DIY: repairing faded/foggy headlights
Old Mar 14, 2010 | 07:24 PM
  #41
Voboy's Avatar
Voboy
dang... can't believe 06+ owners are already having these problems! but im glad there's a simple fix.
Old Mar 14, 2010 | 08:15 PM
  #42
kno's Avatar
kno
miami's heat is killler
Old May 23, 2010 | 12:50 PM
  #43
GARYMM1187's Avatar
GARYMM1187
kno, thanks for posting up your method and results, I think I may try that.
Old May 23, 2010 | 02:26 PM
  #44
kno's Avatar
kno
np pm me if you have any questions.
Old May 24, 2010 | 06:28 PM
  #45
GARYMM1187's Avatar
GARYMM1187
Ok, so I went at it a bit tonight on one light and got decent results...
I used some plastic polish I had at my work and attached a foam pad to the drill and went crazy....
btw sorry for the crappy cell phone pics...thats all I can do for now...
Old May 25, 2010 | 04:25 PM
  #46
HEYROBI1001's Avatar
HEYROBI1001
Recomend not to do the sandpaper unless you know what you are doing. i messed up on my old bmw years ago on that one. The sand paper leves swirl marks. I had the same problem with my 06 and with the heat in san diego my lights where becoming yellow. I went to Walmart and bought Meguiars PlastX Clear Plastic Cleaner & Polish worked like a charm and instanly cleared it up. I also noticed small crackes in the plastic lens dont know what to do with that
?? it cst about 8 bucks . Try it out you will not regret it.
http://www.meguiarsdirect.com/produc...?T1=MEG+G12310
Old May 25, 2010 | 04:33 PM
  #47
phreaktor's Avatar
phreaktor
Design Engineer
I would reccomend spreading some car wash over the lights while wetsanding to help carry away debris and keep the paper lubricated.... Don't forget to rinse the paper OFTEN...
Old May 26, 2010 | 07:17 AM
  #48
GARYMM1187's Avatar
GARYMM1187
HEYROB, How did you apply the plastX? I have a drill and buffing pad. That might work better than the stuff I used...
Old May 26, 2010 | 07:19 AM
  #49
kno's Avatar
kno
read my post on page 2, i used my fingers and rubbed it all over the headlight first. if not your gonna splatter the cream everywhere
Old May 26, 2010 | 07:24 AM
  #50
GARYMM1187's Avatar
GARYMM1187
I saw it said that you used the powerball, but I was trying to avoid buying that...I'm thinking maybe the foam buffing pad I have will work...
Old May 26, 2010 | 07:48 AM
  #51
kno's Avatar
kno
give it a try its all about trial and error. if your gonna experiment try using product from less abrasive and work your way up to more abrasive products. be careful tho, those headlights are expensive.
Old May 26, 2010 | 02:44 PM
  #52
HEYROBI1001
i would apply it with round those microfiber pads for waxing(buy at walmart for like 2bucks) then do it buy hand. away from direct sun. it first takes the yellow haze and will see it in the pad. you might want to turn it over to buff it out or use a buffer.
Old Nov 17, 2010 | 04:00 PM
  #53
GARYMM1187's Avatar
GARYMM1187
I ended up using the 2000 grit wetdry, plastx, and powerball.
Did it the way kno suggested minus the wax and it turned out pretty good.
Old Nov 17, 2010 | 08:02 PM
  #54
kno's Avatar
kno
Old Nov 30, 2010 | 06:28 PM
  #55
HEYROBI1001
great can anyone point me to where or how or why does my car light get water inside. how can i fix it?
Old Jan 7, 2011 | 12:35 PM
  #56
yomike007's Avatar
yomike007
I used some Plastx, a paper towel, and a little elbow grease and it made the world of a difference. Proper sanding would have made it looked perfect, but mine seem to re-fade every three or four months or so and Im too lazy to keep busting out the electric sander.
Old Jan 9, 2011 | 11:26 AM
  #57
BoomerZ33's Avatar
BoomerZ33
that's condensation buildup. it's probably cracked somewhere where it's hard to see or it's not sealed correctly.
Old Feb 2, 2011 | 04:48 PM
  #58
sssmasss's Avatar
sssmasss
how often do you guys do this. i did this 3 times already within a year!!!
Old Feb 13, 2011 | 11:27 PM
  #59
shakalaka's Avatar
shakalaka
So does applying a regular wax and rubbing the **** out of it help clear the light out somewhat? I kind of don't want to risk it with the sanding.
Old Feb 14, 2011 | 05:43 AM
  #60
kno's Avatar
kno
it just hides it till you wash your car or the wax fades off.
