LED's in the Door Handle's. (56k Maybe)
Old Feb 24, 2005 | 06:29 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
its cool. i think the amber is real nice.
Old Feb 24, 2005 | 07:13 PM
FLZ's Avatar
FLZ
Kind of nice lookin'....but would you stop wigglin' and take a clear pic please........:-)
Old Feb 25, 2005 | 03:49 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Stickied.
Bump...
Old Feb 26, 2005 | 01:18 PM
Acree's Avatar
Acree
here's how to wire them to the map lights.
first of all, you need to drill the holes, epoxy the LEDs, wire them with the corresponding resistor, then run the wires from the door handle inside the door, out through the gromet for the door, under the side skirt, under the weather stripping along the bottom of the door, up the side molding, all the way up to the headliner through the A-pillar, then over to the map lights. one tricky thing i ran into was getting the wire under the headliner over to the map light housing. i had to get a coat hangar and push it through were the light housing popped out to the windshield. then taped the wire to the hangar, and pulled it back through. here are the pics for access to the light housing, and soldering the wires.
here is where you need to pop out the lense.
Old Feb 26, 2005 | 01:19 PM
Acree's Avatar
Acree
after you have both lenses popped off, there are 4 catches around the housing where it is popped into place. you can either put ur screwdriver here, or at the 4 places.
Acree's Avatar
Acree
here is a close up of 2 of the catches that hold the housing in place. you need to depress all 4 of these with the screw driver to get the housing to fall out. be careful not to pull on the housing because it has wires attached
Old Feb 26, 2005 | 01:20 PM
Acree's Avatar
Acree
the 2 sets of wires you see are mine. i have wired so that the left map light, if pressed turns on the left handle LEDs and same thing for the right side.
Acree's Avatar
Acree
here is a close up of the wiring for the left side. since LED's are polar, the electricity has to flow one direction. so when doing this, make sure that positive lead wire that is connected to the resistor, then the positive lead on the LED, is soldered on to the bulb lead that is closer to the front of the car. this is very important. if you sodler the leads on to the wrong bulb connections, the LED's will not work and, if enough voltage flows through, could damage the LEDs.
Old Feb 26, 2005 | 02:04 PM
chazzg's Avatar
chazzg
how much would you charge to do this for someone local? would having the side airbags be an issue? Pm me if you want to do my Z (with Blue LEDs if you can)
Old Mar 1, 2005 | 09:36 AM
willthethrill's Avatar
willthethrill
First off i really like it!
Im not sure about you Z folks but i know in the G there is a light in the door "step light" that comes on with the dome light at a unlock.. If you have the same light it would save a ton of work running those wires to the dome.
Old Mar 2, 2005 | 12:50 PM
Faluzure's Avatar
Faluzure
So pimp. You are my hero.
Old Mar 2, 2005 | 09:38 PM
Brandon@Forged
Thanks 350ztwinturbo.
Old Mar 3, 2005 | 01:13 PM
Acree's Avatar
Acree
no problem man. jusy doin what i can to help people do it.
Old Mar 3, 2005 | 07:34 PM
Beaker02's Avatar
Beaker02
Fun. Good job.
Old Mar 17, 2005 | 02:52 AM
zipman's Avatar
zipman
very nice how'd you do it?
Old Mar 17, 2005 | 09:02 AM
Acree's Avatar
Acree
zip- read the thread man. its all there. thanks.
Old Mar 23, 2005 | 04:39 PM
  #38
pyindeem's Avatar
pyindeem
Default Nice Mod.
But I wonder if any1else have thought about installing the led behind the the handle instead of in front. To me it would be both functional & class.
Old Mar 23, 2005 | 11:54 PM
  #39
jchen1020's Avatar
jchen1020
Default test
test
Old Mar 23, 2005 | 11:56 PM
  #40
jchen1020's Avatar
jchen1020
test
