Tein Coilover Not Lowering In Rear ????
Old Jan 28, 2005 | 05:12 AM
symbolic350's Avatar
symbolic350
Default Tein Coilover Not Lowering In Rear ????
I JUST INSTALLED TEIN BASIC COILOVERS AND FRONT DROPS FINE BUT REAR STLL WAY TOO HIGH, DO I HAVE TO REMOVE SOMETHING ?? PLEASE HELP
Old Jan 28, 2005 | 06:27 AM
ALong's Avatar
ALong
The car looks fine, definately lowered in the back. Did you do a before and after ride height measurement to see how much lower it is?
Old Jan 28, 2005 | 09:26 AM
King Tut's Avatar
King Tut
Nothing should be removed if I remember correctly. The spring is repaced with the coilover in the rear. Do you have the spring perch down as far as it will go?
Old Jan 28, 2005 | 02:52 PM
ss350's Avatar
ss350
Yea, I basically have the rear all the way down, but it is low enough for me. I believe the max drop in the rear is like 1.1 or 1.3 inches.
Old Jan 28, 2005 | 03:28 PM
symbolic350
sorry my sig was on springs the back only drop like a 1" thats really sucks i could of saved 800.00 and been lower somethings gotta be wrong
Old Jan 28, 2005 | 04:33 PM
King Tut's Avatar
King Tut
If being low is all you care about you could have just had your springs cut. The back is really simple to install. I can't think of any common thing that could have been done wrong.
Old Jan 28, 2005 | 04:38 PM
Gsedan35's Avatar
Gsedan35
DO NOT CUT THE COILS!!! You will either weaken the springs or raise the effective spring rate. Tein basic's can only deal with a very tiny increase in spring rate, given the shape of owner reviews, frankly I would only consider lowering the rate, if at all a tiny amount.
Question I have, do these coilovers utilize the oem upper spring seat? If so, that is where you can lower the rear from, by modifying and if needed back filling with shims.
Old Jan 31, 2005 | 05:44 AM
symbolic350
HELL NO ILL SELL THEM BEFORE I CUT THEM I GOT THEM TO DROP ILL POST PICS LATER THANKS FOR INPUT GUYS
Old Jan 31, 2005 | 09:06 AM
King Tut's Avatar
King Tut
I wasn't telling him to cut the Basics. He was bitching about paying $800 and not being lower so I told him he could have cut the stock springs and been real low and saved alot of money IF that is all he cares about. I would never ACTUALLY recommend cutting your springs, haha.
Old Jan 31, 2005 | 09:24 AM
MDubbsZ's Avatar
MDubbsZ
you could try completely removing one or both of the adjustable pieces. that would give you another 1/2 to 3/4 inch drop.
Old Jan 31, 2005 | 12:42 PM
2004z's Avatar
2004z
Sleeps in 350Z
Nice rims
Old Apr 11, 2023 | 03:09 PM
michaelsb03's Avatar
michaelsb03
this is a reach but hope I get a response what did you end up doing to the rear? I’m going through the same now my front drops fine the rear doesn’t drop as much as I would want it to
Old Apr 11, 2023 | 03:55 PM
travlee's Avatar
travlee
Master
He hasn't logged in since 05
Old Apr 12, 2023 | 05:04 AM
Heel Til I Die's Avatar
Heel Til I Die
If you just did the install, give it some time and everything will settle down. I installed these in a friend's Z and he was pissed since the rear was still too high (for him). It sat overnight and there was a noticeable drop after everything settled.
