Jan 17, 2012 | 03:57 AM
  #297
RandomHer0's Avatar
RandomHer0
I have a Twin Disc OS Giken Clutch. No Shirt, No Frame and I installed it myself
Cusco LSD.
Old Jan 17, 2012 | 08:03 AM
  #298
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
depends when you got it, they have not always included free things with the products
Old Jan 17, 2012 | 08:13 AM
  #299
RandomHer0's Avatar
RandomHer0
Damnit
Old Jan 17, 2012 | 08:33 AM
  #300
betamotorsports
You also get a little pack of stickers.
