DIY: titanium brake shims
Old Jun 7, 2010 | 04:11 PM
mw9's Avatar
mw9
Default DIY: titanium brake shims
I am having my dad make these. Still finding the perfect method of cutting, titanium is some tuff sht. I have a 03 touring, found a set of dual piston 06 calipers for basically nothing, front and rear. Too poor to buy a BBK. Took some trial and error figuring out how to bend it without weakening it or breaking. But I think we have it. Let me know what you think
Titanium sheet from was fairly cheap around $25-35
http://cgi.ebay.com/3-pcs-TITANIUM-S...item3cacdf685e
starting to shape
finished product
Old Jun 8, 2010 | 08:26 AM
RandomHer0's Avatar
RandomHer0
Dang, I just bought some Ti Alloy ones from http://www.tispeed.com/
Old Jun 8, 2010 | 08:37 AM
mw9's Avatar
mw9
Cheapest route I found was to make them myself, plus they only make the shims for Brembos. So I had to make them for my non-brembo setup.
Old Jun 8, 2010 | 08:39 AM
RandomHer0's Avatar
RandomHer0
Right, easier for me since I have Brembo.
Well done sir.
Old Jun 8, 2010 | 08:46 AM
GT-Rob's Avatar
GT-Rob
Think I might try this myself (also stuck with non-brems)
What did you use for the cuts/bends? Looks very clean, good work!
Old Jun 9, 2010 | 01:05 PM
sektor 11's Avatar
sektor 11
Whats the advantage of titanium shims?
Old Jun 10, 2010 | 02:34 AM
mw9's Avatar
mw9
Old Jun 10, 2010 | 04:48 AM
sektor 11's Avatar
sektor 11
Nice. Thanks for the link!
I'm not sold but let me know how it goes! Kind of curious.
Old Mar 7, 2011 | 04:01 PM
JDMStanced's Avatar
JDMStanced
So what did he use to cut and bend the titanium sheet?
Can you use the torch to heat em up for real titanium look?
Old Mar 7, 2011 | 04:08 PM
LaoSiFu's Avatar
LaoSiFu
Why do you want the titanium look when it isn't visible?
~Robert
Old Mar 7, 2011 | 04:18 PM
JDMStanced's Avatar
JDMStanced
It should be visible with non brembo.
Old Mar 7, 2011 | 06:05 PM
plumpzz's Avatar
plumpzz
What did u use to cut the Ti so nicely? I want to make a shield as well..
edit: dremel + high carbon wheel?
Old Mar 8, 2011 | 01:46 AM
mw9's Avatar
mw9
I used a shear at work to get them close and went back with dremel and grinding wheel
Old Mar 8, 2011 | 04:28 AM
RandomHer0's Avatar
RandomHer0
Real ti look?
Old Mar 8, 2011 | 03:09 PM
LaoSiFu's Avatar
LaoSiFu
I haven't seen non Brembo brakes in a long time but if I am not mistaken the visibility is very minimum.
~Robert
Old Mar 9, 2011 | 05:48 AM
mw9's Avatar
mw9
~Robert
Exactly, these are not for looks, these are for function. If they are titanium, won't they look titanium?
Old Mar 9, 2011 | 05:56 AM
plumpzz's Avatar
plumpzz
i want to make a spacer for the mounting of the clutch cylinder on the trans. reducing heat transfer from the clutch to the cylinder will prevent a nasty feeling clutch. I'll try this out this summer.
Old Mar 9, 2011 | 08:18 AM
JDMStanced's Avatar
JDMStanced
^^that's a good idea
Old Jul 23, 2013 | 01:57 PM
Oz Striker's Avatar
Oz Striker
Thread resurrection, but anyone know how thick a titanium sheet you could/should get in between the pad and calliper piston on Brembos? 1, 2, 3mm??
Stevo Z
Oct 3, 2015 09:14 PM
