350EVO sway bar install question
Old Apr 28, 2005 | 08:33 PM
tommym's Avatar
tommym
Default 350EVO sway bar install question
Hey, I bought the front sway bar from 350EVO. When I went to install it, the bolts in the end link will not go through far enough to put the bolt on. Are these supposed to work with a stock setup? I read that someone mention that they had to dremel down the area to make it work, but how much? We tried it, but still didn't get enough to work. Has anyone else had this problem, and if so, how did you solve it?
Thanks,
Tommy
Old Apr 29, 2005 | 02:28 AM
jmark's Avatar
jmark
PM BJ aka dwnshift on this board. He can help he works for 350Evo.
Old Apr 29, 2005 | 02:29 AM
jmark's Avatar
jmark
Phone #. Ask for BJ.
http://www.350evo.com/
Old Apr 29, 2005 | 03:28 AM
zzzya's Avatar
zzzya
You do not have to dremel anything!!! You have to flip the connecting rod upside down that the sway bar connects to. When you go to remove that connecting rod you will notice that it is not nearly as thick allowing the bolt to make it through the sway bar for installation. Pretty simple and requires no modification to the sway bars. Good luck!
Old Apr 29, 2005 | 10:01 AM
daveh's Avatar
daveh
^^ ditto what he said. You will also have to disconnect the shock to have clearance to do this.
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
torchkc
Sep 11, 2015 08:26 PM
