DIY LED Corner Reflectors
Old Dec 28, 2006 | 08:31 PM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
man i'm waiting for my clear reflectors to come....then it begins for me
Old Dec 28, 2006 | 08:53 PM
Xenor's Avatar
Xenor
Here are a couple of nighttime shots. It's hard to get a good representation of them even with my DSLR, but these at least give an idea.
Attached Thumbnails DIY LED Corner Reflectors-led1.jpg   DIY LED Corner Reflectors-img_0015.jpg
Old Dec 28, 2006 | 09:34 PM
stogey420time
Club Moderator
the Hot Spot
^ wow thats bright (a good thing).
which bulb did you use for your parking lights?
do they burn out easy?
Old Dec 28, 2006 | 09:47 PM
Xenor's Avatar
Xenor
Parking lights are some 1 led polarized bulbs from Superbrightleds, these are the only ones I've bought from this company that haven't burned out.
The LEDs in the reflectors are 5mm LEDs I mentioned earlier. They're running at 3.5 volts and 21 mA.
Old Dec 31, 2006 | 12:56 PM
Xenor's Avatar
Xenor
A couple of daytime pics.
Old Dec 31, 2006 | 11:20 PM
ZLadie2000's Avatar
ZLadie2000
too many LEDs, I would have opted for 3...Nice handy work though
Old Jan 1, 2007 | 07:42 AM
stogey420time
Club Moderator
the Hot Spot
nah i think the 7 leds looks good cause it's the 06' refelctors but i would've centered it though.
i'm going to put 5 on mine...can't wait till my reflectors are here
Old Jan 1, 2007 | 07:55 AM
plumpzz's Avatar
plumpzz
did you put the lights in parallel?
Old Jan 6, 2007 | 07:02 PM
Xenor's Avatar
Xenor
The LEDs are placed towards the rear of the reflector in this case because the plastic and metal bracketry on the back on the reflector was difficult to modify. Since I moved them towards the rear, I angled the LEDs so that the light is more forward. This seems to allow the LEDs to be seen from the front a little better.
The wiring of the LEDS is similar to the illustration attached.
Old Jan 20, 2007 | 04:21 PM
Agentman03's Avatar
Agentman03
Don't Most of the New LED come with built in Resistors for 12 v ??
Old Jan 20, 2007 | 07:30 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Some do and help the math challenged. Buy picking your LEDs you can select exactly what you want - brightness, color, and output angle.
Old Jan 30, 2007 | 06:20 PM
Agentman03's Avatar
Agentman03
Plasmaled.com & autodirectsave.com have 5 mm & 8 mm led's for 12 volt parellell setup wiith the Resistors and wires already soldered up .. just wire up !! 10 for $12.00 ... all colors ..
Old Jan 30, 2007 | 06:21 PM
Agentman03's Avatar
Agentman03
bought 10 white to use on my new silver chrome reflectors ..
Old Jan 31, 2007 | 09:26 AM
dragone2717's Avatar
dragone2717
Whats the difference between the 5 & 8mm?
Old Feb 6, 2007 | 05:49 PM
Agentman03's Avatar
Agentman03
Bought the 5 MM Led's From " Plasma Led.com " 10 for $12 .. they Have the Built in Leads and Resitors .. They Work Great fot The Side Reflectors, No Calculating or Extra Soldering ect.. Great ...Thank's.. Great Wright up !!
Old Feb 8, 2007 | 06:17 PM
stogey420time
Club Moderator
the Hot Spot
pics
Old Feb 8, 2007 | 09:36 PM
gNaRKiLL's Avatar
gNaRKiLL
Alright I just went crazy tonight. Bought some clear reflectors from ebay. Bought 1000 red LED's from surplusleds.com for 40 bucks (Planning on making a few sets of these).
Determining whether or not to pull the trigger right now on some parking lights and the blinkers.
Anyone know if you have to open up the headlight to access the parking and blinker lights? I am assuming no but cant remember.
Old Feb 14, 2007 | 10:09 AM
  #38
Paul350Z's Avatar
Paul350Z
Living in 350Z
The parking and blinker lights are attached to the sides of the headlight enclosure so you don't actually remove the big plug in the back of the assembly but you do have to do everything else:
1. remove the wheel.
2. remove the plastic inner fenderwell.
3. have fun.
Old Mar 2, 2007 | 06:46 PM
  #39
MiniRide's Avatar
MiniRide
I just ordered 10 white LEDS
Old Mar 8, 2007 | 05:00 AM
  #40
Skorch's Avatar
Skorch
Very cool. I'll be getting a set of 12 UV colored ones when I get my Z.
