The Lowest Springs
Old May 4, 2005 | 08:55 PM
fonzy's Avatar
fonzy
Default The Lowest Springs
Hey Guys, I Want To Lower My 350z But I Want The Lowest Drop Possible With Just Springs, Could U Guys Refer Me To The Best Out There? Thanks.
Old May 4, 2005 | 09:24 PM
GQ 350z's Avatar
GQ 350z
Tanabe GF210--> I own these, about 1.3" all around (based on my actual inspection).
H & R Springs ---> about 1.5" all around I believe, super low, great springs.
Eibach Sportlines----> Just came out, but very low drop (heard they sag? ).
Good luck. There are other (cheaper) brands out there that might drop lower *ahem* sprint *ahem*, but they don't perform as well as those listed above.
Ravi
Old May 4, 2005 | 09:35 PM
2 low Z's Avatar
2 low Z
I have the Tanabes NF210, 1.2 all around. I believe the GF210 are 1.0 front and 1.2 rear as per the wesite. I have very pleased with the ride quality, better than stock. I'll have a better write up an a later date. In a way I kinda wished I waited for the sportlines (I didn't know about them at time of perchase) for a little lower stance, but I'm still very happy with the Tanabes.
I heard the Eibachs sag a tad bit, but for what it's worth the Pro Kit is 1.0 all around and Sportline is 1.2 all around.
Hope this helps
Old May 5, 2005 | 11:59 AM
fonzy's Avatar
fonzy
Thanks A Lot Guys I Think Ill Research It A Bit More. If U Guys Have Any Good Ideas On How To Lower My Car. Let Me Know, I Dont Want To Spend That Much, But I Am Going To Change My Struts And Cambers. Im Getting New Tires Also For My Stock Seventeens.
Old May 5, 2005 | 12:22 PM
mojo powered's Avatar
mojo powered
I had the sportlines on my GTI for over 40K, best springs I ever owned but harsh ride, never experienced sagging. The manufacturing process involves a "cold coiling" process and apparently that prevents them from sagging over time. I heard of sagging with H&R coilover springs but never with Eibach springs.
Again, they are not made for cruising, they're track springs. If you want a drop and a little bit stiffer ride, then go for Eibach Prokit.
Old May 5, 2005 | 12:27 PM
sisco534's Avatar
sisco534
Prokit rocks , 32k no sag stiff in the turns love them, Good drop takes a week or so to settle.
Old May 5, 2005 | 12:45 PM
MATTRESS MAN's Avatar
MATTRESS MAN
I've had the sportlines on for two weeks now and the front has dropped barely over an inch (maybe 1.2) and 1.25" in the rear. I hope they drop a little lower in both front and rear. Ride is excellent, smoother than stock but a little bouncier. Hope this helps.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
