Rear suspension removal? Anyone do their own?
Old Mar 1, 2005 | 04:34 PM
speedform's Avatar
speedform
Default Rear suspension removal? Anyone do their own?
So I've pulled out all the plastic pieces covering the rear stamped steel brace and shock housing but I can't seem to find any room to get a wrench on the upper shock perch. Am I missing something? Do I need to remove the black metal support piece (the one with about 10 cad plated bolts going through it)?
I have a damaged shock so I need to get it out to fix it asap before next weeks California Speedway NASA event. Any help or advice is appreciated. cheers,
Old Mar 1, 2005 | 06:59 PM
SungNamZ's Avatar
SungNamZ
I did shocks, springs and sway - front and rear eight months ago and didn't find it that difficult, especially the rear. You are describing some things in the rear that I can't recall having to do.
Somewhere are this site, you could do a "search" using Koni shocks under "suspension" and something would come up, but that has been months ago.
If you are a member of www.zchickz.com you will find the help you need in their "Garage" section.
Old Mar 1, 2005 | 10:23 PM
speedform's Avatar
speedform
HA! Typical. I'm making things more difficult then they need to be. Thanks for th reply...
Old Mar 1, 2005 | 11:07 PM
neur0sis's Avatar
neur0sis
You remove the rear shocks from UNDER the car, in the tirewell. No need to disassemble the interior
Two nuts from the top, and one nut/bolt on the bottom of the shock.
Old Mar 2, 2005 | 04:56 AM
King Tut's Avatar
King Tut
Yep, you can't get a wrench on them, but a socket and extenstion work great. If you got adjustable shocks, then you will have to remove some plastic in the interior to adjust them.
Old Mar 2, 2005 | 07:28 AM
speedform's Avatar
speedform
Yeah..all the plastics out. I getting some strange clunking and squeaking under load coming from back there. Not sure if it's blown but I don't think I want to do a track event on it.
Anyone know of an HKS rebuild shop in socal?
350Z_Al
Oct 29, 2020 07:44 PM
