Rear fluid nozzle removal
Old Mar 14, 2010 | 02:11 PM
Swanson731's Avatar
Swanson731
Default Rear fluid nozzle removal
Here is the DIY rear fluid nozzle removal guide,this is my first DIY so I hope it will be informal. This is very easy.
What you need:
Needle Nose Pliers
Dremel (or other sanding device)
Krylon Stain Black Paint
Crown Bolt 7/8 Locking Hole Plug
Thread Seal Tape (optional)
1. Towards the back of the hatch you should see a rubber tube connected to the bottom of the nozzle, simply pull it off and cap it off with a bolt (that's what I did).
2. Now take the needle nose pliers and grab each side of the nozzle and gently push upwards. Then simply lower the hatch and pull it out from the out side. (Sorry I couldn't get a good picture of this step)
3. The hole plug fits perfectly diameter wise, length wise it is too long, that where a Dermel comes in handy. Just shave some plastic off the bottom of the plug. CAUTION: Take your time with this step, and keep going back to the car to check on the length.
Original length versus new length:
4. Paint the plug, the paint can may say it only take 10min to dry, but give it at least 30min to an 1h.
5. (optional) wrap the sides of the plug with thread seal tape for waterproofing.
6. Plug the hole, and your done!
Hopefully this helps everybody!
-Shawn
Old Mar 14, 2010 | 03:39 PM
grizz311's Avatar
grizz311
good work!!
Old Mar 14, 2010 | 04:30 PM
blue350zed's Avatar
blue350zed
Where'd you get the plug from?
Old Mar 14, 2010 | 04:42 PM
Swanson731's Avatar
Swanson731
I got it from Home Depot, it was in the section with the wing nuts, screws, and bolts.
Old Apr 1, 2010 | 12:21 AM
StillAlive2029's Avatar
StillAlive2029
Is there no latches holding it in? Just a snug fit? and so getting it started out the hole is all you need to then be able to grab it from the outside and pull it out?
Old Aug 31, 2011 | 11:09 AM
defcon83's Avatar
defcon83
I did this weekend and it came out real good. Great diy!!!
Old Sep 28, 2011 | 07:03 AM
moose350z's Avatar
moose350z
Thank you OP for this DIY. This completes the rear wiper delete PERFECTLY.
Old Sep 28, 2011 | 04:36 PM
defcon83's Avatar
defcon83
It was a great diy. It looks nice and sleek when you do both the squirter and the wiper.
Old Sep 28, 2011 | 05:53 PM
moose350z's Avatar
moose350z
Did mine over the weekend.
Old Aug 1, 2012 | 04:21 PM
sry110's Avatar
sry110
What happens if you accidentally pull the lever that actuates the pump to send washer fluid back there? I understand the end of the hose is plugged, but it seems that this would "dead-head" that pump. Possibly there is a fuse dedicated to this pump....anyone happen to know which one it is?
Old Aug 4, 2012 | 04:51 AM
sry110's Avatar
sry110
BUMP
Anyone? I guess the fluid would be outside of the weather seal and just run down and out the back?
Old Mar 1, 2013 | 03:52 PM
rawgarage's Avatar
rawgarage
need to do this asap...
Old Mar 1, 2013 | 05:39 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
BUMP
I left my nozzle there for that reason after getting a CF hatch w/ no wiper. Now if I accidentally hit my washer fluid it just pees all over my windshield.
Old Mar 1, 2013 | 09:30 PM
rawgarage's Avatar
rawgarage
Hahahaha how you like the CF Hatch
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
