StopTech Stainless Steel Line Install Manual
The question has been asked time and again, so here's the answer!
http://www.stoptech.com/installation...A_10-25-04.pdf
This manual can be found on our website under
Technical
StopTech Big Brake Kit Installation Manuals
Scroll down to Nissan 350Z...Front Line Install
Enjoy.
Technical
Enjoy.
Two notes on my experience installing Stoptech lines:
I noted I had to flip the lines side to side (Left line>Right side) in order to do the suggested line routing for Brembo calipers and have the bracket nest like the photo.
I found that propping a rod between the seat and the brake pedal, depressing it an inch or so, kept fluid from leaking out. I didn't use the rubber plugs.
edit-
It's freeware, if you don't have it, do a search. GL!
350z, install, installation, installing, instruction, instructions, line, lines, manual, manuals, routing, ss, stainless, steel, stoptech
