Update on Project Mu Brake Pads
Old May 3, 2005 | 11:31 AM
  #41
scubasteve's Avatar
scubasteve
Originally Posted by fairladyZ in Japan
I am thinking of going with the Level MAX 9000 pads .. top-of-the-line from sports to racing.
OK...nice pads, but keep in mind that the more aggressive the pad, the more rotor wear you will have. Looking at the chart, these look pretty aggressive and likely operate at higher temperatures. For street use as daily pads, I don't think these would be a good option. Personally, I'd go with a lesser grade pad for the street. You will also likely run into a lot of squealing because the pads will not likely reach their operating temperatures. This also affects the brakes performance.
Just something to consider.
-Steve
Old May 3, 2005 | 11:38 AM
  #42
scubasteve's Avatar
scubasteve
Originally Posted by KManZ
I am getting my B-Force pads on Thursday!! Have an appointment at the dealer to have them installed on Friday.. is there any extra parts needed for the install, or do they bolt right in? I don't want to get to the dealer and have them tell me that they don't fit or something b/c of a missing part!!!
DIY....30-45 minutes max in your garage.
Should I upgrade my brake fluid too? If so, what do you guys recommend?
It isn't necessary, but it certainly won't hurt. If you were tracking, then of course you should. Otherwise, not a big deal.
Finally, do you think these will wear as good as stock, or am I going to be replacing sooner?
I think they should actually last longer. The stock compound seemed pretty soft, hence all the dust. They will likely last longer than the stock pads.
good luck,
Steve
Old May 3, 2005 | 07:17 PM
  #43
KManZ's Avatar
KManZ
Thumbs up
Nice info! Thanks Steve. After your reply and some more research I think I may buy some new rotors as well.
Old May 3, 2005 | 11:26 PM
  #44
fairladyZ in Japan's Avatar
fairladyZ in Japan
-Steve
Steve ... Very good point. Will do some more research since there are a variety of pads available here.
Thanks .. Bill
Old May 8, 2005 | 10:18 PM
  #45
etang789's Avatar
etang789
I have looked in the projectnissan.com... they do not have a specific project mu b-force pad for G35 coupe with brembos. I assume that 350z and g35 brembos are the same. so does that mean i will need [Project Mu Brake Pad B-Force 350Z 03+ Front (Brembo)], and [Project Mu Brake Pad B-Force Skyline GT-R R32 Spec V 89-95, R33/R34 95-02 & 350Z Brembo 03+ Rear]. which the total comes out as $180.20 from projectnissan.com are there cheaper sites? Am I getting the right pad for my 6mt G35 coupe?
Old May 8, 2005 | 10:25 PM
  #46
ssk0771's Avatar
ssk0771
I think they are same. Call them and ask them.
Also, I checked around and they were cheapest. Since I live here in CA, sales tax is 8.25% so it was better for me to order it from outside and pay for shipping.
Old May 11, 2005 | 01:48 PM
  #47
etang789's Avatar
etang789
Yea i emailed them and ask ...they said they are the same , so i went and order them for my 6mt coupe... i will let you guys know what is the results... Now my brembo doesnt even stop, its so weared out(well i would say its worse than a normal car stopping distance)
Old Jun 1, 2005 | 08:35 PM
  #48
imalazeeass's Avatar
imalazeeass
any update?
Old Jun 1, 2005 | 10:18 PM
  #49
ssk0771's Avatar
ssk0771
Originally Posted by imalazeeass
any update?
I recently got my rotors turned because my steering wheel was shaking so when I took it to the shop, my rotors were wraped. Since than, no shaking. I still have a little suqeak here and there but nothing major. It seems like the squeak is comming from left rear only.
Thats about all the update.
All I can say is its still the best pad I used so far.
Old Jun 2, 2005 | 10:26 AM
  #50
etang789's Avatar
etang789
I got them put on about 2 weeks ago, I would say they bite harder than stock pads. only minor squeak when parking the car, and for the price nothing can beat it. I like these pads alot
Old Jun 2, 2005 | 11:22 PM
  #51
KManZ's Avatar
KManZ
I just installed the B-Force pads on my fronts tonight... gotta wait for the rain to subside so I can do the rears and then bed them...
Old Jun 4, 2005 | 12:08 AM
  #52
fairladyZ in Japan
I ordered the HC+ and will be installing them the week of June 20th.
These pads will replace my current NISMO aftermarket pads ... will post results and impressions later.
Old Jun 6, 2005 | 07:12 PM
  #53
KManZ's Avatar
KManZ
Well, it has been 3 days since I finished installing the P-Mu B Force pads and Rotora rotors.. After bedding and what not, I have noticed that the braking power/ bite has increased steadily as time goes on. Already I can say that it is equal to if not better than stock. ssk0771, did you notice this as well or was yours better out of the box?
AND NO DUST!!! My car looks as clean as when I waxed it after the install the other day!!!
No squeeking either, which is a god send because the stock brakes were driving me nuts.
Thanks to ssk0771 for his suggestions and input.
Old Jun 6, 2005 | 07:15 PM
  #54
imalazeeass
where did u get ur b force pads from?
Old Jun 6, 2005 | 07:40 PM
  #55
KManZ's Avatar
KManZ
I ordered the brake pads from projectnissan.com
Old Jun 21, 2005 | 08:37 PM
  #56
CAVZ33's Avatar
CAVZ33
I just got my set of rear and front project mu pads b-force.(non-brembo). I am getting ready to install them, but I noticed that on the rear pads, only one of them has a sensor. Does anybody know if this is how they're suppsoed to be? My fronts have all the sensors.
Old Jun 21, 2005 | 10:18 PM
  #57
KManZ's Avatar
KManZ
Yes, just one side has the sensor... the Mu pads also come like that if I am not mistaken. I have no idea why it is like that...
Old Jun 21, 2005 | 10:23 PM
  #58
etang789's Avatar
etang789
mine have none
Old Jun 22, 2005 | 09:59 AM
  #59
KManZ's Avatar
KManZ
etang, you have the Brembos on your G35C? If so, yours may more than likely be different than those of us with a non-Brembo setup.
Then again I may be mistaken..
Old Jun 22, 2005 | 11:17 AM
  #60
zzz350's Avatar
zzz350
Do these pads come in the size for the non-Brembo brake models?
