Wheel Hub Assembly (wheel bearing) replacement - FRONT - HOW TO
Old Oct 17, 2013 | 07:42 PM
  #81
mattleegee's Avatar
mattleegee
timken
Old Oct 18, 2013 | 08:19 AM
  #82
jes1888's Avatar
jes1888
thanks, but another questions: are moog bads? according to my little experience with the brand, they ain't bad, but for a SUV and high performing cars as ours is, i dont know if the holds the name, please someone chime in, thanks in advance
Old Apr 13, 2015 | 07:38 AM
  #83
JMII's Avatar
JMII
Red face
Just attempted this procedure this weekend but failed, had to take it to a shop
Got that one really difficult bolt out by using a long, thin extension and the smallest (low profile) 17" mm socket I could. It is not easy but do-able. Required getting the steering angle just right to have enough room to work. My problem was after getting all the bolts off the darn hub wouldn't budge! In retrospect I should have put the wheel back on and used it as leverage to help pull the hub out. Once the wheel and rotor are off there isn't anything to really grip the hub itself with. What you really need is a slide hammer / hub puller. There is a reason they sell specialty tools. Hopefully this note might assist others.
Also had the problem with dust shield getting slightly bent and rubbing against the rotor once I put everything back together. So keep an eye out for that.
Old May 17, 2015 | 08:56 AM
  #84
Rockytopturbo's Avatar
Rockytopturbo
This might sound strange but is it possible to remove the wheel hub assy with the wheel still mounted? I have 2 stripped studs,and I can't get the lug nuts off. I figured i could pull the wheel hub off and cut the head of the stud off with a dremel. I tried drilling the studs out but after going through a few drill bits i gave up.
Old May 17, 2015 | 09:38 AM
  #85
dkmura's Avatar
dkmura
General & DIY Moderator
Wow- Nissan engineered the Z so the wheel hubs are extremely difficult to remove with the wheel still attached. The only time I've ever seen this accomplished is after a racing accident in which the entire wheel was ripped off a car after hitting a wall or tire barrier. Not something you want to have happen to your Z!
Take it to a wheel/tire shop and have them remove the wheel...
Old May 17, 2015 | 11:52 AM
  #86
Rockytopturbo
In theory, If i can remove the brake caliper and bracket, then remove the 4 hub bolts, the hub would come right off without removing the tire. Is there something i'm missing? I really don't want to drive the car with only 3 tight lug nuts.
Old May 17, 2015 | 06:43 PM
  #87
dkmura's Avatar
dkmura
Theory is crap- you're gonna tear up a lot more of your car (and yourself) trying to do this. Use your insurance or just hire a cheap tow to get you to the tire store. Or you can spend hours at hard labor and still be stuck..your choice.
Old May 20, 2015 | 09:34 AM
  #88
Rockytopturbo
It is possible to remove the hub with the wheel still attached
Thanks for the "Theory is crap" comment. It motivated me to prove you wrong. I didn't even have to wreck my car to get it off. Maybe next time you should have some facts to back yourself up before you start running your mouth.
Old Jan 25, 2016 | 01:50 PM
  #89
Nismo Ninja's Avatar
Nismo Ninja
If I may add on one last piece of advice to this thread I would say to have a large pair of channel locks or C-clamp handy. After getting the hub assembly and rotor back on I had a hell of a time getting the caliper to fit back onto the rotor. After scratching my head a bit I realized the piston had slightly compressed. Take your channel locks and squeeze that puppy back in. Caliper went on no problem.
Old Apr 28, 2016 | 04:47 PM
  #90
Yellow350ZKid's Avatar
Yellow350ZKid
Default Front end problem
I have a noise when driving that sounds like a bad wheel bearing, but I put the car up and checked the wheels for play and they were as sold as a rock. What can cause this problem. It get louder when I turn.
Can anyone help with a suggestion.
John
Old May 14, 2016 | 07:44 PM
  #91
bananernick's Avatar
bananernick
Default Helpppp!!!!!
I have the rotor off all of the bolts holding on the hub but the hub wont budge ive tried pb blast rubber mallet hammer sledge hammer and it still wont budge
Old May 15, 2016 | 06:23 PM
  #92
Heritage's Avatar
Heritage
Try bolting the wheel back on and turning it left and right with the car's weight on it.
Old Nov 18, 2016 | 03:19 PM
  #93
WYZIWYG's Avatar
WYZIWYG
Just had my driver's side replaced a few weeks ago since it was making alot of noise. However the passenger side is still quiet. My car has over 100k on it now ['05], so I was curious should I replace the passenger side as well or just wait for it to go out too?
Old Feb 17, 2017 | 05:59 PM
  #94
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Any guide to removing the hub from the bearing or does everyone just get the entire assembly?
Old Feb 17, 2017 | 08:14 PM
  #95
rottingcat's Avatar
rottingcat
just replaced mine, i would not recommend it everyone just replaces the whole assembly only the rear can/is done separately
Old May 24, 2017 | 08:23 PM
  #96
Miguel200095's Avatar
Miguel200095
Excellent write up and pictures. Had a hard time getting the rotor out but it budged. Thank you!
Old Nov 13, 2017 | 08:55 AM
  #97
350zx6r's Avatar
350zx6r
Are you guys getting OEM replacement or aftermarket? I seen somebody saying the OEM is garbage. I seen one at ebay with lifetime warranty. Question is getting that warranted.
Old Nov 13, 2017 | 09:12 AM
  #98
350zx6r's Avatar
350zx6r
https://www.ebay.com/itm/TRQ-Front-W...NZzft2&vxp=mtr
Old Aug 4, 2019 | 10:16 PM
  #99
abester322's Avatar
abester322
Default Break Pads
Originally Posted by Jtuned Z33
Just did this install, but now my wheel squeaks while driving any ideas?
It's the break pads
bcoffee20
Nov 19, 2015 06:39 PM
CrowzRSA
Sep 21, 2015 04:00 PM
