race wheels
Old Sep 12, 2004 | 08:39 PM
M23's Avatar
M23
Default race wheels
17x9 27mm offset front and rear
will this setup run fine on track?
i mean running same offset and width wheels for front and rear, does that affect handling?
Old Sep 14, 2004 | 12:38 PM
stumpmj's Avatar
stumpmj
Default Re: race wheels
I'm running that setup with 275/40 Nitto 555 R2 (R compound) tires. I was just at the track with it yesterday. Traction control (and presumably VDC) hates it but it helps to dial most of the understeer out of the car. I had no issues with clearence or rubbing. I love the combo.
Old Sep 21, 2004 | 12:39 PM
03Z33's Avatar
03Z33
I also run a similar setup 17x9 et20 front and rear. I usually place a 15 or 20mm spacer in the rear.
With the higher 27mm offset you may also want a 5 or 10mm spacer up front... for best looks and a little wider stance.
Tire sizes I have used are as follows:
255/40/17 all around (had to disable ABS/VDC to keep from intruding)
245/45/17 all around (had to disable ABS/VDC to keep from intruding)
245/40/17 front and 255/45/17 rear (OK with ABS fuse in)
Next I will rund 255/45/17 front and 275/45/17 rear with fuse pulled (I usually drive with ABS/VDC disabled all the time) HTH
Old Sep 21, 2004 | 01:28 PM
Lateapex's Avatar
Lateapex
Originally posted by 03Z33
... (I usually drive with ABS/VDC disabled all the time) HTH
Does pulling the ABS fuse disable the VDC, as well? And, where is that fuse located?
Old Sep 21, 2004 | 02:41 PM
03Z33's Avatar
03Z33
The Fuse is located in the narrow fuse box by the battery (under hood p/s side compartment by windshield) When you open the cover it will be the only larger style red square fuse all the way on one end.
I used to pull this only for spirited drives and track, but now leave it out almost all the time.
When you start the car and roll forward you will notice the following lights will come on: Brake, VDC, Slip, ABS. This will disable the following: VDC, T/C, ABS and you will be able to feel the throttle response is different right away. HTH
Old Sep 21, 2004 | 06:22 PM
daveh's Avatar
daveh
I'm running 17X9.5 +35 all around and have 5mm spacers on order for the fronts to give some extra clearance from the arms. Your tires may be sticking outside of the fenders up front if you go with 275's. Mine are perfectly flush with the +35mm
Old Sep 22, 2004 | 08:26 AM
03Z33's Avatar
03Z33
Dave are you running the stock front arms? 275 is pretty aggresive up front, is that for autocross mostly? The most I have run is 265/35/18 on a 9" et25 wheel and that had good clearance...
Old Sep 22, 2004 | 10:06 AM
daveh's Avatar
daveh
It is for road racing. When I mount the wheels up front, there is about 3mm of clearance between the wheel and the arm. After taking the wheels off at the end of the track day, I saw a slight black mark on the arms where the tire was rubbing (presumably under hard cornering). There is no noticeable mark on the actual tire so I figure it's minor rubbing at best, but to be safe a 5mm spacer should give me some extra clearance. I am running the stock arms.
Old Sep 22, 2004 | 10:08 AM
2003z's Avatar
2003z
I run 275/40 on 17x9+35 autocross and track with no issues.
Old Sep 22, 2004 | 10:21 AM
03Z33's Avatar
03Z33
Thanks for the info! looks like the extra 1/4" on the inside of the 9.5" wheel is the issue.. 5mm should do the trick.
Old Sep 22, 2004 | 12:10 PM
daveh's Avatar
daveh
I didn't think the 1/4" would make a difference because it would put the actual tire in the same place as a 9" rim with the same offset. It's the tire hitting the arm, not the wheel. Perhaps it's just the difference in brands and what they consider to be +35 offset. I think the 275 fits better on the 9.5 too.
This setup does look very meaty up front. I think sport compact car used the term "autocross freakshow". When I get some A arms, it'll tuck the wheel in a little and not look so oversized.
Old Sep 22, 2004 | 02:12 PM
EnthuZ's Avatar
EnthuZ
That is the exact size I've had since April! I run 255/45 Kumho MX tires all around. Handles great on street & track! This is the optimum width tire for this rim, according to Kumho. And the diameter is REAL close to stock.
Not totally happy with the tires on the track though. Sidewall is a bit too soft, softer than 040's. If I had to do it over, I'd get 245/40's. Stiffen up the sidewalls, and improve gearing a bit.
Using same size tires F & R helps get rid of that pesky understeer! That, and Cusco sway bars.
BTW, I do not use spacers.
Old Sep 24, 2004 | 05:51 AM
M23's Avatar
M23
thanks guys for the info
which 17" race wheel is the most popular ?? looking for something that i can afford...
Old Sep 24, 2004 | 07:20 AM
tomzz's Avatar
tomzz
Default which 17" wheels for track set?
Which 17" wheels for Track (light & strong) set? at a reasonable price?
My investigation on this subject suggests you first start with an investment decision on Cast vs. Forged (stronger and mo $$) wheels. Here are some options that seem to be popular presuming you get 8.5", 9", or 9.5 inch (or maybe 10"ers). Simple cast wheels in the $200 range are the low end option with some Khumo R tires
High Quality light Cast
Enkei's such as RPF1 $250-$350 ea
Lower Cost Forged $400-$500 ea
Racing Hart's - single piece
Complete Custom Wheels - very strong multi piece
I am looking at used BBS 17" wheel options from Bob Woodward Tires.
I will be interested to see what is suggested by others.
Old Sep 25, 2004 | 01:26 PM
axxizzer's Avatar
axxizzer
just use the nismo LMGT4s they are tailor made for this car and thats what I use
Old Sep 25, 2004 | 09:22 PM
daveh's Avatar
daveh
Here is a pic of my 9.5" ssr. I think the extra .5" places the outside of the wheel roughly in the same place as the +27 MB comp.
Old Sep 25, 2004 | 09:23 PM
daveh's Avatar
daveh
Old Sep 26, 2004 | 07:55 PM
M23's Avatar
M23
i'm planning on getting some 17" Voklks gram light 57C, they are pretty lightweight.
Kumho's V700 are cheaper $$ than RA-1 but which one do you guys recommand?
Old Sep 26, 2004 | 08:55 PM
03Z33's Avatar
03Z33
I would classify the Kumho Victoracer V700 as a slightly stickier more aggressive tire than the Toyo RA1. Under most conditions it will not last as long, but should allow for better times (taking into account car setup, race/road conditions, etc...) The Kumho also tends to like a little more camber, which unless you have adjustable upper control arms on your Z33 it is difficult to achieve. There is also the newer Kumho Ecsta V700 which I have less experience with, but is similar to the Victoracer, with a little stiffer sidewalls, lighter weight and slightly less all out grip.
It really depends on the type of driving: street, autocross, HPDE, time trial? Will these be used for track only, or will they be driven on a daily basis? If driven on the street for extended periods of time most people would prefer the Toyos... unless you are willing to compromise some longevity for the added grip. HTH
Old Sep 27, 2004 | 12:06 PM
speedform's Avatar
speedform
For price I'm guessing the MB Motoring Competition wheel is a good choice. 17by 9" size, 27 offset, 20 pounds a piece and $134.00 a wheel through Discount tire. It's a little heavier than the next step up (Enkei RPFI's: 16.5 pounds, $250.00 per) but hell, we're not pro race drivers here. I'd rather save some cash for new tires and loose a tenth second a lap.
Obadabot
Jun 18, 2023 11:31 PM
