G35 Coupe Owners Get In Here / JDM Master Cylinder Cover
Vendor - Former Vendor
JDM V35 Battery Cover (US G35 Brake/Clutch Master Cylinder Cover) kit for all '02+ G35 Coupes.
From the factory, the G35 Coupe came without a cosmetic cover for the Brake and Clutch Master Cylinders (Unlike its sibling, the 350Z). Lacking this cover, the now exposed reservoirs and fluid lines can be an eye sore.
By using the RHD V35 Skyline's Battery Cover Panels, you can retro fit the piece to cleanly cover the Brake/Clutch Master Cylinders and its hardware. This not only makes the engine bay much cleaner in appearance, but it also protects the various reservoirs and lines from exposure to the elements.
The kit includes for following items:
Cutting/ Drilling of the body and supplied RHD Skyline Battery Panels are required. Please read all directions carefully before cutting or beginning installation. Professional installation is highly recommended.
Fits Coupe models ONLY!
Stock
With JDM Cover Installed
Limited Number in stock $39.00 Click Here To Order.
- 1x V35 RHD Battery Cover Panel (Small)
- 1x V35 RHD Engine Cover Panel (Large)
- 5x OEM Plastic Panel Clips
- 1x Z1 Motorsports Brake/Clutch Master Cylinder Cover Installation Instruction Sheet
- 1x OEM Panel Support Bracket
- 1x Z1 Motorsports V35 Battery Cover Support Bracket (Rear)
Stock
