How to make a kick *** gauge pod!
Old Feb 4, 2004 | 05:22 AM
m3powerrr's Avatar
m3powerrr
Default How to make a kick *** gauge pod!
Okay, I've had lots of inquiries regarding this gauge pod but the time it takes to make one just doesn't justify the amount of money I have to charge. It was never my intention to make money off of this thing but it looks damn good and I think every Z owner should do this. Here is a step by step on how to make this pod. This is what we start with.
Old Feb 4, 2004 | 05:27 AM
m3powerrr's Avatar
m3powerrr
Position the gauge pod so the all four edges are flush with the pillar. Screw it down good on all four corners.
Old Feb 4, 2004 | 05:33 AM
m3powerrr's Avatar
m3powerrr
Start grinding away the edges of the pauge pod so the edge becomes flush with the pillar. You are actually grinding away some material on the pllar too because you will be adding material back later.
Old Feb 4, 2004 | 05:34 AM
ares's Avatar
ares
Veteran
wait...
is your "work bench" a FERRARI?!?
*goes to cry*
Old Feb 4, 2004 | 05:36 AM
m3powerrr's Avatar
m3powerrr
This is where you start applying the fiberglass. Don't ask me how to do fiberglass. It's real easy. Just read the instruction on the can. Applying the fabric is optional. When I do fiberglass, I always apply fabric. Some folks only use the resin. Yes, it's much stronger if you use the fabric, but then again, it's not a part that's going to see a whole lot of stress. It's your call.
Old Feb 4, 2004 | 05:42 AM
m3powerrr's Avatar
m3powerrr
this is what it will look like after applying the resin. Don't worry about over applying. It'll just take longer to sand. But it's better to have more material and and sand then having not enough material. Every time you need to add more material, you have to wait till it dries to sand again.
Old Feb 4, 2004 | 05:43 AM
JFritz's Avatar
JFritz
Hah, whoops, he must have decided to take pictures and accidently got the Ferrari emblem in there.
m3powerrr's Avatar
m3powerrr
Once it dries, go back and take the screws out and apply fiberglass to cover up the holes.
Old Feb 4, 2004 | 05:47 AM
m3powerrr's Avatar
m3powerrr
Now it's just sanding. Start with 180 then finish off with 320. Here's what it looks like primed.
Old Feb 4, 2004 | 05:56 AM
teh215's Avatar
teh215
Is there a particular paint color that matches the OEM pillar or should we just paint both pillars so they match. Thanks for the write. This definitely seems like it is very easy to do. Also, which pod are you using? Is it a generic Autometer part?
Old Feb 4, 2004 | 06:09 AM
m3powerrr's Avatar
m3powerrr
Here's a picture of a 2 gauge pod that's finished.
Old Feb 4, 2004 | 06:11 AM
m3powerrr's Avatar
m3powerrr
We ended up painting both pillars. Adn yes, it's just a generic Autometer part.
Old Feb 4, 2004 | 06:55 AM
D@ActiveTuning's Avatar
D@ActiveTuning
Nice work, finished product looks great!
Old Feb 4, 2004 | 08:27 AM
junglist350Z's Avatar
junglist350Z
so i'll just go ahead and ask, what ferrari is that you have in your garage?
ps, the guage pillar looks real nice
Old Feb 4, 2004 | 08:39 AM
teh215's Avatar
teh215
How do you remove the pillar? I couldn't find it in the FSM.
Old Feb 4, 2004 | 08:46 AM
BJF2K's Avatar
BJF2K
very nice!
Old Feb 4, 2004 | 10:34 AM
ss350's Avatar
ss350
Default nyce
Man that pod looks great. Do you 3 pods would fit? It looks like the 3rd one might be mounted to close to the roof and be out of normal road vision?
Old Feb 4, 2004 | 11:10 AM
teh215's Avatar
teh215
I am going to try this this weekend if I can locate 2 pods locally. If not, I will have to order them. I will post the outcome and how difficult it is for someone that has never worked with fiberglass. Hopefully I do not have to end up buying a new pillar.
Old Feb 4, 2004 | 11:28 AM
Phatmitzu's Avatar
Phatmitzu
Sweet! Make one for another PPW owner? :P
Old Feb 4, 2004 | 11:38 AM
yobri's Avatar
yobri
Nice, you could be a my350z Inventor if you should choose to sell your wares.
