suspension: Pros only
Old Apr 28, 2005 | 11:40 AM
mario60185's Avatar
mario60185
Chicago Realtor
Default suspension: Pros only
Ok im not a noob to any of this so please no newb answers, but if you know what your talking about, please, i need a little help.
1. i know shorter springs will be harder on stock shocks, but does the stiffness of the spring also have that effect?
2. To loosen the back end, meaning more oversteer, i would want stiffer rear springs, right?
3. How much stiffer would you think is best, i dont have a problem with stiffness, just wondering what your personal exp. is with stiffer springs and this also has to do with question 1.
4. most important question, im running 18x9 and 10.5 both 30mm offsets, tires are conservative: 245/40 and 275/40, if i lower 1.2" front and rear will it rub. Has anyone here run a similar setup and had rubbing problems.
Thank you.
Old Apr 28, 2005 | 12:14 PM
mario60185's Avatar
mario60185
Chicago Realtor
one more thing...whos got pics of a z lowered with just springs on 18's with more thasn an inch drop. I want the tire to almost touch the fender.
Old Apr 28, 2005 | 01:20 PM
mario60185's Avatar
mario60185
Chicago Realtor
please help, i need pics of 18's with a big drop, im not interested in less than 1" drop
Old Apr 28, 2005 | 04:25 PM
bwilliams's Avatar
bwilliams
The following cause-effect statements assume all other characteristics of the car are unchanged. Sorry for long response, but sounds like you want real answers.
1. Shorter springs with no change in spring rate will simply lower the car, which lowers the cars center of gravity, which reduces the tendency to roll (reduced moment) during a turn, braking or acceleration, and increase the possibility of bottoming out the suspension. Shorter springs (without a change in spring rate) does not directly have any impact on your shocks.
However, shorter springs typically come with higher spring rate (stiffer). A stiffer spring, regardless of whether it changed your ride height or not, will wear shocks quicker, due to the quicker "bounce" (higher frequency), puts more cycles (up/down) on the shocks.
2. Stiffer springs in rear will increase oversteer.
3. I dunno...lots of variables. Suggest trial-error. (FYI, there are a few other things you can attempt to increase oversteer (ie, increase front traction, softer front sway bar, optimize front tire pressure, lower rear tire pressure, shift center of gravity forward).
Old Apr 28, 2005 | 04:32 PM
mario60185's Avatar
mario60185
Chicago Realtor
thank you, i was already aware of everything except for the part about the springs, so ytour aying if i lower 1.5 all around but keep the same spring rates, there will be no extra shock wear?
Old Apr 28, 2005 | 04:37 PM
thawk408's Avatar
thawk408
https://my350z.com/forum/brakes-and-suspension/112798-suspension-faq-and-reviews-tech-info-tuning-and-reviews.html
Old Apr 28, 2005 | 05:11 PM
mario60185's Avatar
mario60185
Chicago Realtor
thanks, but still not sure.
KOF
Tuning
Sep 30, 2015 04:09 AM
