The Big LSD FAQ thread (About various Limited Slip Differentials)
Old Oct 9, 2009 | 05:01 AM
  #261
mhoward1's Avatar
mhoward1
merged a bunch of threads together so you can open this thread together and search a single brand or compare a bunch of them in one place.
Old Oct 9, 2009 | 07:12 AM
  #262
betamotorsports's Avatar
betamotorsports
Locking percent on a CLSD is only adjustable off the car. The Nismo 1.5 LSD has an on-the-car preload adjustment but that's not something you adjust between track sessions. Its more an adjustment from street to track and back again. Having run one of these Nismo units in my 350Z the range of adjustment on the peload is not significant.
Old Oct 9, 2009 | 08:34 AM
  #263
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by sektor 11
how easy is it to adjust the locking on the different limited slips? is it something one can do in between track sessions?
it would take a pretty advanced driver, on a thoroughly sorted car, and knowing what tracks to try what settings at, to justify playing with lockup on the diff. I've never once adjusted the Cusco on my car. Even at it's lowest lockup % it's still roughly more than 2 x the lockup that a brand new factory VLSD has (which only goes down with age)
Old Oct 9, 2009 | 08:40 AM
  #264
betamotorsports
Agreed. It basically requires a different complete rear end setup for each lockup percent and two days of testing at a track to determine the optimal lockup percent. Been there and done that (as crew) with an GrandAm GTO Viper team back in 2000. Viper diffs are frickin' heavy and I swapped five diffs over two days and the team determined that the original setup in the car (as recommended by Neil Hanniman at Dodge Motorsports) was the best. Teams of engineers with computers often get it right. :-)
Old Oct 9, 2009 | 08:44 AM
  #265
Z1 Performance
Former Sponsor
yeah no fun at all!
when we were involved on one of the many E46's running in World Challenge a few years back, I recall we had a few different diff setups...and even those were heavy! All we had to go off was driver feedback, zero datalogging lolol - a bit old school
Old Oct 9, 2009 | 08:47 AM
  #266
betamotorsports
As crew I was always very, very worried when the driver showed up on Thursday and said, "I have this great idea about how to make the car handle better..." and he's holding a car magazine.
Old Oct 9, 2009 | 08:50 AM
  #267
Z1 Performance
Former Sponsor
lolololol - you knew our driver I see
he knew how to use google, that was his biggest issue. Instead of improving him, he always tried improving the car...meanwhile, as often happens, the car was more capable than the driver
Old Oct 10, 2009 | 07:25 AM
  #268
betamotorsports
Marty,
You might want to stick this thread. Thanks for merging them all together for us.
Old Oct 10, 2009 | 08:14 AM
  #269
mhoward1's Avatar
mhoward1
Originally Posted by betamotorsports
Marty,
thought about it but I am worried about too many stickies
Old Oct 11, 2009 | 12:58 PM
  #270
Germanguy's Avatar
Germanguy
short question: Do I have better traction straight ahead with a helical lsd like Quaife? coz im turboed and have a non lsd base model .
Old Oct 12, 2009 | 05:56 AM
  #271
sektor 11's Avatar
sektor 11
I could be wrong but I don't think LSD's assist with straight-ahead performance. I thought they were for putting traction to the wheel with least resistance (mostly in turns). I guess it might be somewhat helpful for straights?
Old Oct 12, 2009 | 06:07 AM
  #272
03Z33's Avatar
03Z33
Yes. Any LSD will give you better traction than open diff. Helicals are usually preffered for OEM type applications where they want smooth operation. Clutch type LSD will actually give more grip but is a more aggressive feel depending on how it's set up. I've always ran clutch type LSD in my rwd cars, only tried helical in fwd cars and a few porsches.. not a big fan.
You are wrong.
Open diff = one wheel burnout
LSD = two wheel burnout
Old Oct 12, 2009 | 09:44 AM
  #273
sektor 11's Avatar
sektor 11
got it, makes sense.
Old Jan 15, 2012 | 05:31 PM
  #274
SE5spd's Avatar
SE5spd
Yes I am bumping a REALLY old thread
I am stuck, I cant decide between the OS GIKEN and CUSCO RS
any benefit between one or the other, any reason I would specifically want to choose one or the other?
Old Jan 15, 2012 | 05:36 PM
  #275
2TH PWR's Avatar
2TH PWR
Hey I got a question.
I just got a Cusco RS LSD at 80% and I wanna fill it with Motul 90PA.
Will this be awesome?
Old Jan 15, 2012 | 11:18 PM
  #276
terrasmak's Avatar
What is to decide on if OS is in your budget?
Old Jan 16, 2012 | 07:41 AM
  #277
Z1 Performance
Former Sponsor
OS - a bit smoother engagement vs Cusco (its close but the OS is a touch smoother). Any adjustments have to really be done by OS, which means taking the diff out and sending it back to them unless there is an authorized OS 'pro technical' shop in your area.
Cusco - user adjustable for lockup (60,80,100% in manual cars), and for direction (adjustable from 1.5 to 2 way) Diff has to come out to make lockup adjustments, but can still be done by the user (instructions provided on restacking the plates)
Both work extremely well
Old Jan 16, 2012 | 07:46 AM
  #278
RandomHer0's Avatar
RandomHer0
What config is the OS shipped with?
Old Jan 16, 2012 | 07:52 AM
  #279
Z1 Performance
Former Sponsor
1.5 way 100%
Old Jan 16, 2012 | 07:53 AM
  #280
RandomHer0's Avatar
RandomHer0
Wow, so you purchase the unit and then have to send it in for re-config, or can you choose your config at the time of purchase?
