DIY: Engine Bay Dress-Up Bolt/Washer Kits, NFSP Style
Old Mar 23, 2012 | 06:22 PM
nfsp g35's Avatar
nfsp g35
Originally Posted by midna
What are the bolts circled?
Thanks again for posting this!
Those are M6x25mm and 16mm lengths for various places around the engine bay. There's a lot of places you can put those, so you're usually best getting a lot more than you think you need because they're not that expensive.
That kit in the pic is one for somebody with a 5/16 spacer.
I sent him 50mm and 70mm lengths for the 7 middle bolts, and 35mm ones for the perimeter, and he didn't have a problem.
Wouldn't be a bad idea to grab a couple extra 35mm ones just in case (if you have a spacer)
Old Mar 29, 2012 | 06:16 AM
cmcurran5's Avatar
cmcurran5
so does someone have like a complete list of all the bolts we need?
Old Mar 29, 2012 | 06:41 AM
NZMOWND's Avatar
NZMOWND
This, for an HR engine...ill gladly paypal u 10 bucks to share exactly what was bought!!
Old Mar 30, 2012 | 05:18 AM
midna's Avatar
midna
Thanks!!! I will be placing my order Monday
Old Mar 30, 2012 | 06:46 AM
cmcurran5's Avatar
cmcurran5
i went to order and was thoroughly confused lol. i know I'm pretty slow but can someone please translate the bolt size for me..
6mm-1,00x10 FHCS (ss)
obviously the ss is stainless steel
so im assuming the 6mm is the thickness of the bolt.
the 1,00 is that pitch that you mentioned, midna
and the 10FHCS is the length
??? i need to order these soon lol
Old Mar 30, 2012 | 04:10 PM
nfsp g35's Avatar
nfsp g35
^M6 is the bolt size (metric, 6mm dia bolt... these are the ones that would have a 10mm head)
1.00 is the thread pitch (pretty much all the M6 bolts on a Nissan are going to be 1.00 thread pitch)
and the 10 is the length in MM from the top of the bolt head (the flat surface part, not the bottom of the head where the threads start)
A 10mm is super short. I would recommend you only go as low as 16mm for short bolts, and 25mm for most of them (but grab a few 16mm length, they're necessary in a couple places)
Sorry I can't give you guys a ton of details, but I'm used to dealing with the G35, and the engine bay on the 350 is different, but uses a lot of the same bolts.
Old Apr 4, 2012 | 01:42 PM
TPete19's Avatar
TPete19
Thumbs up
Alright guys, here's the list I've compiled working from what NFSP G35, midna, and NoSurf2Day had provided. I also cross referenced with the GalleryFresh kit list, Courtesy Parts' diagrams and datsun1200.com's part number decoding thread (interesting read on how to decipher nissan's part numbers).
(Updated 9/5/12)I've added this exact setup to my engine bay, so I can vouch for it all.
This is for the HR motor, but much of it is the same for DE cars as well (just use half of the throttle body bolts, ignore the engine cover nuts/bolts, and add the plenum bolts that midna and NFSP have listed).
Headlights
(2) M6x1.00x20mm flat head allen bolts
(2) M6 countersunk washers
Strut Bar
(6) M10x1.25x25mm flanged hex bolts (use 30mm if you have a DE with a plenum spacer)
(2) M10x1.25 flanged nuts
(8) M10 flat washers
Shock Towers
(6) M8 flanged nuts
(6) M8 flat washers
Power Steering Bolts
(3) M6x1.00x25mm flat head allen bolts
(3) M6 countersunk washers
Radiator Support
(4) M8x1.25x20mm flat head allen bolts
(4) M8 countersunk washers
Engine Cover (HR specific two piece cover)
(3) M6x1.00x20mm flat head allen bolts
(4) M6x1.00 dome(acorn) nuts
(4) M6 flat washers
Hood
(4) M8 hex nuts
(4) M8 flat washers
Throttle Body (for DE motors, get 4 of each and the bolt are 60mm in length instead of 55)
(8) m6x1.00x55mm metric allen bolts
(8) m6 flat washers (the smaller the outside diameter the better)
Fender
(6) M6x1.00x25mm flat head allen bolts
(6) M6 countersunk washers
104 total pieces.
Old Apr 4, 2012 | 04:42 PM
nfsp g35's Avatar
nfsp g35
^Sounds pretty good, though you completely missed the plenum bolts
Old Apr 4, 2012 | 04:47 PM
cmcurran5's Avatar
cmcurran5
well he did say its for an HR motor
Old Apr 5, 2012 | 08:03 AM
TPete19's Avatar
TPete19
No need for plenum bolts on the HR list...
Old Apr 5, 2012 | 08:05 AM
NZMOWND's Avatar
NZMOWND
have u ordered your bolts yet?? if so how much was the cost?
Old Apr 5, 2012 | 08:22 AM
TPete19's Avatar
TPete19
Haven't ordered them yet. I built the list to send to a vendor who told me they would build a kit, but now tell me to buy the separate smaller packs of bolts... FML
Old Apr 5, 2012 | 08:38 AM
Junkster's Avatar
Junkster
I was actually looking into some kits that were on ebay that were what looked like to be identical to these. I was suprised at how cheap they were...
Like OP i was always drawn away from the high dollar kits. I find it hard to believe you really need extremely high quality strength bolts to hold on a plenum cover or a fender lol...Coming from me where ive used zipties to keep together an entire front end i think any cheap alternative would suit just fine :lol:
Old Apr 5, 2012 | 09:45 AM
TPete19's Avatar
TPete19
I agree. I just don't trust the finish on the cheap bolts... With all the heat cycling that happens under the hood, I'd imagine they wouldn't look great after a while if you went too cheap.
Old Apr 5, 2012 | 11:10 AM
SirSpeedyZ's Avatar
SirSpeedyZ
I don't know how I've never seen this before.
This is def going on my summer project list
Old Apr 5, 2012 | 12:14 PM
cmcurran5's Avatar
cmcurran5
i put a list together in the shopping cart and had to run out.. i thought that my list would still be there after 30 mins of putting it all together but it wasn't!
but the price for all the bolts and nuts that you can get from allensfasteners was like 55 bucks. not bad for something that some sites charge well over 200
Old Apr 5, 2012 | 12:45 PM
Junkster's Avatar
Junkster
wow 55 bucks is pretty damn cheap! was that for HR?
Old Apr 5, 2012 | 02:33 PM
  #38
cmcurran5's Avatar
cmcurran5
sorry no that was the DE.
Old Apr 5, 2012 | 03:52 PM
  #39
sluggoZ's Avatar
sluggoZ
All I did was use the old fashion "elbow grease" using Nevrdull....works miracles!
What your seeing is oem strut bar bolts (originally crappy lookin') that now look like brand spanky new polished lustre to dazzle the eyes!!!!
Old Apr 5, 2012 | 05:11 PM
  #40
cmcurran5's Avatar
cmcurran5
so i just bought everything! 46 at allens fasteners and 18 at the other site for the washers. thats if i didn't forget anything lol. i hope not! ill try to remember to do before and after pictures too.
