Tein Flex Kit info needed
Old Jan 9, 2005 | 10:13 AM
JETPILOT's Avatar
JETPILOT
Default Tein Flex Kit info needed
Does the flex kit do away with the rear stock spring mount location on the arm and turn it into a coil over in the rear?
Is $1100 a good deal on the flex kit?
Should I get the EDFC?
Without the EDFC can the shocks be adjusted on the car?
JET
Old Jan 9, 2005 | 11:46 AM
juan's Avatar
juan
#1: Yes, it will replace the rear shock
#2: $1100 sounds like a good new price; if used, not so good.
#3: yes, get the EDFC if at all possible; it makes a cool sound when it goes into action.
#4: the edfc controls dampening (how hard it feels in use), whereas the outside wrenches control the height adjustment ONLY (I think).
Old Jan 9, 2005 | 03:45 PM
JETPILOT's Avatar
JETPILOT
Thanks for your reply...
I know it repaces the rear shock, I was asking if it does away with the stock srping mounting location,
It's new for $1100
Can the shocks be adjusted when installed or do they have to be removed to be adjusted?
JET
Old Jan 9, 2005 | 04:21 PM
juan's Avatar
juan
jet:
the edfc motors in the rear needed, in my car, some modification (cutting) on the rear strut towers to be able to put the individual motors in the rear coilovers.
I think my mechanic put the coilover in the original location, just replaced the shock,it seems to me. Sorry I can't be more specific,but I seem to recall it just replaced the original shock in the location.
The coilovers can be adjusted for height while on the car,but it is difficult bec. you are almost forced to raise the car, which is a chore in a low, heavy vehicle like the Z. Sorry I cant be more helpful, maybe some members with more experience can chime in.
Old Jan 9, 2005 | 04:50 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. no it does not
2. are they new?
3. yes you can still adjust the coilovers without the EDFC - the EDFC allows you to do if from inside the car
4. the height adjustments are on the car - takes no more than 30 minutes to do all 4 wheels - very very easy with just a floor jack
Adam
Old Jan 10, 2005 | 06:51 AM
King Tut's Avatar
King Tut
I gotta ask. Who in their right mind is selling the Tein Flexs for $1100 brand new? The best price I have ever seen was $1500 shipped.
Old Jan 10, 2005 | 09:31 AM
Road Warrior's Avatar
Road Warrior
i could have had the flex's for 1400 new...but didn't want to deal with the noise issues. i went with the hks ls+ instead and couldn't be happier with them. if the kit is new its a hell of a deal, otherwise you might want to reconsider
Old Jan 10, 2005 | 02:16 PM
jcr847's Avatar
jcr847
where are you getting the flex for 1100?
Old Jan 10, 2005 | 05:36 PM
JETPILOT's Avatar
JETPILOT
THE SET IS NEW!
Well..... I think there is only one set.... I'm going to buy them, and I'll post the info.
JET
Old Jan 10, 2005 | 05:59 PM
jcr847's Avatar
jcr847
well if yuo change your mind id even give you a finders fee if you could get me those for 1100
Old Jan 10, 2005 | 09:08 PM
King Tut's Avatar
King Tut
Yeah, I think we all want to know where you guys are finding these great prices. I been checking prices for a couple months now.
Old Jan 11, 2005 | 11:11 PM
JETPILOT's Avatar
JETPILOT
It seams the Flex Kit is not supplied with the pillow mounts. Thats why its $1100.
JET
Old Jan 12, 2005 | 05:12 AM
King Tut's Avatar
King Tut
Yeah, not worth it then. The mounts is part of what makes the $700+ difference between the Basics and the Flex.
Old Jan 12, 2005 | 06:56 AM
Gsedan35's Avatar
Gsedan35
JET
When they revised the Flex with stiffer spring rates they also worked to resolve complaints about noise coming from the dampners in the rear. They switched to CS coilover upper mounts to cure the noise problem, which are described as "A hard rubber upper mount is used for noise proofing".
Pillow mounts cannot adjust camber on these cars.
Given how much noise can come through with the oem shocks and mounts when one removes that chunk of soft rubber, I'd hate to think how much noise you'd get with something that use's 672lbs springs vs 314/342.
Bodyboarder81
Nov 2, 2015 12:17 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
